rabcor
October 12, 2024, 10:38am
1
So I updated the system about 10 hours ago, it was roughly 24 packages I didn’t pay particularly close attention to which packages (it was all official packages though, no AUR ones). The PC updated successfully and shutdown normally after.
Now when I boot, when it asks for my LUKS password for the drives it will no longer accept the correct password.
What I most strongly suspect to be the problem is that my password uses non-english characters, as such my keyboard must be set to the correct language, this hasn’t been a problem for a good year now.
What I’m guessing happened is that the keyboard language on bootup has reverted to english, but it is ultimately a guess. If it’s correct though, how do I fix that?
rabcor
October 12, 2024, 12:48pm
2
I have tried this: Dracut and non-standard keymap
(as in i booted from a liveusb, and chrooted and did that)
It didn’t seem to fix the problem. I suspect then that the issue lies in systemd-boot
rabcor
October 12, 2024, 4:29pm
3
I gave up on this issue, just added another passphrase that can be typed on an english keyboard.
I am extremely disappointed by this experience. Just random nonsense costing me half a day where I couldn’t even boot into my computer only to end up ultimately unresolved and I had to use an undesirable workaround.
Here’s the pacman log for the update that broke this. The only thing I think could possibly have caused this is the dracut update: upgraded dracut (103-2 -> 104-1)
Pacman Log
[2024-10-12T00:02:06+0000] [PACMAN] Running 'pacman -Syu'
[2024-10-12T00:02:06+0000] [PACMAN] synchronizing package lists
[2024-10-12T00:02:14+0000] [PACMAN] starting full system upgrade
[2024-10-12T00:10:08+0000] [ALPM] running '71-dkms-remove.hook'...
[2024-10-12T00:10:08+0000] [ALPM] running '90-kernel-remove.hook'...
[2024-10-12T00:10:09+0000] [ALPM-SCRIPTLET] :: kernel-install removing kernel 6.11.2-arch1-1
[2024-10-12T00:10:09+0000] [ALPM] transaction started
[2024-10-12T00:10:09+0000] [ALPM] upgraded opencolorio (2.3.2-3 -> 2.4.0-1)
[2024-10-12T00:10:09+0000] [ALPM] upgraded python (3.12.6-1 -> 3.12.7-1)
[2024-10-12T00:10:10+0000] [ALPM] upgraded materialx (1.38.10-4 -> 1.38.10-5)
[2024-10-12T00:10:10+0000] [ALPM] upgraded openimagedenoise (2.2.2-1 -> 2.3.0-2)
[2024-10-12T00:10:10+0000] [ALPM] upgraded openimageio (2.5.15.0-2 -> 2.5.16.0-1)
[2024-10-12T00:10:10+0000] [ALPM] upgraded openshadinglanguage (1.13.10.0-2 -> 1.13.11.0-2)
[2024-10-12T00:10:10+0000] [ALPM] upgraded usd (24.08-3 -> 24.08-5)
[2024-10-12T00:10:10+0000] [ALPM] upgraded python-charset-normalizer (3.3.2-2 -> 3.4.0-1)
[2024-10-12T00:10:11+0000] [ALPM] upgraded blender (17:4.2.1-2 -> 17:4.2.2-4)
[2024-10-12T00:10:11+0000] [ALPM] upgraded breeze-gtk (6.1.5-1 -> 6.2.0-1)
[2024-10-12T00:10:19+0000] [ALPM] upgraded cuda (12.6.1-1 -> 12.6.2-1)
[2024-10-12T00:10:20+0000] [ALPM-SCRIPTLET] - When you uninstall an old, unrequired version of GCC that was previously
[2024-10-12T00:10:20+0000] [ALPM-SCRIPTLET] required by cuda for the default host compiler ($NVCC_CCBIN), you may need
[2024-10-12T00:10:20+0000] [ALPM-SCRIPTLET] to source /etc/profile or restart your session. Additionally, you may need
[2024-10-12T00:10:20+0000] [ALPM-SCRIPTLET] to clear the build cache of your projects where the old path may be still
[2024-10-12T00:10:20+0000] [ALPM-SCRIPTLET] recorded.
