Hello, on my motherboard (asus b550 rog strix e-gaming) there are sound outputs via type-c, but this audio output path does not work (in Linux, in Windows everything is fine): I connect headphones through the adapter to the type-c, there is no sound.
Other audio output paths work fine(hdmi, 3.5 jack), the sound is adjustable. How to get audio output via type-c to work?
I have the default installed (during system installation) pipewire.
Did you try to select the correct device with alsa-mixer or just to send the output using helvum or similar?
