I was wondering if anyone had any recommendations on a USB mic and camera that works well for work? Nothing fancy, just something to handle online meetings.
Thanks,
Thanks,
I have used both the Logitech C920S and the Logitech C270 with success.
The C270 is lower resolution and has a narrower fov. Whether that is good or bad depends on your personal preference.
Thanks, good to know. It used to be so easy to find a camera and mic 20 years ago. Now the choice runs the gamut. I even thought of a mic, headset, and camera set system.
I’ve seen great reviews of Onkyo headsets and equally as good in-ear earbuds. I’m looking into that. I’ll post what I find.
I’ve been wanting to get a Spedal MF934H webcam for some time now but i don’t know if it works on linux