[2024-10-12T00:10:20+0000] [ALPM] upgraded dracut (103-2 -> 104-1)
[2024-10-12T00:10:20+0000] [ALPM] upgraded electron32 (32.1.2-1 -> 32.2.0-1)
[2024-10-12T00:10:20+0000] [ALPM] upgraded eos-bash-shared (24.16.24-1 -> 24.16.25-1)
[2024-10-12T00:10:20+0000] [ALPM] upgraded hyprland (0.44.0-1 -> 0.44.1-1)
[2024-10-12T00:10:20+0000] [ALPM] upgraded lib2geom (1.3-2 -> 1.4-2)
[2024-10-12T00:10:21+0000] [ALPM] upgraded inkscape (1.3.2-12 -> 1.4-1)
[2024-10-12T00:10:21+0000] [ALPM] upgraded js128 (128.2.0-1 -> 128.3.1-1)
[2024-10-12T00:10:21+0000] [ALPM] upgraded libkdcraw5 (24.08.1-1 -> 24.08.2-1)
[2024-10-12T00:10:21+0000] [ALPM] upgraded krita (5.2.6-1 -> 5.2.6-2)
[2024-10-12T00:10:21+0000] [ALPM] upgraded layer-shell-qt (6.1.5-3 -> 6.2.0-1)
[2024-10-12T00:10:21+0000] [ALPM] upgraded lib32-libnm (1.48.10-1 -> 1.50.0-1)
[2024-10-12T00:10:21+0000] [ALPM] upgraded libuv (1.49.0-1 -> 1.49.1-1)
[2024-10-12T00:10:22+0000] [ALPM] upgraded linux (6.11.2.arch1-1 -> 6.11.3.arch1-1)
[2024-10-12T00:10:24+0000] [ALPM] upgraded linux-lts-headers (6.6.54-1 -> 6.6.56-1)
[2024-10-12T00:10:24+0000] [ALPM] upgraded luajit (2.1.1725453128-1 -> 2.1.1727870382-1)
[2024-10-12T00:10:24+0000] [ALPM] upgraded nvidia-open (560.35.03-12 -> 560.35.03-13)
[2024-10-12T00:10:24+0000] [ALPM] upgraded polkit-kde-agent (6.1.5-1 -> 6.2.0-1)
[2024-10-12T00:10:24+0000] [ALPM] upgraded python-google-auth (2.32.0-1 -> 2.35.0-1)
[2024-10-12T00:10:24+0000] [ALPM] upgraded python-sphinx (8.0.2-1 -> 8.1.0-1)
[2024-10-12T00:10:26+0000] [ALPM] upgraded signal-desktop (7.27.0-1 -> 7.28.0-1)
[2024-10-12T00:10:26+0000] [ALPM] upgraded webkit2gtk-4.1 (2.46.1-3 -> 2.46.1-4)
[2024-10-12T00:10:26+0000] [ALPM] transaction completed
[2024-10-12T00:10:27+0000] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-10-12T00:10:27+0000] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-10-12T00:10:27+0000] [ALPM] running '30-systemd-update.hook'...
[2024-10-12T00:10:27+0000] [ALPM] running '60-depmod.hook'...
[2024-10-12T00:10:29+0000] [ALPM] running '70-dkms-install.hook'...
[2024-10-12T00:10:29+0000] [ALPM-SCRIPTLET] ==> ERROR: Missing 6.6.56-1-lts kernel modules tree for module ryzen_smu/162.e61177d.
[2024-10-12T00:10:29+0000] [ALPM] running '90-kernel-install.hook'...
[2024-10-12T00:10:29+0000] [ALPM-SCRIPTLET] Running kernel-install for 6.11.3-arch1-1
[2024-10-12T00:10:30+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback 6.11.3-arch1-1
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-pcrphase ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: modsign ***
[2024-10-12T00:10:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-10-12T00:10:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: btrfs ***
[2024-10-12T00:10:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-10-12T00:10:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-10-12T00:10:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lvm ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: mdraid ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: nvdimm ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu ***
[2024-10-12T00:10:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu-net ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fido2 ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pkcs11 ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lunmask ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: resume ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: virtiofs ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-10-12T00:10:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-10-12T00:10:36+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-10-12T00:10:36+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-10-12T00:10:37+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback' ***
[2024-10-12T00:10:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback' done ***
[2024-10-12T00:10:41+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd 6.11.3-arch1-1
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-10-12T00:10:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-10-12T00:10:43+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-10-12T00:10:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-10-12T00:10:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-10-12T00:10:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd' ***
[2024-10-12T00:10:49+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd' done ***
[2024-10-12T00:10:49+0000] [ALPM] running 'eos-nvidia-fix.hook'...
