I have a Razer BASILISK V3 mouse and recently whenever I left click, the mouse pointer starts clicking and dragging down and to the left. This happens as long as I am holding the left click button. So I can’t right click a piece of text without it selecting some characters to the left of it and I also can’t click on draggable items.
What I tried:
Unplugging and replugging the mouse
Checked libinput version - I have libinput 1.25.0 and xf86-input-libinput 1.4.0
Checked evdev version - I have libevdev 1.13.1
Ran xinput list - the output is as follows: (I’m on Wayland):
I rebooted my system, and the mouse issue dissapeared. I reproduced the mouse issue by playing Back to the Dawn on Steam with my controller, then exiting out of the game. When I did, the mouse was back up to the clicking-and-dragging bug.
I thought, there must be something in Steam that is causing this. So, I ran sudo killall steam and the mouse works normally again. I reopen the Steam client and the issue does not come back.
I reopened Back to the Dawn, but this time did not touch the controller and played using only keyboard and mouse. Upon exiting the game, the mouse issue is not present. When I open the game and used the controller in the game, the issue didn’t come back either. I mention this game specifically because the issue did not happen when opening other games.
So the issue happens when I start the Steam client on a fresh boot, play this one specific game, then exit it. Killing and reopening the Steam client and playing the game again does not reproduce the issue, only on first boot.
What is going on here? I don’t want to have to run sudo killall steam every time my mouse starts acting up like this, and I’m going to be playing this game for a while. I’d like to know the root cause.
I have no idea why is it happening, but I searched linux mouse drift controller looks like a lot of people have issues with controllers. Did you try unplugging it after you stopped the game?
Ok as it turns out Steam was not necessary at all. I literally just moved the right stick on my controller, and the mouse cursor acts up. Unplugging the controller restores mouse functionality to normal, and the issue only happens when I move the right stick again.
A question I saw on StackOverflow suggests disabling joystick control over the mouse cursor by editing /etc/X11/xorg.conf.d/51-joystick.conf, so I’m going to try that
EDIT: It worked. Solution is to create file/etc/X11/xorg.conf.d/51-joystick.conf, then put the following in it:
