Fresh reinstall it is!
What commands should I use first with reflector?
OK, I just took a look.
After pudgeās commands from above you are left without eos keys so try this:
sudo pacman -S endeavouros-keyring
Then update only your repo packages with:
sudo pacman -Syu
If that doesnāt work, post the current output from pacman -Syu even if it looks the same to you.
Here you go. Think Iāll try the reflector option next once I know what commands to use.
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman -S endeavouros-keyring
[sudo] password for oneshinyboi:
warning: endeavouros-keyring-20220614-1 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change
endeavouros/endeavouros-keyring 20220614-1 20220614-1 0.00 MiB
Total Installed Size: 0.01 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [--------------------------------] 100%
downloading required keys...
:: Import PGP key 003DB8B0CB23504F, "EndeavourOS <info@endeavouros.com>"? [Y/n] y
error: key "003DB8B0CB23504F" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
I donāt see anything to indicate a mirror problem here.
What is the output of sudo pacman-key --populate endeavouros ?
I believe @anon11595408 was the one who mentioned that there could be a mirror issue and recommended reflect. Hereās the output you asked for.
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman-key --populate endeavouros
==> Appending keys from endeavouros.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 7 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 13 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 13 signed: 95 trust: 0-, 0q, 0n, 13m, 0f, 0u
gpg: depth: 2 valid: 75 signed: 26 trust: 75-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-04-21
Does this work better now:
sudo pacman -Syu
Well I donāt know if I would use the word ābetterā but itās giving a different error message now which could be good?
EDIT: Is this a case where it would be good to use overwrite perhaps?
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman -Syu
endeavouros is up to date
core is up to date
extra 1743.3 KiB 351 KiB/s 00:05 [--------------------------------] 100%
community 7.2 MiB 1232 KiB/s 00:06 [--------------------------------] 100%
multilib 165.6 KiB 71.7 KiB/s 00:02 [--------------------------------] 100%
:: Replace yad-eos with endeavouros/yad? [Y/n] y
warning: dependency cycle detected:
warning: mesa will be installed before its libglvnd dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: insufficient columns available for table display
Packages (442) a52dec-0.7.4-12 aalib-1.4rc5-15 alsa-card-profiles-1:0.3.64-1
amd-ucode-20221214.f3c283e-1 arc-gtk-theme-eos-20221218-1 audit-3.0.9-1
bind-9.18.10-1 binutils-2.40-1 btrfs-progs-6.1.2-1 ca-certificates-mozilla-3.87-1
chromaprint-1.5.1-6 cifs-utils-7.0-2 clang-15.0.7-1 clucene-2.3.3.4-13
code-1.74.3-1 compiler-rt-15.0.7-1 curl-7.87.0-3 cython-0.29.33-1 db-6.2.32-1
db5.3-5.3.28-2 default-cursors-2-1 device-mapper-2.03.18-1
dialog-1:1.3_20221229-1 djvulibre-3.5.28-4 dnsmasq-2.88-1
dotnet-host-7.0.2.sdk102-1 dotnet-runtime-7.0.2.sdk102-1
dotnet-runtime-6.0-6.0.13.sdk113-1 duktape-2.7.0-5 electron19-19.1.9-3
elementary-icon-theme-7.1.0-1 ell-0.55-1 endeavouros-mirrorlist-4.11-1
endeavouros-skel-default-1.8-1 endeavouros-skel-xfce4-3.3-1
endeavouros-theming-22.12.1.1-1 endeavouros-xfce4-terminal-colors-5-1
eos-apps-info-1.5-1 eos-bash-shared-1.41-1 eos-hooks-1.10-1
eos-lightdm-slick-theme-3.2-1 eos-log-tool-1.14-4 eos-packagelist-2.1-1
eos-quickstart-1.3.1-1 eos-translations-23-4 ethtool-1:6.1-1 exo-4.18.0-1
file-5.44-1 firefox-109.0-1 firewalld-1.3.0-1 fluidsynth-2.3.1-1 fmt-9.1.0-4
fuse-common-3.13.0-1 fuse3-3.13.0-1 garcon-4.18.0-1 gcc-12.2.1-1
gcc-libs-12.2.1-1 gd-2.3.3-6 gdk-pixbuf2-2.42.10-2 gegl-0.4.40-4
ghostscript-10.0.0-4 gimp-2.10.32-3 git-2.39.1-1 glib2-2.74.4-1 glibc-2.36-7
glslang-11.13.0-2 gnome-boxes-43.2-1 gnu-netcat-0.7.1-9 go-2:1.19.5-1
gpgme-1.18.0-2 graphviz-7.0.6-1 grub-2:2.06.r415.g1a241e050-1 grub-btrfs-4.12-2
gst-libav-1.20.5-5 gst-plugin-pipewire-1:0.3.64-1 gst-plugins-bad-1.20.5-5
gst-plugins-bad-libs-1.20.5-5 gst-plugins-base-1.20.5-5
gst-plugins-base-libs-1.20.5-5 gst-plugins-good-1.20.5-5 gst-plugins-ugly-1.20.5-5
gstreamer-1.20.5-5 gtk-update-icon-cache-1:4.8.3-3 gtk3-1:3.24.36-1
gupnp-1:1.6.3-1 gvfs-1.50.3-1 gvfs-afc-1.50.3-1 gvfs-gphoto2-1.50.3-1
gvfs-mtp-1.50.3-1 gvfs-nfs-1.50.3-1 gvfs-smb-1.50.3-1 harfbuzz-6.0.0-1
harfbuzz-icu-6.0.0-1 hidapi-0.13.1-1 http-parser-2.9.4-1 hunspell-1.7.2-1
hwdata-0.366-1 hwdetect-2023.01-1 hwinfo-22.2-1 iana-etc-20221215-1
imagemagick-7.1.0.57-2 imlib2-1.10.0-2 inxi-3.3.24.1-4 iproute2-6.1.0-3
iwd-2.1-1 jasper-4.0.0-1 kaccounts-integration-22.12.1-1 kactivities-5.102.0-1
karchive-5.102.0-1 kauth-5.102.0-1 kbookmarks-5.102.0-1 kcmutils-5.102.0-1
kcodecs-5.102.0-1 kcompletion-5.102.0-1 kconfig-5.102.0-1
kconfigwidgets-5.102.0-1 kcoreaddons-5.102.0-1 kcrash-5.102.0-1
kdbusaddons-5.102.0-1 kdeclarative-5.102.0-1 kded-5.102.0-1
kglobalaccel-5.102.0-1 kguiaddons-5.102.0-1 ki18n-5.102.0-1 kiconthemes-5.102.0-1
kio-5.102.0-1 kirigami2-5.102.0-1 kitemviews-5.102.0-1 kjobwidgets-5.102.0-1
kjs-5.102.0-1 knotifications-5.102.0-1 kpackage-5.102.0-1 kparts-5.102.0-1
kpty-5.102.0-1 krb5-1.20.1-1 kservice-5.102.0-1 ktextwidgets-5.102.0-1
kwallet-5.102.0-1 kwayland-5.102.0-1 kwidgetsaddons-5.102.0-1
kwindowsystem-5.102.0-1 kxmlgui-5.102.0-1 lcms2-2.14-2 lib32-curl-7.87.0-1
lib32-gcc-libs-12.2.1-1 lib32-glibc-2.36-7 lib32-krb5-1.20.1-1
lib32-libglvnd-1.6.0-1 lib32-libtirpc-1.3.3-2 lib32-libx11-1.8.3-1
lib32-libxau-1.0.11-1 lib32-libxdamage-1.1.6-1 lib32-libxdmcp-1.1.4-1
lib32-libxshmfence-1.3.2-1 lib32-llvm-libs-15.0.7-1 lib32-mesa-22.3.3-3
lib32-ncurses-6.4-1 lib32-nss-3.87-1 lib32-sqlite-3.40.1-1 lib32-systemd-252.4-1
lib32-vulkan-mesa-layers-22.3.3-3 lib32-vulkan-radeon-22.3.3-3 lib32-xz-5.4.1-1
libarchive-3.6.2-2 libass-0.17.0-1 libbluray-1.3.4-1 libcamera-0.0.3-3
libcddb-1.3.2-7 libelf-0.188-2 libetonyek-0.1.10-3 libfontenc-1.1.7-1
libgit2-1:1.5.0-2 libglvnd-1.6.0-1 libgusb-0.4.3-1 libheif-1.14.2-1
libical-3.0.16-4 libice-1.1.1-1 libiec61883-1.2.0-7 libinput-1.22.1-1
libkexiv2-22.12.1-1 libkeybinder3-0.3.2-4 libksba-1.6.3-1 liblc3-1.0.1-1
libmfx-22.6.4-1 libmm-glib-1.20.4-1 libmodplug-0.8.9.0-5 libmpc-1.3.1-1
libnice-0.1.21-1 libnm-1.40.10-1 libnma-1.10.6-1 libnma-common-1.10.6-1
libomxil-bellagio-0.9.3-4 libopenmpt-0.6.7-1 libopenraw-0.3.3-1 libpcap-1.10.3-1
libplacebo-5.229.1-2 libproxy-0.4.18-2 libpsl-0.21.2-1 libraqm-0.10.0-1
libraw-0.21.1-1 libreoffice-still-7.3.7-2 librevenge-0.0.5-2 libsigc++-2.12.0-1
libsm-1.2.4-1 libsndfile-1.2.0-1 libsoxr-0.1.3-3 libspectre-0.2.12-1
libsysprof-capture-3.46.0-3 libtiff-4.5.0-1 libtool-2.4.7+4+g1ec8fa28-1
libva-2.17.0-1 libvirt-1:8.10.0-1 libwbclient-4.17.4-4 libwebp-1.3.0-2
libwireplumber-0.4.13-1 libwmf-0.2.12-3 libx11-1.8.3-5 libxau-1.0.11-1
libxcomposite-0.4.6-1 libxdamage-1.1.6-1 libxfce4ui-4.18.1-1
libxfce4util-4.18.1-1 libxkbcommon-1.5.0-1 libxkbcommon-x11-1.5.0-1
libxkbfile-1.1.2-1 libxpm-3.5.15-1 libxres-1.2.2-1 libxshmfence-1.3.2-1
libxv-1.0.12-1 linux-6.1.6.arch1-3 linux-atm-2.5.2-8
linux-firmware-20221214.f3c283e-1 linux-firmware-whence-20221214.f3c283e-1
linux-hardened-6.1.6.hardened2-2 linux-headers-6.1.6.arch1-3
linux-zen-6.1.6.zen1-2 linux-zen-headers-6.1.6.zen1-2 llvm-libs-15.0.7-1
logrotate-3.21.0-2 lsof-4.96.5-1 lua-5.4.4-3 luajit-2.1.0.beta3.r467.gd0e88930-1
lvm2-2.03.18-1 make-4.4-1 man-db-2.11.2-1 man-pages-6.02-1 mbedtls-2.28.2-1
mesa-22.3.3-3 mkinitcpio-34-2 mobile-broadband-provider-info-20221107-2
modemmanager-1.20.4-1 mpfr-4.2.0-2 mpg123-1.31.2-1 multipath-tools-0.9.4-1
nano-7.1-1 ncurses-6.4-1 ndctl-75-1 netpbm-10.73.42-2 networkmanager-1.40.10-1
nftables-1:1.0.6-1 nilfs-utils-2.2.9-2 nss-3.87-1 ntp-4.2.8.p15-3
okular-22.12.1-1 openjpeg2-2.5.0-2 openssl-3.0.7-4 osinfo-db-20221130-1
pacman-contrib-1.8.2-1 pacman-mirrorlist-20221204-1 pahole-1:1.24+r29+g02d67c5-1
parallel-20221222-1 pciutils-3.9.0-2 pcsclite-1.9.9-2 perl-5.36.0-3
perl-encode-locale-1.05-10 perl-html-tagset-3.20-13 perl-http-date-6.05-6
perl-http-negotiate-6.01-11 perl-lwp-mediatypes-6.04-3 perl-www-robotrules-6.02-11
pinta-2.1-1 pipewire-1:0.3.64-1 pipewire-alsa-1:0.3.64-1
pipewire-audio-1:0.3.64-1 pipewire-jack-1:0.3.64-1 pipewire-pulse-1:0.3.64-1
plasma-framework-5.102.0-1 poppler-23.01.0-3 poppler-glib-23.01.0-3
poppler-qt5-23.01.0-3 psmisc-23.6-1 purpose-5.102.0-1 python-3.10.9-1
python-cairo-1.23.0-2 python-chardet-5.1.0-1 python-distro-1.8.0-2
python-gpgme-1.18.0-2 python-pydantic-1.10.4-1 python-setproctitle-1.3.2-1
python-termcolor-2.2.0-1 python-trove-classifiers-2023.1.12-1
qemu-audio-alsa-7.2.0-1 qemu-audio-dbus-7.2.0-1 qemu-audio-jack-7.2.0-1
qemu-audio-oss-7.2.0-1 qemu-audio-pa-7.2.0-1 qemu-audio-sdl-7.2.0-1
qemu-audio-spice-7.2.0-1 qemu-block-curl-7.2.0-1 qemu-block-dmg-7.2.0-1
qemu-block-nfs-7.2.0-1 qemu-block-ssh-7.2.0-1 qemu-chardev-spice-7.2.0-1
