Update gives error due to dependacy issue and fails to proceed
HI,
Am new to Endeavor/Arch.
I have some recent experience running Deb/Ubuntu based systems.
I have some smaller experience 2o years old running Red Hat 2.0 (before they became a PAID product).
It’s why I am posting in the newbie forum.
Am a Windows IT Technician/Analyst for approx. 28 years.
Familiar with working at term but certainly no expert or even power user, I have to look up Linux cmds/switches literally all the time when I run Linux.
Some updates were performed when I tried the "Update Native and AUR packages using the Welcome app.
BOTH other update apps crapped out when they hit the dep issue below:
==> eos-update
eos-update: package updater with additional features
Updating native apps…
[sudo] password for yodaminium:
:: Synchronizing package databases…
endeavouros is up to date
core is up to date
extra is up to date
multilib is up to date
:: Starting full system upgrade…
resolving dependencies…
looking for conflicting packages…
:: installing ppp (2.5.2-1) breaks dependency ‘ppp=2.5.1’ required by rp-pppoe
I do not use pppoe (cable internet user)I connect directly to my firewall and that connects directly to the Cable modem. I am sure you’re all familiar.
I simply want to know if I can ignore this dep error or if I should try to omit the ppp 2.5.2-1 update somehow and get the erst of the updates?
I want to get some peace of mind that this update, if ignored, will not somehow break something else I depend on. I can’t see how that can be but better to ask and not have to reinstall or recover a broken OS.
TYVM ahead of time to the community.
I have frequent these forums on occasion even while running other, non-arch distros and this fourm is a literal gold mine of Linux info-thanks again!
John
You should be very cautious of ignoring an update to a package and updating the rest of the system.
That means that those two packages are out of alignment which is odd. Try resorting your mirrors and see if it works after that.
Thank you very much for the FAST response.
I did run all three update mirror routines from the welcome app first. Then, ran all three update packages routine.
and they all returned dep error with the yay app returning:
==> yay
core is up to date
extra is up to date
:: Searching AUR for updates…
:: Searching databases for updates…
→ Packages not in AUR: argon2
:: 64 packages to upgrade/install.
64 endeavouros/downgrade 11.4.2-1 → 11.4.3-1
63 endeavouros/endeavouros-mirrorlist 24.10-1 → 25.1-1
62 endeavouros/eos-bash-shared 24.16.25-1 → 25.1.3-1
61 endeavouros/eos-log-tool 24.8.1-1 → 24.12-1
60 endeavouros/eos-packagelist 2.3.1-1 → 2.3.1-2
59 endeavouros/eos-qogir-icons 5-1 → 6-1
58 endeavouros/eos-rankmirrors 24.9.2-1 → 25-1
57 endeavouros/eos-translations 24.12.4-1 → 24.12.5-1
56 endeavouros/kernel-install-for-dracut 1.10.1-1 → 1.11-1
55 endeavouros/nvidia-inst 24.10.2-2 → 25-1
54 endeavouros/welcome 24.12.4-1 → 24.12.7-1
53 core/audit 4.0.2-2 → 4.0.3-1
52 core/binutils 2.43+r4+g7999dae6961-1 → 2.43_1+r171+g01da089627be-1
51 core/brotli 1.1.0-2 → 1.1.0-3
50 core/btrfs-progs 6.12-1 → 6.12-2
49 core/cracklib 2.10.2-1 → 2.10.3-1
48 core/cryptsetup 2.7.5-1 → 2.7.5-2
47 core/curl 8.11.0-3 → 8.11.1-3
