Since I’ve upgraded to the new 6.1.12-1-lts my wired connection is no longer recongnized (Realtek RTL810xE). the previous 5.19-lts it worked with this AUR package >> aur/r8101-dkms 1.035.03-2 (+6 0.00) (Orphaned)
I tried to build it on the new 6.1-lts kernel and I got this output:
:: Running post-transaction hooks…
(1/3) Arming ConditionNeedsUpdate…
(2/3) Install DKMS modules
==> dkms install --no-depmod r8101/1.035.03 -k 6.1.12-arch1-1
Error! Bad return status for module build on kernel: 6.1.12-arch1-1 (x86_64)
Consult /var/lib/dkms/r8101/1.035.03/build/make.log for more information.
==> WARNING: dkms install --no-depmod r8101/1.035.03 -k 6.1.12-arch1-1' exited 10 ==> dkms install --no-depmod r8101/1.035.03 -k 6.1.12-1-lts Error! Bad return status for module build on kernel: 6.1.12-1-lts (x86_64) Consult /var/lib/dkms/r8101/1.035.03/build/make.log for more information. ==> WARNING: dkms install --no-depmod r8101/1.035.03 -k 6.1.12-1-lts’ exited 10
(3/3) Refreshing PackageKit…
I’m stuck using wifi at this moment until I can find a solution.
Thanks!