qemu-common-7.2.0-1 qemu-desktop-7.2.0-1 qemu-hw-display-qxl-7.2.0-1
qemu-hw-display-virtio-gpu-7.2.0-1 qemu-hw-display-virtio-gpu-gl-7.2.0-1
qemu-hw-display-virtio-gpu-pci-7.2.0-1 qemu-hw-display-virtio-gpu-pci-gl-7.2.0-1
qemu-hw-display-virtio-vga-7.2.0-1 qemu-hw-display-virtio-vga-gl-7.2.0-1
qemu-hw-s390x-virtio-gpu-ccw-7.2.0-1 qemu-hw-usb-host-7.2.0-1
qemu-hw-usb-redirect-7.2.0-1 qemu-hw-usb-smartcard-7.2.0-1 qemu-img-7.2.0-1
qemu-pr-helper-7.2.0-1 qemu-system-x86-7.2.0-1 qemu-system-x86-firmware-7.2.0-1
qemu-tools-7.2.0-1 qemu-ui-curses-7.2.0-1 qemu-ui-dbus-7.2.0-1
qemu-ui-egl-headless-7.2.0-1 qemu-ui-gtk-7.2.0-1 qemu-ui-opengl-7.2.0-1
qemu-ui-sdl-7.2.0-1 qemu-ui-spice-app-7.2.0-1 qemu-ui-spice-core-7.2.0-1
qemu-vhost-user-gpu-7.2.0-1 qemu-virtiofsd-7.2.0-1 qrencode-4.1.1-2
qt5-base-5.15.8+kde+r165-1 qt5-declarative-5.15.8+kde+r24-2
qt5-graphicaleffects-5.15.8-1 qt5-location-5.15.8+kde+r3-1
qt5-multimedia-5.15.8+kde+r1-1 qt5-quickcontrols-5.15.8-1
qt5-quickcontrols2-5.15.8+kde+r7-1 qt5-speech-5.15.8+kde+r1-1
qt5-svg-5.15.8+kde+r8-1 qt5-tools-5.15.8+kde+r1-3 qt5-translations-5.15.8-1
qt5-wayland-5.15.8+kde+r57-1 qt5-webchannel-5.15.8+kde+r3-1
qt5-webengine-5.15.12-2 qt5-x11extras-5.15.8-1 qt6-base-6.4.2-1
qt6-declarative-6.4.2-1 qt6-translations-6.4.2-1 rav1e-0.6.3-1 re2-1:20221201-2
ripgrep-13.0.0-3 ristretto-0.12.4-1 rsync-3.2.7-3 rust-1:1.66.1-2 sdl2-2.26.2-1
sdl2_image-2.6.2-3 shaderc-2022.4-1 shadow-4.13-1
signon-kwallet-extension-22.12.1-1 slang-2.3.3-2 smbclient-4.17.4-4
sof-firmware-2.2.4-1 solid-5.102.0-1 sonnet-5.102.0-1 spandsp-0.0.6-4
spdlog-1.11.0-2 spirv-tools-2022.4-1 sqlite-3.40.1-1 suitesparse-6.0.3-1
svt-av1-1.4.1-1 systemd-252.4-2 systemd-libs-252.4-2 systemd-sysvcompat-252.4-2
texinfo-7.0.1-1 threadweaver-5.102.0-1 thunar-4.18.2-1 thunar-volman-4.18.0-1
tor-0.4.7.13-1 torbrowser-launcher-0.3.6-1 tracker3-3.4.2-1
ttf-bitstream-vera-1.10-15 tumbler-4.18.0-1 unrar-1:6.2.3-1 usbutils-015-2
virglrenderer-0.10.4-1 vlc-3.0.18-6 vte-common-0.70.2-1 vte3-0.70.2-1
vulkan-mesa-layers-22.3.3-3 vulkan-radeon-22.3.3-3 wavpack-5.6.0-1
webkit2gtk-2.38.3-1 webkit2gtk-4.1-2.38.3-1 webp-pixbuf-loader-0.0.7-1
welcome-3.45-1 whois-5.5.15-1 wildmidi-0.4.5-1 wireplumber-0.4.13-1
wolfssl-5.5.4-1 wpa_supplicant-2:2.10-8 xapp-2.4.2-1 xcb-util-0.4.1-1
xfce4-appfinder-4.18.0-1 xfce4-datetime-plugin-0.8.3-1 xfce4-notifyd-0.6.5-1
xfce4-panel-4.18.1-1 xfce4-power-manager-4.18.0-1 xfce4-screenshooter-1.10.3-1
xfce4-session-4.18.0-1 xfce4-settings-4.18.1-1 xfce4-taskmanager-1.5.5-1
xfce4-whiskermenu-plugin-2.7.2-1 xfconf-4.18.0-1 xfdesktop-4.18.0-1
xfsprogs-6.1.1-2 xfwm4-4.18.0-1 xorg-server-21.1.6-1 xorg-server-common-21.1.6-1
xorg-xhost-1.0.9-1 xorg-xinit-1.4.2-1 xorg-xkbcomp-1.4.6-1 xorg-xprop-1.2.6-1
xorg-xrandr-1.5.2-1 xorg-xset-1.2.5-1 xz-5.4.1-1 yad-12.3-1.1
yad-eos-12.1-1.1 [removal] yay-11.3.2-1 zvbi-0.2.39-1 zxing-cpp-2.0.0-1
Total Download Size: 238.64 MiB
Total Installed Size: 6386.51 MiB
Net Upgrade Size: 126.19 MiB
:: Retrieving packages...