46 core/dbus 1.14.10-2 → 1.16.0-1
45 core/device-mapper 2.03.28-1 → 2.03.30-1
44 core/e2fsprogs 1.47.1-4 → 1.47.2-1
43 core/fakeroot 1.36-1 → 1.36.2-1
42 core/file 5.46-2 → 5.46-3
41 core/gcc 14.2.1+r134+gab884fffe3fc-1 → 14.2.1+r134+gab884fffe3fc-2
40 core/gcc-libs 14.2.1+r134+gab884fffe3fc-1 → 14.2.1+r134+gab884fffe3fc-2
39 core/gettext 0.22.5-2 → 0.23.1-2
38 core/glib2 2.82.3-3 → 2.82.4-2
37 core/gpgme 1.24.1-1 → 1.24.1-3
36 core/hwdata 0.390-1 → 0.391-1
35 core/icu 75.1-1 → 75.1-2
34 core/kbd 2.7-1 → 2.7.1-1
33 core/libcap-ng 0.8.5-2 → 0.8.5-3
32 core/libedit 20240517_3.1-1 → 20240808_3.1-1
31 core/libnghttp3 1.6.0-1 → 1.7.0-1
30 core/libseccomp 2.5.5-3 → 2.5.5-4
29 core/libssh2 1.11.0-1 → 1.11.1-1
28 core/libunistring 1.2-1 → 1.3-1
27 core/libxcrypt 4.4.36-2 → 4.4.38-1
26 core/libxml2 2.13.5-1 → 2.13.5-2
25 core/linux 6.12.4.arch1-1 → 6.12.9.arch1-1
24 core/linux-firmware 20241210.b00a7f7e-1 → 20250109.7673dffd-1
23 core/linux-firmware-marvell 20241210.b00a7f7e-1 → 20250109.7673dffd-1
22 core/linux-firmware-whence 20241210.b00a7f7e-1 → 20250109.7673dffd-1
21 core/linux-headers 6.12.4.arch1-1 → 6.12.9.arch1-1
20 core/lvm2 2.03.28-1 → 2.03.30-1
19 core/mdadm 4.3-2 → 4.4-1
18 core/nano 8.2-1 → 8.3-1
17 core/nettle 3.10-1 → 3.10.1-1
16 core/nfs-utils 2.8.1-1 → 2.8.2-2
15 core/nfsidmap 2.8.1-1 → 2.8.2-2
14 core/pacman-mirrorlist 20240717-1 → 20250101-1
13 core/ppp 2.5.1-1 → 2.5.2-1
12 core/procps-ng 4.0.4-3 → 4.0.5-1
11 core/python 3.12.7-1 → 3.13.1-1
10 core/python-capng 0.8.5-2 → 0.8.5-3
9 core/rpcbind 1.2.7-1 → 1.2.7-2
8 core/sqlite 3.47.2-1 → 3.48.0-2
7 core/sudo 1.9.16.p2-1 → 1.9.16.p2-2
6 core/systemd 256.9-1 → 257.2-2
5 core/systemd-libs 256.9-1 → 257.2-2
4 core/systemd-resolvconf 256.9-1 → 257.2-2
3 core/systemd-sysvcompat 256.9-1 → 257.2-2
2 core/util-linux 2.40.2-1 → 2.40.4-1
1 core/util-linux-libs 2.40.2-1 → 2.40.4-1
==> Packages to exclude: (eg: “1 2 3”, “1-3”, “^4” or repo name)
→ Excluding packages may cause partial upgrades and break systems
I thught that yay had updated some but not others but it seems like it has failed to update anything also. I understand this is by design and for the best. TYVM.
Last quetsion: Do dep issues usually clear up on their own within a certain amount of time or is this it…I am stuck with the packages I have until I fix something?
Try opening /etc/pacman.d/mirrorlist and commenting out the first mirror on the list and then run sudo pacman -Syu
Most dependency issues are caused by AUR packages or 3rd party repos and in these cases you often need to take an action to resolve it.
However, that is not the case here. This seems more like a mirror issue where the mirror you are connected to is not updated. It is possible that waiting would resolve the issue but I would switch to a different mirror and see if that fixes it.
OK. TYVM.
You are/were correct.
I was updating 3x and THEN running all three update apps.
What I did this time was I only updated the Update Mirrors (Arch, reflector simple)’
and then I ran the Update native packages and it is installing updates as I type this.
However, before I ended typing I see this on the update routine: now I am terrified to reboot :slight_smile: BUT, I still have 2 more package updaters to run and I will do that now.
==> eos-update
core is up to date
extra 7.5 MiB 1587 KiB/s 00:05 [------------------------------------] 100%
warning: dependency cycle detected:
warning: egl-x11 will be installed before its mesa dependency
warning: nvidia-utils will be installed before its mesa dependency
warning: xdg-desktop-portal-kde will be installed before its plasma-workspace dependency
warning: libcamera-ipa will be installed before its libcamera dependency
warning: insufficient columns available for table display
Packages (395) ark-24.12.1-1 at-spi2-core-2.54.1-1 attica-6.10.0-1 audit-4.0.3-1
avahi-1:0.8+r194+g3f79789-3 baloo-6.10.0-1 baloo-widgets-24.12.1-1 bash-completion-2.16.0-1
bind-9.20.4-2 binutils-2.43_1+r171+g01da089627be-1 blas-3.12.1-2 bleachbit-4.6.2-2
bluedevil-1:6.2.5-1 bluez-qt-6.10.0-1 boost-libs-1.86.0-6 breeze-6.2.5-1
breeze-gtk-6.2.5-1 breeze-icons-6.10.0-1 brotli-1.1.0-3 btrfs-progs-6.12-2 cblas-3.12.1-2
chromium-132.0.6834.83-1 clang-19.1.6-1 compiler-rt-19.1.6-1 cracklib-2.10.3-1
cryptsetup-2.7.5-2 curl-8.11.1-3 dbus-1.16.0-1 device-mapper-2.03.30-1 discord-0.0.80-1
dkms-3.1.4-1 dnsmasq-2.90-2 dolphin-24.12.1-1 dolphin-plugins-24.12.1-1 downgrade-11.4.3-1
doxygen-1.13.2-1 e2fsprogs-1.47.2-1 egl-wayland-4:1.1.17-1 egl-x11-1.0.0-1
endeavouros-mirrorlist-25.1-1 eos-bash-shared-25.1.3-1 eos-log-tool-24.12-1
eos-packagelist-2.3.1-2 eos-qogir-icons-6-1 eos-rankmirrors-25-1 eos-translations-24.12.5-1
fakeroot-1.36.2-1 ffmpeg-2:7.1-5 ffmpeg4.4-4.4.5-2 ffmpegthumbs-24.12.1-1 file-5.46-3
firefox-134.0.1-1 firewalld-2.3.0-2 flashrom-1.5.1-1 fluidsynth-2.4.2-1 fmt-11.1.2-1
frameworkintegration-6.10.0-1 fwupd-2.0.3-2 fzf-0.57.0-1 gcc-14.2.1+r134+gab884fffe3fc-2
gcc-libs-14.2.1+r134+gab884fffe3fc-2 gegl-0.4.52-1 gettext-0.23.1-2 git-2.48.1-1
glances-4.3.0.8-2 glib-networking-1:2.80.1-1 glib2-2.82.4-2 gnulib-l10n-20241231-1
gobject-introspection-runtime-1.82.0-2 gpgme-1.24.1-3 gst-libav-1.24.11-2
gst-plugins-bad-1.24.11-2 gst-plugins-bad-libs-1.24.11-2 gst-plugins-base-1.24.11-2
gst-plugins-base-libs-1.24.11-2 gst-plugins-ugly-1.24.11-2 gstreamer-1.24.11-2
gtk-update-icon-cache-1:4.16.12-1 gtk4-1:4.16.12-1 gwenview-24.12.1-1 harfbuzz-10.2.0-1
harfbuzz-icu-10.2.0-1 haruna-1.3.0-1 hwdata-0.391-1 i2c-tools-4.4-2 icu-75.1-2
imagemagick-7.1.1.43-1 imath-3.1.12-2 inxi-3.3.37.1-1 iwd-3.3-1 jemalloc-1:5.3.0-5
kaccounts-integration-24.12.1-1 kactivitymanagerd-6.2.5-1 karchive-6.10.0-1 kate-24.12.1-1
kauth-6.10.0-1 kbd-2.7.1-1 kbookmarks-6.10.0-1 kcalc-24.12.1-1 kcmutils-6.10.0-1
kcodecs-6.10.0-1 kcolorscheme-6.10.0-1 kcompletion-6.10.0-1 kconfig-6.10.0-1
kconfigwidgets-6.10.0-1 kcontacts-1:6.10.0-1 kcoreaddons-6.10.0-1 kcrash-6.10.0-1
kdbusaddons-6.10.0-1 kde-cli-tools-6.2.5-1 kde-gtk-config-6.2.5-1 kdeclarative-6.10.0-1
kdeconnect-24.12.1-1 kdecoration-6.2.5-1 kded-6.10.0-1 kdegraphics-mobipocket-24.12.1-1
kdegraphics-thumbnailers-24.12.1-1 kdenetwork-filesharing-24.12.1-1 kdeplasma-addons-6.2.5-1
kdesu-6.10.0-1 kdnssd-6.10.0-1 kernel-install-for-dracut-1.11-1 kfilemetadata-6.10.0-1
kgamma-6.2.5-1 kglobalaccel-6.10.0-1 kglobalacceld-6.2.5-1 kguiaddons-6.10.0-1
kholidays-1:6.10.0-1 ki18n-6.10.0-1 kiconthemes-6.10.0-1 kidletime-6.10.0-1
kimageformats-6.10.0-1 kinfocenter-6.2.5-1 kio-6.10.0-1 kio-admin-24.12.1-1
kio-extras-24.12.1-1 kirigami-6.10.0-1 kirigami-addons-1.7.0-1 kitemmodels-6.10.0-1
kitemviews-6.10.0-1 kjobwidgets-6.10.0-1 kmenuedit-6.2.5-1 knewstuff-6.10.0-1
knotifications-6.10.0-1 knotifyconfig-6.10.0-1 konsole-24.12.1-1 kpackage-6.10.0-1
kparts-6.10.0-1 kpeople-6.10.0-1 kpipewire-6.2.5-1 kpmcore-24.12.1-1 kpty-6.10.0-1
kquickcharts-6.10.0-1 krunner-6.10.0-1 kscreen-6.2.5-1 kscreenlocker-6.2.5-1
kservice-6.10.0-1 kstatusnotifieritem-6.10.0-1 ksvg-6.10.0-1 ksystemstats-6.2.5-1
ktexteditor-6.10.0-1 ktextwidgets-6.10.0-1 kunitconversion-6.10.0-1 kuserfeedback-6.10.0-1
kwallet-6.10.0-1 kwallet-pam-6.2.5-1 kwayland-6.2.5-1 kwayland-integration-6.2.5-1
kwidgetsaddons-6.10.0-1 kwin-6.2.5-1 kwindowsystem-6.10.0-1 kxmlgui-6.10.0-1
lapack-3.12.1-2 layer-shell-qt-6.2.5-1 ldb-2:4.21.3-1 lensfun-1:0.3.4-5
libblockdev-3.2.1-3 libblockdev-crypto-3.2.1-3 libblockdev-fs-3.2.1-3
libblockdev-loop-3.2.1-3 libblockdev-mdraid-3.2.1-3 libblockdev-nvme-3.2.1-3
libblockdev-part-3.2.1-3 libblockdev-swap-3.2.1-3 libbytesize-2.11-1 libcamera-0.3.2-2
libcamera-ipa-0.3.2-2 libcap-ng-0.8.5-3 libcdio-2.2.0-1 libcups-2:2.4.11-2
libdeflate-1.23-1 libedit-20240808_3.1-1 libftdi-1.5-7 libgexiv2-0.14.3-2
libgirepository-1.82.0-2 libice-1.1.2-1 libimobiledevice-1.3.0-15 libinput-1.27.1-1
libixion-0.19.0-6 libjpeg-turbo-3.1.0-1 libkdcraw-24.12.1-1 libkexiv2-24.12.1-1
libkscreen-6.2.5-1 libksysguard-6.2.5-1 libmaxminddb-1.12.2-1 libnewt-0.52.24-3
libnghttp3-1.7.0-1 libnm-1.50.1-2 libnvme-1.11.1-2 libopenmpt-0.7.13-1 liborcus-0.19.2-4
libplasma-6.2.5-1 libplist-2.6.0-2 libpng-1.6.45-1 libpwquality-1.4.5-6
libqalculate-5.5.0-1 libreoffice-fresh-24.8.4-2 libseccomp-2.5.5-4 libsixel-1.10.3-7
libsm-1.2.5-1 libsoup3-3.6.4-1 libssh2-1.11.1-1 libtorrent-rasterbar-1:2.0.10-4
libunistring-1.3-1 libupnp-1.14.20-2 liburcu-0.15.0-1 libuv-1.50.0-1 libvlc-3.0.21-11
libvpl-2.14.0-1 libvpx-1.15.0-1 libwbclient-2:4.21.3-1 libwebp-1.5.0-1 libxau-1.0.12-1
libxcrypt-4.4.38-1 libxcvt-0.1.3-1 libxml2-2.13.5-2 libxrender-0.9.12-1
libxshmfence-1.3.3-1 libxslt-1.1.42-2 libxv-1.0.13-1 libxxf86vm-1.1.6-1 lilv-0.24.24-3
linux-6.12.9.arch1-1 linux-firmware-20250109.7673dffd-1
linux-firmware-marvell-20250109.7673dffd-1 linux-firmware-whence-20250109.7673dffd-1
linux-headers-6.12.9.arch1-1 llvm-libs-19.1.6-3 lsb-release-2.0.r55.a25a4fc-1
lvm2-2.03.30-1 maliit-keyboard-2.3.1-4 mdadm-4.4-1 meld-3.22.3-1 memtest86±7.20-2
mesa-1:24.3.3-2 milou-6.2.5-1 modemmanager-qt-6.10.0-1 mpg123-1.32.10-1 nano-8.3-1
nbd-3.26.1-2 nettle-3.10.1-1 networkmanager-1.50.1-2 networkmanager-qt-6.10.0-1
nfs-utils-2.8.2-2 nfsidmap-2.8.2-2 nftables-1:1.1.1-2 noto-fonts-1:2025.01.01-1
noto-fonts-extra-1:2025.01.01-1 nvidia-565.77-11 nvidia-inst-25-1 nvidia-utils-565.77-3
ocean-sound-theme-6.2.5-1 okular-24.12.1-1 onetbb-2022.0.0-2 openal-1.24.2-1
openconnect-1:9.12-3 opencv-4.11.0-1 openjpeg2-2.5.3-1 openvpn-2.6.13-1 openxr-1.1.43-1
pacman-mirrorlist-20250101-1 pahole-1:1.28-3 parallel-20241222-1 partitionmanager-24.12.1-1
pcsclite-2.3.1-1 perl-http-message-7.00-1 perl-mailtools-2.22-1 perl-uri-5.31-1
plasma-activities-6.2.5-1 plasma-activities-stats-6.2.5-1 plasma-browser-integration-6.2.5-1
plasma-desktop-6.2.5-1 plasma-disks-6.2.5-1 plasma-firewall-6.2.5-1
plasma-integration-6.2.5-1 plasma-nm-6.2.5-1 plasma-pa-6.2.5-1 plasma-systemmonitor-6.2.5-1
plasma-workspace-6.2.5-1 plasma5support-6.2.5-1 polkit-126-2 polkit-kde-agent-6.2.5-1
poppler-25.01.0-1 poppler-glib-25.01.0-1 poppler-qt6-25.01.0-1 powerdevil-6.2.5-1
ppp-2.5.2-1 print-manager-1:6.2.5-1 prison-6.10.0-1 procps-ng-4.0.5-1 protobuf-29.2-1
protobuf-c-1.5.0-10 pulseaudio-qt-1.7.0-1 purpose-6.10.0-1 pv-1.9.27-1 pybind11-2.13.6-2
python-3.13.1-1 python-annotated-types-0.7.0-2 python-cairo-1.27.0-2 python-capng-0.8.5-3
python-colorama-0.4.6-5 python-dbus-1.3.2-5 python-defusedxml-0.7.1-7
python-gobject-3.50.0-2 python-orjson-3.10.14-1 python-packaging-24.2-3
python-psutil-6.1.1-1 python-pyaml-24.9.0-2 python-pydantic-2.10.4-1
python-pydantic-core-1:2.27.2-1 python-pyqt5-5.15.11-2 python-pyqt5-sip-12.16.1-2
python-shtab-1.7.1-3 python-termcolor-2.5.0-1 python-typing_extensions-4.12.2-3
python-yaml-6.0.2-2 qbittorrent-5.0.3-1 qqc2-breeze-style-6.2.5-1
qqc2-desktop-style-6.10.0-1 qt6-declarative-6.8.1-3 qt6-tools-6.8.1-2 qt6-webengine-6.8.1-2
rebuild-detector-4.4.5-1 reflector-2023-3 ripgrep-all-0.10.6-3 rp-pppoe-4.0-4
rpcbind-1.2.7-2 rsync-3.4.1-1 samba-2:4.21.3-1 screen-5.0.0-2 sddm-0.21.0-6
sddm-kcm-6.2.5-1 sdl2-2.30.11-1 signon-kwallet-extension-24.12.1-1 smbclient-2:4.21.3-1
socat-1.8.0.2-1 solid-6.10.0-1 sonnet-6.10.0-1 spdlog-1.15.0-2 spectacle-24.12.1-1
sqlite-3.48.0-2 sudo-1.9.16.p2-2 svt-av1-2.3.0-1 syndication-6.10.0-1
syntax-highlighting-6.10.0-1 systemd-257.2-2 systemd-libs-257.2-2
systemd-resolvconf-257.2-2 systemd-sysvcompat-257.2-2 systemsettings-6.2.5-1 talloc-2.4.2-4
tcl-8.6.16-1 tdb-1.4.12-2 tevent-1:0.16.1-4 threadweaver-6.10.0-1 tinysparql-3.8.2-2
tldr-3.3.0-2 ttf-opensans-1.101-5 upower-1.90.7-1 util-linux-2.40.4-1
util-linux-libs-2.40.4-1 v4l-utils-1.28.1-2 vapoursynth-R70-2 vlc-3.0.21-11
volume_key-0.3.12-10 webkit2gtk-4.1-2.46.5-1 welcome-24.12.7-1 xcb-proto-1.17.0-3
