Please use the </> option when posting. It’s really hard to read a screen shot and it’s even tougher for someone to help you or for someone else who may have the same use to search for it once this is answered.
It’s owned by hwids. . . I just looked at both repos and aur and I don’t see that package at either location. …
@Stagger_Lee mentioned that a few posts ago already. I don’t know if it was replaced and removed, or just replaced in whatever package it was a dependency in. I just wanted to make sure removing it wouldn’t break some other random thing they installed along the way also.
Replacing a dependency won’t cause that message. That only happens when package A is a replacement for package B.
When that happens, repo packages will get their dependencies changed at the same time and get rebuilt if needed. AUR packages end up in catch-22 though. You can’t update them because you don’t yet have the new package. You can’t switch to the new package because the dependency from the AUR package stops you.
The only ways I know of to fix that problem are to temporarily remove the AUR package or tell pacman to ignore the dependencies.
If you look at pacman -Qi in this situation you need to do so with the knowledge that you are looking at the old dependencies, not the new ones. In other words, even if there was 1,000 dependencies on hwids, it isn’t definitely a problem because you are looking at the state of the packages on your system, not in the repos.
While I don’t disagree with anything you said, I didn’t want to advise them to remove the package to install the next to find out some obscure AUR package they do need requires it and hasn’t updated their dependencies. . . That’s all.
I wouldn’t recommend that method for a few reasons
It won’t work in yay because yay evaluates dependencies before the phase where you edit the PKGBUILD
You can’t do it as part of an update because the repo packages are updated first.
That means you need to do that first and it will try to pull in the new package as a dependency. However, if the old package has any repo packages dependent on it, it will still fail.