qt5-base-5.15.8+kde+r165-1... 13.0 MiB 571 KiB/s 00:23 [--------------------------------] 100%
mesa-22.3.3-3-x86_64 10.5 MiB 769 KiB/s 00:14 [--------------------------------] 100%
lib32-llvm-libs-15.0.7-1-x... 32.5 MiB 764 KiB/s 00:43 [--------------------------------] 100%
lib32-mesa-22.3.3-3-x86_64 10.2 MiB 1298 KiB/s 00:08 [--------------------------------] 100%
compiler-rt-15.0.7-1-x86_64 3.2 MiB 1800 KiB/s 00:02 [--------------------------------] 100%
qt5-tools-5.15.8+kde+r1-3-... 5.3 MiB 1144 KiB/s 00:05 [--------------------------------] 100%
clang-15.0.7-1-x86_64 39.3 MiB 826 KiB/s 00:49 [--------------------------------] 100%
lib32-vulkan-radeon-22.3.3... 2.2 MiB 1600 KiB/s 00:01 [--------------------------------] 100%
lib32-vulkan-mesa-layers-2... 337.6 KiB 879 KiB/s 00:00 [--------------------------------] 100%
vulkan-mesa-layers-22.3.3-... 321.1 KiB 1032 KiB/s 00:00 [--------------------------------] 100%
vulkan-radeon-22.3.3-3-x86_64 2.1 MiB 1358 KiB/s 00:02 [--------------------------------] 100%
rust-1:1.66.1-2-x86_64 90.4 MiB 1469 KiB/s 01:03 [--------------------------------] 100%
llvm-libs-15.0.7-1-x86_64 25.0 MiB 1694 KiB/s 00:15 [--------------------------------] 100%
Total (13/13) 238.6 MiB 382 KiB/s 10:40 [--------------------------------] 100%
error: failed retrieving file 'llvm-libs-15.0.7-1-x86_64.pkg.tar.zst' from mnvoip.mm.fcix.net : OpenSSL SSL_read: Connection timed out, errno 110
(441/441) checking keys in keyring [--------------------------------] 100%
(441/441) checking package integrity [--------------------------------] 100%
(441/441) loading package files [--------------------------------] 100%
(441/441) checking for file conflicts [--------------------------------] 100%
error: failed to commit transaction (conflicting files)
python-cairo: /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc exists in filesystem
You can just delete /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc
Also, it looks like your keyring issue is now resolved.
I wonder which command it was that fixed it? Well thatās good. Letās see if any other errors pop up.
In this case it could have been ok.
However for more cautious course of action >> The better way
I can explain that if you would like.
At one point you did this:
sudo cp -rf /etc/pacman.d/gnupg /etc/pacman.d/gnupg.bkup
sudo rm -rf /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate archlinux
sudo systemctl reboot
That completely erased your keyring and then populated it only with the keys for Arch. Critically, you were now missing the EOS keys.
Next you did this:
sudo pacman-key --add enos.pgp
You added the key without signing it.
Lastly you did this:
That populated all the eos keys properly.
Thanks. That was the longest one Iāve yet done. Iāll be sure to keep updated from here forward.