xdg-desktop-portal-kde-6.2.5-1 xorg-server-21.1.15-1 xorg-server-common-21.1.15-1
xorg-xinit-1.4.3-1 xxhash-0.8.3-1 zbar-0.23.93-4 zxing-cpp-2.3.0-4
Total Download Size: 2166.40 MiB
Total Installed Size: 6397.52 MiB
Net Upgrade Size: 16.15 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages…
chromium-132.0.6834.83-1-x86_64 99.3 MiB 1596 KiB/s 01:04 [------------------------------------] 100%
linux-6.12.9.arch1-1-x86_64 137.7 MiB 1694 KiB/s 01:23 [------------------------------------] 100%
libreoffice-fresh-24.8.4-2-x86_64 143.3 MiB 1729 KiB/s 01:25 [------------------------------------] 100%
nvidia-utils-565.77-3-x86_64 241.3 MiB 1930 KiB/s 02:08 [------------------------------------] 100%
qt6-webengine-6.8.1-2-x86_64 81.5 MiB 2.18 MiB/s 00:37 [------------------------------------] 100%
linux-firmware-20250109.7673dffd… 258.6 MiB 1953 KiB/s 02:16 [------------------------------------] 100%
breeze-6.2.5-1-x86_64 88.5 MiB 1397 KiB/s 01:05 [------------------------------------] 100%
firefox-134.0.1-1-x86_64 72.1 MiB 4.30 MiB/s 00:17 [------------------------------------] 100%
discord-0.0.80-1-x86_64 60.1 MiB 7.10 MiB/s 00:08 [------------------------------------] 100%
Total ( 9/395) 2.1 GiB 13.8 MiB/s 02:37 [------------------------------------] 100%
error: failed retrieving file ‘nvidia-utils-565.77-3-x86_64.pkg.tar.zst.sig’ from mirror.ufscar.br : Connection timed out after 10000 milliseconds
error: failed retrieving file ‘linux-firmware-20250109.7673dffd-1-any.pkg.tar.zst.sig’ from mirror.ufscar.br : SSL connection timeout
error: failed retrieving file ‘discord-0.0.80-1-x86_64.pkg.tar.zst’ from mirror.ufscar.br : OpenSSL SSL_read: SSL_ERROR_SYSCALL, errno 0
warning: too many errors from mirror.ufscar.br, skipping for the remainder of this transaction
warning: failed to retrieve some files
error: failed to commit transaction (unexpected error)
Press ENTER to close this window: ^C
Warning: Program ‘/home/yodaminium/.cache/eos_yad_RunCmdTermBashOpt.Y9qrl’ crashed.Preformatted text
@Yodaminium When posting terminal output or code, please use the “Preformatted Text” option.
Your output above would be easier to digest. It would look like this:
==> eos-update
core is up to date
Keep in mind, there are a bunch of options there. You don’t have to run all of them every time.
If you did an offline install, it is normal to see a huge amount of updates the first time.
You need to let it proceed though. It looks like you cancelled out of it.
OK I have run the second updater and have 2 concerns: numbered to make it easy to search through the garbage.
Number 1. This is at the very end of the second update routine–it is waiting for me to type something and I am unsure if it should be quit or continue or yes or OK, etc,etc.