[2024-10-12T00:10:50+0000] [ALPM-SCRIPTLET] Installing kernel 6.11.3-arch1-1
[2024-10-12T00:10:51+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback 6.11.3-arch1-1
[2024-10-12T00:10:51+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-10-12T00:10:51+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-10-12T00:10:51+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-pcrphase ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: modsign ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: btrfs ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-10-12T00:10:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lvm ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: mdraid ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: nvdimm ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu-net ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-10-12T00:10:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fido2 ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pkcs11 ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lunmask ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: resume ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: virtiofs ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-10-12T00:10:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-10-12T00:10:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-10-12T00:10:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-10-12T00:10:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-10-12T00:10:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback' ***
[2024-10-12T00:11:00+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd-fallback' done ***
[2024-10-12T00:11:01+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd 6.11.3-arch1-1
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: bash ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shell-interpreter ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-10-12T00:11:02+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-10-12T00:11:03+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-10-12T00:11:03+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-10-12T00:11:03+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-10-12T00:11:04+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-10-12T00:11:05+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-10-12T00:11:06+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd' ***
[2024-10-12T00:11:09+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.11.3-arch1-1/initrd' done ***
[2024-10-12T00:11:09+0000] [ALPM] running 'eos-reboot-required.hook'...
[2024-10-12T00:11:10+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-10-12T00:11:11+0000] [ALPM] running 'rebuild-detector.hook'...
[2024-10-12T00:20:52+0000] [ALPM-SCRIPTLET] foreign proton-ge-custom-bin
[2024-10-12T00:20:52+0000] [ALPM-SCRIPTLET] foreign ryzenadj-controller-git
[2024-10-12T00:20:52+0000] [ALPM-SCRIPTLET] foreign unreal-engine
[2024-10-12T00:20:52+0000] [ALPM] running 'update-desktop-database.hook'...
After the update did you run sudo dracut-rebuild
Hmm. Looking at the log it seems this was done implicitly.
dalto
October 12, 2024, 4:57pm
5
This is not likely. The bootloader doesn’t have much control over that.
dalto
October 12, 2024, 5:27pm
6
Looks like it has already been reported and a fix is in progress:
dracut-ng:main
← jozzsi:64
opened 02:04PM - 12 Oct 24 UTC
Follow-up 5551746088633116a28f3ded9d7003f378b6cd17.
## Checklist
- [ ] I hav… e tested it locally
- [ ] I have reviewed and updated any documentation if relevant
- [ ] I am providing new code and test(s) for it
Fixes #709
TomDoe
October 12, 2024, 5:33pm
7
Same problem here on my 2 EOS installations. After update/reboot LUKS passphrase is not recognized because the keyboard-layout is obviously english instead of german (had to replace “z” with “y”).
@dalto
Thanks for sharing this link
So let’s wait for the update
dalto
October 12, 2024, 5:39pm
8
It looks like they need some help testing the fix:
opened 10:22AM - 12 Oct 24 UTC
bug
OS: EndeavourOS
I was struggling to decrypt on startup. After several attempt… s, I checked if the keymap was wrong and it was.
I'm not sure if this is caused by dracut, but it happened after a reboot right after I upgraded from 103-2 to 104.
I have the same issue due to an Azerty keyboard (fr). To input my password, I have to use my keyboard as if it were a Qwerty one.
Phodox
October 13, 2024, 8:24am
10
I encountered this issue after the update today. I entered my correct passphrase 3 times, but it wasn’t accepted, which really shocked me.
Fortunately, I was able to revert to a previous snapshot with Limine to fix the issue and have stopped updating for now.
SdW
October 13, 2024, 11:45am
11
Interesting. I haven’t seen this even though I use dvorak layout (with US english keymap). So it’s the keymap, not the layout, that switched. I also use GRUB, Sway, LTS kernel, if that’s relevant.
dracut 105-1 is out and working fine. Just tested.
rabcor
October 14, 2024, 1:43pm
13
Same here. Updating dracut fixed it.
system
Closed
October 16, 2024, 1:44pm
14
