I recently developed, maybe a couple weeks at the oldest, an extremely odd issue where my MIDI keyboard (some cheap thing off amazon) that I use over USB will be recognized by everything, but no input will be registered or sent anywhere.
On Windows, it works perfectly fine, so I know it isn’t an issue with the keyboard itself.
In Linux, I can detect that it is registered with lsusband aplaymidi -l & know it isn’t just piped into itself by looking at qpwgraph. I have tried multiple cables in multiple ports & the behavior remains the same.
Here, I have run into a brick wall with what I know what to do or check for! Pretty much any help would be appreciated! The closest lead I have is that dmesg | grep -i midi will will output after the device is plugged in usb 1-1: Quirk or no altset; falling back to MIDI 1.0 but so far, I haven’t found anything useful to this specific issue.
Quick Edit: I also know that it is not stuck in some output mode, as I used aplaymidi -p 16 gbuster.mid to try and play a ghostbusters midi through it.
