Upgraded my CPU and motherboard and now Endeavouros won't work with my front audio
could be you where on AMD CPU before?
Worth giving it a shot. :+1:
But I already did reinstalled endeavour OS twice, the second time because I forgot to choose btrfs on calamaris
No I was on 8700k before.
I think maybe i found the solution. :thinking:
Can you please go through this and check if it is the same on your motherboard. The solution is post#10 but i want you to read through the posts and run all the same commands to see if it is the same and then try the solution in post 10 to see whether that fixes the issue. :crossed_fingers:
https://bbs.archlinux.org/viewtopic.php?id=272523
Edit: Actually it may be post #16 and #18 that is a better fix? Maybe you get it figured out. As i don’t have this hardware.
Edit2: Also #25 might just do it too. You’re going to have to go through the whole page read it and check it out.
I already found this but the solutions only broke my audio even further. but OP has the exact same issue on the exact same motherboard
Well it’s working for them that’s why i wanted you to compare the hardware outputs. You may have different numbering. :man_shrugging:
well i’ll check it out in more depth later
yeah apparently ALC4080 isn’t properly supported on linux. its fine, support is being worked on already.