29/29) Updating the vlc plugin cache…
:: 6 dependencies will also be installed for this operation.
extra/python-build → 1.2.2-3
(make dependency of python-future)
extra/python-installer → 0.7.0-10
extra/python-pytest → 1:8.3.4-1
extra/python-requests → 2.32.3-4
extra/python-setuptools → 1:75.2.0-4
extra/python-wheel → 0.45.0-3
:: 1 package to upgrade/install.
1 aur/python-future 1.0.0-1 → 1.0.0-4
AUR Dependency (1): python-future-1.0.0-4
Sync Check Dependency (2): python-requests-2.32.3-4, python-pytest-1:8.3.4-1
Sync Make Dependency (4): python-setuptools-1:75.2.0-4, python-wheel-0.45.0-3, python-build-1.2.2-3, python-installer-0.7.0-10
:: (1/1) Downloaded PKGBUILD: python-future
1 python-future (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> A
:: Deleting (1/1): /home/yodaminium/.cache/yay/python-future
HEAD is now at fcd4ac2 uncomment checkdeps
==> Diffs to show?
==> A
diff --git /home/yodaminium/.cache/yay/python-future/.nvchecker.toml /home/yodaminium/.cache/yay/python-future/.nvchecker.toml
new file mode 100644
index 0000000…399c8bd
— /dev/null
+++ /home/yodaminium/.cache/yay/python-future/.nvchecker.toml
@@ -0,0 +1,3 @@
+[python-future]
+source = “pypi”
+pypi = “future”
diff --git /home/yodaminium/.cache/yay/python-future/PKGBUILD /home/yodaminium/.cache/yay/python-future/PKGBUILD
index 0000000…9a65199
— /dev/null
+++ /home/yodaminium/.cache/yay/python-future/PKGBUILD
@@ -0,0 +1,42 @@
+# Contributor: Michał Wojdyła < micwoj9292 at gmail dot com >
+# Contributor: Felix Yan felixonmars@archlinux.org
+# Contributor: Christopher Arndt <aur -at- chrisarndt -dot- de>
+# Contributor: Gaute Hope eg@gaute.vetsj.com
+# Contributor: Melissa Padilla
+pkgname=python-future
+pkgver=1.0.0
+pkgrel=4
+pkgdesc=“Clean single-source support for Python 3 and 2”
+url=“https://python-future.org/
+arch=(‘any’)
+license=(‘MIT’)
+depends=(‘python’)
+provides=(‘futurize’ ‘pasteurize’)
+checkdepends=(‘python-requests’ ‘python-pytest’)
+makedepends=(‘python-build’ ‘python-installer’ ‘python-setuptools’ ‘python-wheel’)
+optdepends=(‘python-setuptools: futurize and pasteurize scripts’)
+options=(‘!emptydirs’)
+source=(“https://pypi.io/packages/source/f/future/future-$pkgver.tar.gz”)
Number 2.
This concerns me but I am not sure if I should be concerned or not?
racut[I]: *** Creating image file ‘/efi/a8327be0fb0142a8b10883f1d907fcd2/6.12.9-arch1-1/initrd’ ***
dracut[I]: *** Creating initramfs image file ‘/efi/a8327be0fb0142a8b10883f1d907fcd2/6.12.9-arch1-1/initrd’ done ***
error: unable to write to pipe (Broken pipe)
(15/29) Reloading system bus configuration…
(16/29) Warn about old perl modules
(17/29) Add EndeavourOS specific config.
(18/29) Hook to rank EndeavourOS mirrors after installing or upgrading the related mirrorlist package
→ configuration set to rank mirrors
==> eos-rankmirrors: info: extracting /var/cache/pacman/pkg/endeavouros-mirrorlist-25.1-1-any.pkg.tar.zst …
==> eos-rankmirrors: info: ranking EndeavourOS mirrors, please wait …
==> Info: Results of ranking EndeavourOS mirrors:
Once again. TY for all your help.
I am m aking a note of everything you say so as to reimnd myself next time I run these updates. I’m an old guy and my memory has more lapses than I care to admit :slight_smile:
You should press q. However, in this case, you don’t need that package. So remove it before you update.
sudo pacman -R python-future
That is a nuisance error, you can ignore it.
Awesome sauce! -tyvm for that tip.
I hope I remember to use it :slight_smile:
I also do not being reminded and I can always copy what I posted and re-post it if necessary.
Hi Dalto,
TY for your response.
I don’t think I cancelled out of it, but is a possibility if I thought it would break the system.
