Bobzka
October 9, 2024, 1:25pm
1
Hey guys,
first the hardware in doubt:
Logitech G502x Wireless Mouse
Corsair K65 Plus Wireless Keyboard
The faulty and problematic hardware is the keyboard. It is connected via dongle from Corsair. But the dongle stopped working after like 2-3 minutes of no usage and IT did not connect itself. So I can use the keyboard only in wired mode.
The mouse works fine everytime. I dont know where to look at.
z580c
October 9, 2024, 1:52pm
2
Step one is check if the behaviour persists with a different USB port
Bobzka
October 9, 2024, 2:10pm
3
Tried every single usb port. Also the USB Hub from my monitor
Maybe the reciever is set to auto suspend / power savings mode by default and has trouble to be reactivated.
Try
inxi -Ja | grep Device
That will generate a list of the connected USB Devices connected to your system,
in that format
Device-1: >>1-4.2<<:6 info: Logitech Unifying Receiver
The individual >> USB ID << is the important part here, with that individual ID call
cat /sys/bus/usb/devices/ >> USB ID << /power/control
if it returns
auto
then your USB reciever will deactivated after a short time of inactivity.
To change that behavior you can override that setting with:
echo 'on' > '/sys/bus/usb/devices/ >> USB-ID << /power/control';
But I can also be totally mistaken as I’m not that experienced with Linux, up so far. Thus, your mileage may vary.
Bobzka
October 9, 2024, 2:56pm
5
It returns “on” for me. I set a udev rule as stated in the wiki to turn off usb autosuspend completly.
But my keyboard does not respond after a while.
Bobzka
October 9, 2024, 3:02pm
6
This is from journalctl after the disconnect.
