Updating forces a logout
nov   26 18:54:35 probook sudo[28179]:    johan : TTY=pts/0 ; PWD=/home/johan ; USER=root ; COMMAND=/usr/bin/pacman -D -q --asexplicit --config /etc/pacman.conf -- audacious
nov   26 18:54:35 probook sudo[28179]: pam_unix(sudo:session): session opened for user root(uid=0) by johan(uid=1000)
nov   26 18:54:35 probook sudo[28179]: pam_unix(sudo:session): session closed for user root
nov   26 18:54:35 probook wireplumber[970]: <WpPortalPermissionStorePlugin:0x563fb1e43110> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
nov   26 18:54:35 probook systemd[1]: Started Process Core Dump (PID 28183/UID 0).
nov   26 18:54:36 probook systemd-coredump[28184]: Process 786 (Xorg) of user 0 dumped core.
                                                   Stack trace of thread 808:
                                                   #0  0x00007fa93a083b20 n/a (libc.so.6 + 0x1d8b20)
                                                   ELF object binary architecture: AMD x86-64
nov   26 18:54:36 probook systemd[1]: systemd-coredump@2-28183-0.service: Deactivated successfully.
nov   26 18:54:36 probook at-spi-bus-launcher[890]: X connection to :0 broken (explicit kill or server shutdown).
several times Xorg core dumping in the log… right after using pacman and an error from pipewire wireplumber here…
Must be fully up dto date to install new packages not “pretty much” arch does not support partly updates.
:wink:
next one dumping right after similar wireplumber error:
nov   26 19:06:04 probook wireplumber[970]: <WpPortalPermissionStorePlugin:0x563fb1e43110> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
nov   26 19:06:04 probook wireplumber[970]: <WpSiAudioAdapter:0x563fb20371e0> Object activation aborted: proxy destroyed
nov   26 19:06:04 probook wireplumber[970]: <WpSiAudioAdapter:0x563fb20371e0> failed to activate item: Object activation aborted: proxy destroyed
nov   26 19:06:05 probook systemd[1]: Started Process Core Dump (PID 30572/UID 0).
nov   26 19:06:06 probook systemd-coredump[30573]: Process 28227 (Xorg) of user 0 dumped core.
                                                   Stack trace of thread 28237:
                                                   #0  0x0000000000000031 n/a (n/a + 0x0)
nov   26 19:06:06 probook systemd[1]: systemd-coredump@3-30572-0.service: Deactivated successfully
So it is not updating or pacman/yay itself as it looks like some strange bug.
I think a better approach may have been to start a poll to see how many of us are x Manjaro folk. :smiley:
But seriously, investigating is the most fun part when these thing show up.
I did update, and again system throw me out to login screen … . so odd.
http://ix.io/4MG0
And it actually finished the update …
Maybe freedesktop.home1.service is to blame? :neutral_face:
Finally had a crash today after hoping it had fixed itself. Here’s the log: https://0x0.st/Hxlv.txt
Any ideas? :confused:
