pebcak
January 17, 2023, 4:29am
21
Looks it was ages ago you updated your system.
On a rolling release it is recommended to update on a more regular basis
With that amount of packages to be updated all sort of unexpected issues might arise.
Try again:
sudo pacman -Sy archlinux-keyring endeavouros-keyring
Well at this point should I just do a fresh install? I’m not sure what to do to catch up to the current set of updates.
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman -Sy archlinux-keyring endeavouros-keyring
[sudo] password for oneshinyboi:
endeavouros is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: endeavouros-keyring-20220614-1 is up to date -- reinstalling
resolving dependencies...
Package (2) Old Version New Version Net Change Download Size
core/archlinux-keyring 20221123-1 20221220-1 0.02 MiB
endeavouros/endeavouros-keyring 20220614-1 20220614-1 0.00 MiB 0.02 MiB
Total Download Size: 0.02 MiB
Total Installed Size: 1.61 MiB
Net Upgrade Size: 0.02 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
endeavouros-keyring-202206... 19.7 KiB 125 KiB/s 00:00 [--------------------------------] 100%
(2/2) checking keys in keyring [--------------------------------] 100%
downloading required keys...
:: Import PGP key 003DB8B0CB23504F, "EndeavourOS <info@endeavouros.com>"? [Y/n] y
error: key "003DB8B0CB23504F" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
pebcak
January 17, 2023, 4:40am
23
Let’s see if we can get EnOS’ key manually:
sudo pacman-key --recv-keys 003DB8B0CB23504F
If it gets imported:
sudo pacman-key --finger 003DB8B0CB23504
sudo pacman-key --lsign 003DB8B0CB23504
Oof. I’m sorry for all the trouble. This is getting deeper.
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman-key --recv-keys 003DB8B0CB23504F
gpg: keyserver receive failed: Server indicated a failure
==> ERROR: Remote key not fetched correctly from keyserver.
pebcak
January 17, 2023, 4:48am
25
No problem. It’s just I am running out of ideas
How about
sudo pacman-key --recv-keys 003DB8B0CB23504F --keyserver keyserver.ubuntu.com
It’s fine. You’ve been with me this whole time.
Well the auto updater just popped up for the first time in 2 days. But as far the the response from that last command. I’m off for tonight but thanks for the help so far.
[oneshinyboi@oneshinyboi-rogstrixg513qyg513qy ~]$ sudo pacman-key --recv-keys 003DB8B0CB23504F --keyserver keyserver.ubuntu.com
Pudge
January 17, 2023, 3:38pm
29
Since archliux-keyring is up to date, in a terminal enter the following
sudo cp -rf /etc/pacman.d/gnupg /etc/pacman.d/gnupg.bkup
sudo rm -rf /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate archlinux
sudo systemctl reboot
Don’t know if that will fix the key problems, but it’s worth a try.
If it messes things up, copy the gnupg.bkup directory back to gnupg
Pudge
Wasn’t sure of the right cmds for this bit.
Resetting all the keys
Remove or reset all the keys installed in your system by removing the /etc/pacman.d/gnupg directory (as root) and by rerunning pacman-key --init followed by pacman-key --populate to re-add the default keys.
pebcak
January 17, 2023, 4:04pm
31
The exact steps are detailed out in @Pudge ’s post.
Try them and let’s hope they will fix the issue. Good luck!
Edit: perhaps
sudo pacman-key --populate archlinux endeavouros
I apologize in advance for this super long one.
Arch & EndeavourOS update check:
:: Searching Arch & EndeavourOS for updates...
a52dec 0.7.4-11 -> 0.7.4-12
aalib 1.4rc5-14 -> 1.4rc5-15
alsa-card-profiles 1:0.3.61-1 -> 1:0.3.64-1
amd-ucode 20221109.60310c2-2 -> 20221214.f3c283e-1
arc-gtk-theme-eos 20220405-1 -> 20221218-1
archlinux-keyring 20221123-1 -> 20221220-1
audit 3.0.8-1 -> 3.0.9-1
bind 9.18.9-1 -> 9.18.10-1
binutils 2.39-3 -> 2.39-4
btrfs-progs 6.0.2-1 -> 6.1.2-1
ca-certificates-mozilla 3.85-1 -> 3.87-1
chromaprint 1.5.1-5 -> 1.5.1-6
cifs-utils 7.0-1 -> 7.0-2
clucene 2.3.3.4-12 -> 2.3.3.4-13
code 1.73.1-1 -> 1.74.3-1
curl 7.86.0-4 -> 7.87.0-3
cython 0.29.32-2 -> 0.29.33-1
db 5.3.28-5 -> 6.2.32-1
default-cursors 1-1 -> 2-1
device-mapper 2.03.17-1 -> 2.03.18-1
dialog 1:1.3_20220728-1 -> 1:1.3_20221229-1
djvulibre 3.5.28-3 -> 3.5.28-4
dnsmasq 2.87-3 -> 2.88-1
dotnet-host 7.0.0.sdk100-1 -> 7.0.2.sdk102-1
dotnet-runtime 7.0.0.sdk100-1 -> 7.0.2.sdk102-1
dotnet-runtime-6.0 6.0.11.sdk111-1 -> 6.0.13.sdk113-1
duktape 2.7.0-4 -> 2.7.0-5
electron19 19.1.4-3 -> 19.1.9-3
ell 0.54-1 -> 0.55-1
endeavouros-mirrorlist 4.10-1 -> 4.11-1
endeavouros-skel-default 1.6-1 -> 1.8-1
endeavouros-skel-xfce4 2.19-1 -> 3.3-1
endeavouros-theming 22.09.3.2-1 -> 22.12.1.1-1
endeavouros-xfce4-terminal-colors 4-2 -> 5-1
eos-apps-info 1.4-2 -> 1.5-1
eos-bash-shared 1.35-1 -> 1.41-1
eos-hooks 1.8-1 -> 1.10-1
eos-lightdm-slick-theme 3.1-1 -> 3.2-1
eos-log-tool 1.14-1 -> 1.14-4
eos-packagelist 2.0-1 -> 2.1-1
eos-quickstart 1.3-5 -> 1.3.1-1
eos-translations 1.20-1 -> 23-4
ethtool 1:6.0-1 -> 1:6.1-1
exo 4.16.4-1 -> 4.18.0-1
file 5.43-1 -> 5.44-1
firefox 107.0.1-1 -> 108.0.2-1
firewalld 1.2.1-1 -> 1.3.0-1
fluidsynth 2.3.0-2 -> 2.3.1-1
fmt 9.1.0-2 -> 9.1.0-4
fuse-common 3.12.0-1 -> 3.13.0-1
fuse3 3.12.0-1 -> 3.13.0-1
garcon 4.16.1-1 -> 4.18.0-1
gd 2.3.3-5 -> 2.3.3-6
gdk-pixbuf2 2.42.10-1 -> 2.42.10-2
gegl 0.4.40-1 -> 0.4.40-4
geoip-database 20221118-1 -> 20221227-1
ghostscript 10.0.0-2 -> 10.0.0-4
gimp 2.10.32-2 -> 2.10.32-3
git 2.38.1-2 -> 2.39.0-1
glib2 2.74.2-2 -> 2.74.4-1
glslang 11.11.0-1 -> 11.13.0-2
gnome-boxes 43.1-1 -> 43.2-1
gnu-netcat 0.7.1-8 -> 0.7.1-9
go 2:1.19.3-1 -> 2:1.19.5-1
graphviz 7.0.3-1 -> 7.0.6-1
grub 2:2.06.r380.g151467888-1 -> 2:2.06.r415.g1a241e050-1
grub-btrfs 4.11-2 -> 4.12-2
gst-libav 1.20.4-3 -> 1.20.5-5
gst-plugin-pipewire 1:0.3.61-1 -> 1:0.3.64-1
gst-plugins-bad 1.20.4-3 -> 1.20.5-5
gst-plugins-bad-libs 1.20.4-3 -> 1.20.5-5
gst-plugins-base 1.20.4-3 -> 1.20.5-5
gst-plugins-base-libs 1.20.4-3 -> 1.20.5-5
gst-plugins-good 1.20.4-3 -> 1.20.5-5
gst-plugins-ugly 1.20.4-3 -> 1.20.5-5
gstreamer 1.20.4-3 -> 1.20.5-5
gtk-update-icon-cache 1:4.8.2-1 -> 1:4.8.3-3
gtk3 1:3.24.35-2 -> 1:3.24.36-1
gupnp 1:1.6.2-1 -> 1:1.6.3-1
gvfs 1.50.2-1 -> 1.50.3-1
gvfs-afc 1.50.2-1 -> 1.50.3-1
gvfs-gphoto2 1.50.2-1 -> 1.50.3-1
gvfs-mtp 1.50.2-1 -> 1.50.3-1
gvfs-nfs 1.50.2-1 -> 1.50.3-1
gvfs-smb 1.50.2-1 -> 1.50.3-1
harfbuzz 5.3.1-3 -> 6.0.0-1
harfbuzz-icu 5.3.1-3 -> 6.0.0-1
hidapi 0.12.0-1 -> 0.13.1-1
hunspell 1.7.1-1 -> 1.7.2-1
hwdata 0.364-1 -> 0.366-1
hwdetect 2022.11-1 -> 2023.01-1
hwinfo 22.1-1 -> 22.2-1
iana-etc 20221107-1 -> 20221215-1
imagemagick 7.1.0.52-1 -> 7.1.0.57-2
imlib2 1.9.1-2 -> 1.10.0-2
inxi 3.3.23.1-1 -> 3.3.24.1-4
iproute2 6.0.0-1 -> 6.1.0-3
iwd 2.0-1 -> 2.1-1
jasper 3.0.6-1 -> 4.0.0-1
kaccounts-integration 22.08.3-1 -> 22.12.1-1
kactivities 5.100.0-1 -> 5.102.0-1
karchive 5.100.0-1 -> 5.102.0-1
kauth 5.100.0-1 -> 5.102.0-1
kbookmarks 5.100.0-1 -> 5.102.0-1
kcmutils 5.100.0-1 -> 5.102.0-1
kcodecs 5.100.0-1 -> 5.102.0-1
kcompletion 5.100.0-1 -> 5.102.0-1
kconfig 5.100.1-1 -> 5.102.0-1
kconfigwidgets 5.100.0-1 -> 5.102.0-1
kcoreaddons 5.100.0-1 -> 5.102.0-1
kcrash 5.100.0-1 -> 5.102.0-1
kdbusaddons 5.100.0-1 -> 5.102.0-1
kdeclarative 5.100.0-1 -> 5.102.0-1
kded 5.100.0-1 -> 5.102.0-1
kglobalaccel 5.100.0-1 -> 5.102.0-1
kguiaddons 5.100.0-1 -> 5.102.0-1
ki18n 5.100.0-1 -> 5.102.0-1
kiconthemes 5.100.0-1 -> 5.102.0-1
kio 5.100.0-1 -> 5.102.0-1
kirigami2 5.100.0-1 -> 5.102.0-1
kitemviews 5.100.0-1 -> 5.102.0-1
kjobwidgets 5.100.0-1 -> 5.102.0-1
kjs 5.100.0-1 -> 5.102.0-1
knotifications 5.100.0-1 -> 5.102.0-1
kpackage 5.100.0-1 -> 5.102.0-1
kparts 5.100.0-1 -> 5.102.0-1
kpty 5.100.0-1 -> 5.102.0-1
krb5 1.20-3 -> 1.20.1-1
kservice 5.100.0-1 -> 5.102.0-1
ktextwidgets 5.100.0-1 -> 5.102.0-1
kwallet 5.100.0-1 -> 5.102.0-1
kwayland 5.100.0-1 -> 5.102.0-1
kwidgetsaddons 5.100.0-1 -> 5.102.0-1
kwindowsystem 5.100.0-1 -> 5.102.0-1
kxmlgui 5.100.0-1 -> 5.102.0-1
lcms2 2.14-1 -> 2.14-2
lib32-curl 7.86.0-2 -> 7.87.0-1
lib32-krb5 1.20-3 -> 1.20.1-1
lib32-libglvnd 1.5.0-1 -> 1.6.0-1
lib32-libtirpc 1.3.3-1 -> 1.3.3-2
lib32-libx11 1.8.2-2 -> 1.8.3-1
lib32-libxau 1.0.10-3 -> 1.0.11-1
lib32-libxdamage 1.1.5-3 -> 1.1.6-1
lib32-libxdmcp 1.1.3-2 -> 1.1.4-1
lib32-libxshmfence 1.3.1-1 -> 1.3.2-1
lib32-mesa 22.2.3-1 -> 22.3.3-1
lib32-ncurses 6.3-1 -> 6.4-1
lib32-nss 3.85-1 -> 3.87-1
lib32-sqlite 3.40.0-1 -> 3.40.1-1
lib32-systemd 252.2-1 -> 252.4-1
lib32-vulkan-mesa-layers 22.2.3-1 -> 22.3.3-1
lib32-vulkan-radeon 22.2.3-1 -> 22.3.3-1
lib32-xz 5.2.8-2 -> 5.4.1-1
libarchive 3.6.1-5 -> 3.6.2-2
libass 0.16.0-1 -> 0.17.0-1
libbluray 1.3.3-1 -> 1.3.4-1
libcamera 0.0.2-1 -> 0.0.3-3
libcddb 1.3.2-6 -> 1.3.2-7
libetonyek 0.1.10-2 -> 0.1.10-3
libfontenc 1.1.6-1 -> 1.1.7-1
libgusb 0.4.2-1 -> 0.4.3-1
libheif 1.14.0-1 -> 1.14.2-1
libical 3.0.16-2 -> 3.0.16-4
libice 1.0.10-4 -> 1.1.1-1
libiec61883 1.2.0-6 -> 1.2.0-7
libkexiv2 22.08.3-1 -> 22.12.1-1
libkeybinder3 0.3.2-3 -> 0.3.2-4
libksba 1.6.2-1 -> 1.6.3-1
libmfx 22.4.4-1 -> 22.6.4-1
libmm-glib 1.20.2-1 -> 1.20.4-1
libmodplug 0.8.9.0-3 -> 0.8.9.0-5
libmpc 1.2.1-2 -> 1.3.1-1
libnice 0.1.19-1 -> 0.1.21-1
libnm 1.40.6-1 -> 1.40.10-1
libnma 1.10.4-3 -> 1.10.6-1
libnma-common 1.10.4-3 -> 1.10.6-1
libomxil-bellagio 0.9.3-3 -> 0.9.3-4
libopenmpt 0.6.6-2 -> 0.6.7-1
libopenraw 0.3.2-1 -> 0.3.3-1
libpcap 1.10.1-2 -> 1.10.3-1
libplacebo 4.208.0-1 -> 5.229.1-2
libproxy 0.4.18-1 -> 0.4.18-2
libpsl 0.21.1-3 -> 0.21.2-1
libraqm 0.9.0-1 -> 0.10.0-1
libraw 0.20.2-2 -> 0.21.1-1
libreoffice-still 7.3.7-1 -> 7.3.7-2
librevenge 0.0.4-5 -> 0.0.5-2
libsigc++ 2.10.8-1 -> 2.12.0-1
libsm 1.2.3-3 -> 1.2.4-1
libsndfile 1.1.0-3 -> 1.2.0-1
libsoxr 0.1.3-2 -> 0.1.3-3
libspectre 0.2.11-1 -> 0.2.12-1
libtiff 4.4.0-4 -> 4.5.0-1
libva 2.16.0-1 -> 2.17.0-1
libvirt 1:8.9.0-1 -> 1:8.10.0-1
libwebp 1.2.4-1 -> 1.3.0-2
libwireplumber 0.4.12-2 -> 0.4.13-1
libwmf 0.2.12-2 -> 0.2.12-3
libx11 1.8.2-2 -> 1.8.3-5
libxau 1.0.10-2 -> 1.0.11-1
libxcomposite 0.4.5-4 -> 0.4.6-1
libxdamage 1.1.5-5 -> 1.1.6-1
libxfce4ui 4.16.1-1 -> 4.18.1-1
libxfce4util 4.16.0-1 -> 4.18.1-1
libxkbcommon 1.4.1-2 -> 1.5.0-1
libxkbcommon-x11 1.4.1-2 -> 1.5.0-1
libxkbfile 1.1.1-1 -> 1.1.2-1
libxres 1.2.1-1 -> 1.2.2-1
libxv 1.0.11-5 -> 1.0.12-1
linux 6.0.10.arch2-1 -> 6.1.6.arch1-1
linux-atm 2.5.2-7 -> 2.5.2-8
linux-firmware 20221109.60310c2-2 -> 20221214.f3c283e-1
linux-firmware-whence 20221109.60310c2-2 -> 20221214.f3c283e-1
linux-hardened 6.0.10.hardened1-1 -> 6.1.6.hardened2-1
linux-headers 6.0.10.arch2-1 -> 6.1.6.arch1-1
linux-zen 6.0.10.zen2-1 -> 6.1.6.zen1-1
linux-zen-headers 6.0.10.zen2-1 -> 6.1.6.zen1-1
logrotate 3.20.1-1 -> 3.21.0-2
lsof 4.96.4-1 -> 4.96.5-1
lua 5.4.4-2 -> 5.4.4-3
luajit 2.1.0.beta3.r457.g637721d0-1 -> 2.1.0.beta3.r467.gd0e88930-1
lvm2 2.03.17-1 -> 2.03.18-1
make 4.3-5 -> 4.4-1
man-db 2.11.1-1 -> 2.11.2-1
man-pages 6.01-1 -> 6.02-1
mbedtls 2.28.1-1 -> 2.28.2-1
mkinitcpio 33-1 -> 34-2
mobile-broadband-provider-info 20221107-1 -> 20221107-2
modemmanager 1.20.2-1 -> 1.20.4-1
mpfr 4.1.1.p1-1 -> 4.2.0-1
mpg123 1.31.1-1 -> 1.31.2-1
multipath-tools 0.9.3-1 -> 0.9.4-1
nano 7.0-1 -> 7.1-1
ncurses 6.3-3 -> 6.4-1
ndctl 74-1 -> 75-1
netpbm 10.73.41-1 -> 10.73.42-2
networkmanager 1.40.6-1 -> 1.40.10-1
nftables 1:1.0.5-1 -> 1:1.0.6-1
nilfs-utils 2.2.9-1 -> 2.2.9-2
ntp 4.2.8.p15-2 -> 4.2.8.p15-3
okular 22.08.3-1 -> 22.12.1-1
openjpeg2 2.5.0-1 -> 2.5.0-2
openssl 3.0.7-2 -> 3.0.7-4
osinfo-db 20221018-1 -> 20221130-1
pacman-contrib 1.8.0-1 -> 1.8.2-1
pacman-mirrorlist 20221016-1 -> 20221204-1
pahole 1:1.24-1 -> 1:1.24+r29+g02d67c5-1
parallel 20221122-1 -> 20221222-1
pciutils 3.9.0-1 -> 3.9.0-2
pcsclite 1.9.9-1 -> 1.9.9-2
perl 5.36.0-1 -> 5.36.0-3
perl-encode-locale 1.05-9 -> 1.05-10
perl-html-tagset 3.20-12 -> 3.20-13
perl-http-date 6.05-5 -> 6.05-6
perl-http-negotiate 6.01-10 -> 6.01-11
perl-lwp-mediatypes 6.04-2 -> 6.04-3
perl-www-robotrules 6.02-10 -> 6.02-11
pinta 2.0.2-3 -> 2.1-1
pipewire-alsa 1:0.3.61-1 -> 1:0.3.64-1
pipewire-audio 1:0.3.61-1 -> 1:0.3.64-1
pipewire-jack 1:0.3.61-1 -> 1:0.3.64-1
pipewire-pulse 1:0.3.61-1 -> 1:0.3.64-1
plasma-framework 5.100.1-1 -> 5.102.0-1
poppler 22.11.0-1 -> 23.01.0-3
poppler-glib 22.11.0-1 -> 23.01.0-3
poppler-qt5 22.11.0-1 -> 23.01.0-3
psmisc 23.5-1 -> 23.6-1
purpose 5.100.0-1 -> 5.102.0-1
python 3.10.8-3 -> 3.10.9-1
python-cairo 1.23.0-1 -> 1.23.0-2
python-chardet 5.0.0-1 -> 5.1.0-1
python-distro 1.8.0-1 -> 1.8.0-2
python-pydantic 1.10.2-1 -> 1.10.4-1
python-setproctitle 1.3.1-1 -> 1.3.2-1
python-termcolor 2.1.0-1 -> 2.2.0-1
python-trove-classifiers 2022.12.1-1 -> 2023.1.12-1
qemu-audio-alsa 7.1.0-11 -> 7.2.0-1
qemu-audio-dbus 7.1.0-11 -> 7.2.0-1
qemu-audio-jack 7.1.0-11 -> 7.2.0-1
qemu-audio-oss 7.1.0-11 -> 7.2.0-1
qemu-audio-pa 7.1.0-11 -> 7.2.0-1
qemu-audio-sdl 7.1.0-11 -> 7.2.0-1
qemu-audio-spice 7.1.0-11 -> 7.2.0-1
qemu-block-curl 7.1.0-11 -> 7.2.0-1
qemu-block-dmg 7.1.0-11 -> 7.2.0-1
qemu-block-nfs 7.1.0-11 -> 7.2.0-1
qemu-block-ssh 7.1.0-11 -> 7.2.0-1
qemu-chardev-spice 7.1.0-11 -> 7.2.0-1
qemu-common 7.1.0-11 -> 7.2.0-1
qemu-desktop 7.1.0-11 -> 7.2.0-1
qemu-hw-display-qxl 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-gpu 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-gpu-gl 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-gpu-pci 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-gpu-pci-gl 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-vga 7.1.0-11 -> 7.2.0-1
qemu-hw-display-virtio-vga-gl 7.1.0-11 -> 7.2.0-1
qemu-hw-s390x-virtio-gpu-ccw 7.1.0-11 -> 7.2.0-1
qemu-hw-usb-host 7.1.0-11 -> 7.2.0-1
qemu-hw-usb-redirect 7.1.0-11 -> 7.2.0-1
qemu-hw-usb-smartcard 7.1.0-11 -> 7.2.0-1
qemu-img 7.1.0-11 -> 7.2.0-1
qemu-pr-helper 7.1.0-11 -> 7.2.0-1
qemu-system-x86 7.1.0-11 -> 7.2.0-1
qemu-system-x86-firmware 7.1.0-11 -> 7.2.0-1
qemu-tools 7.1.0-11 -> 7.2.0-1
qemu-ui-curses 7.1.0-11 -> 7.2.0-1
qemu-ui-dbus 7.1.0-11 -> 7.2.0-1
qemu-ui-egl-headless 7.1.0-11 -> 7.2.0-1
qemu-ui-gtk 7.1.0-11 -> 7.2.0-1
qemu-ui-opengl 7.1.0-11 -> 7.2.0-1
qemu-ui-sdl 7.1.0-11 -> 7.2.0-1
qemu-ui-spice-app 7.1.0-11 -> 7.2.0-1
qemu-ui-spice-core 7.1.0-11 -> 7.2.0-1
qemu-vhost-user-gpu 7.1.0-11 -> 7.2.0-1
qemu-virtiofsd 7.1.0-11 -> 7.2.0-1
qrencode 4.1.1-1 -> 4.1.1-2
qt5-base 5.15.7+kde+r176-1 -> 5.15.8+kde+r162-1
qt5-declarative 5.15.7+kde+r23-1 -> 5.15.8+kde+r24-2
qt5-graphicaleffects 5.15.7-1 -> 5.15.8-1
qt5-location 5.15.7+kde+r3-1 -> 5.15.8+kde+r3-1
qt5-multimedia 5.15.7+kde+r1-1 -> 5.15.8+kde+r1-1
qt5-quickcontrols 5.15.7-1 -> 5.15.8-1
qt5-quickcontrols2 5.15.7+kde+r6-1 -> 5.15.8+kde+r7-1
qt5-speech 5.15.7+kde+r1-1 -> 5.15.8+kde+r1-1
qt5-svg 5.15.7+kde+r9-1 -> 5.15.8+kde+r8-1
qt5-tools 5.15.7+kde+r1-2 -> 5.15.8+kde+r1-1
qt5-translations 5.15.7-1 -> 5.15.8-1
qt5-wayland 5.15.7+kde+r55-1 -> 5.15.8+kde+r57-1
qt5-webchannel 5.15.7+kde+r3-1 -> 5.15.8+kde+r3-1
qt5-webengine 5.15.11-2 -> 5.15.12-2
qt5-x11extras 5.15.7-1 -> 5.15.8-1
qt6-base 6.4.1-1 -> 6.4.2-1
qt6-declarative 6.4.1-1 -> 6.4.2-1
qt6-translations 6.4.1-1 -> 6.4.2-1
rav1e 0.5.1-2 -> 0.6.3-1
re2 1:20220601-1 -> 1:20221201-2
ripgrep 13.0.0-2 -> 13.0.0-3
ristretto 0.12.3-1 -> 0.12.4-1
rsync 3.2.7-2 -> 3.2.7-3
rust 1:1.65.0-1 -> 1:1.66.1-1
sdl2 2.26.0-1 -> 2.26.2-1
sdl2_image 2.6.2-2 -> 2.6.2-3
shaderc 2022.1-4 -> 2022.4-1
shadow 4.12.3-2 -> 4.13-1
signon-kwallet-extension 22.08.3-1 -> 22.12.1-1
slang 2.3.3-1 -> 2.3.3-2
smbclient 4.17.3-1 -> 4.17.4-4
sof-firmware 2.2.2-1 -> 2.2.4-1
solid 5.100.0-1 -> 5.102.0-1
sonnet 5.100.0-1 -> 5.102.0-1
spandsp 0.0.6-3 -> 0.0.6-4
spdlog 1.11.0-1 -> 1.11.0-2
spirv-tools 2022.1-1 -> 2022.4-1
suitesparse 6.0.1-1 -> 6.0.3-1
svt-av1 1.3.0-1 -> 1.4.1-1
systemd 252.2-2 -> 252.4-2
systemd-libs 252.2-2 -> 252.4-2
systemd-sysvcompat 252.2-2 -> 252.4-2
texinfo 7.0-1 -> 7.0.1-1
threadweaver 5.100.0-1 -> 5.102.0-1
thunar 4.16.11-2 -> 4.18.2-1
thunar-volman 4.16.0-1 -> 4.18.0-1
tor 0.4.7.11-1 -> 0.4.7.13-1
torbrowser-launcher 0.3.5-4 -> 0.3.6-1
tracker3 3.4.1-1 -> 3.4.2-1
ttf-bitstream-vera 1.10-14 -> 1.10-15
tumbler 4.16.1-3 -> 4.18.0-1
unrar 1:6.2.2-1 -> 1:6.2.3-1
usbutils 015-1 -> 015-2
virglrenderer 0.9.1-1 -> 0.10.4-1
vlc 3.0.17.4-11 -> 3.0.18-6
vte-common 0.70.1-1 -> 0.70.2-1
vte3 0.70.1-1 -> 0.70.2-1
wavpack 5.5.0-1 -> 5.6.0-1
webkit2gtk 2.38.2-2 -> 2.38.3-1
webkit2gtk-4.1 2.38.2-2 -> 2.38.3-1
welcome 3.43-1 -> 3.45-1
whois 5.5.14-1 -> 5.5.15-1
wildmidi 0.4.4-1 -> 0.4.5-1
wolfssl 5.5.3-1 -> 5.5.4-1
wpa_supplicant 2:2.10-7 -> 2:2.10-8
xapp 2.4.1-1 -> 2.4.2-1
xcb-util 0.4.0-4 -> 0.4.1-1
xfce4-appfinder 4.16.1-2 -> 4.18.0-1
xfce4-datetime-plugin 0.8.2-1 -> 0.8.3-1
xfce4-notifyd 0.6.4-2 -> 0.6.5-1
xfce4-panel 4.16.5-1 -> 4.18.1-1
xfce4-power-manager 4.16.0-3 -> 4.18.0-1
xfce4-screenshooter 1.10.0-1 -> 1.10.3-1
xfce4-session 4.16.0-2 -> 4.18.0-1
xfce4-settings 4.16.5-1 -> 4.18.1-1
xfce4-taskmanager 1.5.4-1 -> 1.5.5-1
xfconf 4.16.0-2 -> 4.18.0-1
xfdesktop 4.16.1-1 -> 4.18.0-1
xfsprogs 6.0.0-1 -> 6.1.1-2
xfwm4 4.16.1-3 -> 4.18.0-1
xorg-server 21.1.4-1 -> 21.1.6-1
xorg-server-common 21.1.4-1 -> 21.1.6-1
xorg-xhost 1.0.8-3 -> 1.0.9-1
xorg-xinit 1.4.1-3 -> 1.4.2-1
xorg-xkbcomp 1.4.5-1 -> 1.4.6-1
xorg-xprop 1.2.5-1 -> 1.2.6-1
xorg-xrandr 1.5.1-2 -> 1.5.2-1
xorg-xset 1.2.4-3 -> 1.2.5-1
xz 5.2.8-1 -> 5.4.1-1
yad-eos 12.1-1.1 -> 12.3-1
yay 11.3.1-1 -> 11.3.2-1
zvbi 0.2.37-1 -> 0.2.39-1
zxing-cpp 1.4.0-1 -> 2.0.0-1
Root Password:
core is up to date
extra is up to date
warning: dependency cycle detected:
warning: mesa will be installed before its libglvnd dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: insufficient columns available for table display
Packages (426) db5.3-5.3.28-2 elementary-icon-theme-7.1.0-1 http-parser-2.9.4-1
libgit2-1:1.5.0-2 liblc3-1.0.1-1 libwbclient-4.17.4-4 webp-pixbuf-loader-0.0.7-1
a52dec-0.7.4-12 aalib-1.4rc5-15 alsa-card-profiles-1:0.3.64-1
amd-ucode-20221214.f3c283e-1 arc-gtk-theme-eos-20221218-1
archlinux-keyring-20221220-1 audit-3.0.9-1 bind-9.18.10-1 binutils-2.39-4
btrfs-progs-6.1.2-1 ca-certificates-mozilla-3.87-1 chromaprint-1.5.1-6
cifs-utils-7.0-2 clucene-2.3.3.4-13 code-1.74.3-1 curl-7.87.0-3 cython-0.29.33-1
db-6.2.32-1 default-cursors-2-1 device-mapper-2.03.18-1 dialog-1:1.3_20221229-1
djvulibre-3.5.28-4 dnsmasq-2.88-1 dotnet-host-7.0.2.sdk102-1
dotnet-runtime-7.0.2.sdk102-1 dotnet-runtime-6.0-6.0.13.sdk113-1 duktape-2.7.0-5
electron19-19.1.9-3 ell-0.55-1 endeavouros-mirrorlist-4.11-1
endeavouros-skel-default-1.8-1 endeavouros-skel-xfce4-3.3-1
endeavouros-theming-22.12.1.1-1 endeavouros-xfce4-terminal-colors-5-1
eos-apps-info-1.5-1 eos-bash-shared-1.41-1 eos-hooks-1.10-1
eos-lightdm-slick-theme-3.2-1 eos-log-tool-1.14-4 eos-packagelist-2.1-1
eos-quickstart-1.3.1-1 eos-translations-23-4 ethtool-1:6.1-1 exo-4.18.0-1
file-5.44-1 firefox-108.0.2-1 firewalld-1.3.0-1 fluidsynth-2.3.1-1 fmt-9.1.0-4
fuse-common-3.13.0-1 fuse3-3.13.0-1 garcon-4.18.0-1 gd-2.3.3-6
gdk-pixbuf2-2.42.10-2 gegl-0.4.40-4 geoip-database-20221227-1
ghostscript-10.0.0-4 gimp-2.10.32-3 git-2.39.0-1 glib2-2.74.4-1
glslang-11.13.0-2 gnome-boxes-43.2-1 gnu-netcat-0.7.1-9 go-2:1.19.5-1
graphviz-7.0.6-1 grub-2:2.06.r415.g1a241e050-1 grub-btrfs-4.12-2
gst-libav-1.20.5-5 gst-plugin-pipewire-1:0.3.64-1 gst-plugins-bad-1.20.5-5
gst-plugins-bad-libs-1.20.5-5 gst-plugins-base-1.20.5-5
gst-plugins-base-libs-1.20.5-5 gst-plugins-good-1.20.5-5 gst-plugins-ugly-1.20.5-5
gstreamer-1.20.5-5 gtk-update-icon-cache-1:4.8.3-3 gtk3-1:3.24.36-1
gupnp-1:1.6.3-1 gvfs-1.50.3-1 gvfs-afc-1.50.3-1 gvfs-gphoto2-1.50.3-1
gvfs-mtp-1.50.3-1 gvfs-nfs-1.50.3-1 gvfs-smb-1.50.3-1 harfbuzz-6.0.0-1
harfbuzz-icu-6.0.0-1 hidapi-0.13.1-1 hunspell-1.7.2-1 hwdata-0.366-1
hwdetect-2023.01-1 hwinfo-22.2-1 iana-etc-20221215-1 imagemagick-7.1.0.57-2
imlib2-1.10.0-2 inxi-3.3.24.1-4 iproute2-6.1.0-3 iwd-2.1-1 jasper-4.0.0-1
kaccounts-integration-22.12.1-1 kactivities-5.102.0-1 karchive-5.102.0-1
kauth-5.102.0-1 kbookmarks-5.102.0-1 kcmutils-5.102.0-1 kcodecs-5.102.0-1
kcompletion-5.102.0-1 kconfig-5.102.0-1 kconfigwidgets-5.102.0-1
kcoreaddons-5.102.0-1 kcrash-5.102.0-1 kdbusaddons-5.102.0-1
kdeclarative-5.102.0-1 kded-5.102.0-1 kglobalaccel-5.102.0-1 kguiaddons-5.102.0-1
ki18n-5.102.0-1 kiconthemes-5.102.0-1 kio-5.102.0-1 kirigami2-5.102.0-1
kitemviews-5.102.0-1 kjobwidgets-5.102.0-1 kjs-5.102.0-1 knotifications-5.102.0-1
kpackage-5.102.0-1 kparts-5.102.0-1 kpty-5.102.0-1 krb5-1.20.1-1
kservice-5.102.0-1 ktextwidgets-5.102.0-1 kwallet-5.102.0-1 kwayland-5.102.0-1
kwidgetsaddons-5.102.0-1 kwindowsystem-5.102.0-1 kxmlgui-5.102.0-1 lcms2-2.14-2
lib32-curl-7.87.0-1 lib32-krb5-1.20.1-1 lib32-libglvnd-1.6.0-1
lib32-libtirpc-1.3.3-2 lib32-libx11-1.8.3-1 lib32-libxau-1.0.11-1
lib32-libxdamage-1.1.6-1 lib32-libxdmcp-1.1.4-1 lib32-libxshmfence-1.3.2-1
lib32-mesa-22.3.3-1 lib32-ncurses-6.4-1 lib32-nss-3.87-1 lib32-sqlite-3.40.1-1
lib32-systemd-252.4-1 lib32-vulkan-mesa-layers-22.3.3-1
lib32-vulkan-radeon-22.3.3-1 lib32-xz-5.4.1-1 libarchive-3.6.2-2 libass-0.17.0-1
libbluray-1.3.4-1 libcamera-0.0.3-3 libcddb-1.3.2-7 libetonyek-0.1.10-3
libfontenc-1.1.7-1 libglvnd-1.6.0-1 libgusb-0.4.3-1 libheif-1.14.2-1
libical-3.0.16-4 libice-1.1.1-1 libiec61883-1.2.0-7 libkexiv2-22.12.1-1
libkeybinder3-0.3.2-4 libksba-1.6.3-1 libmfx-22.6.4-1 libmm-glib-1.20.4-1
libmodplug-0.8.9.0-5 libmpc-1.3.1-1 libnice-0.1.21-1 libnm-1.40.10-1
libnma-1.10.6-1 libnma-common-1.10.6-1 libomxil-bellagio-0.9.3-4
libopenmpt-0.6.7-1 libopenraw-0.3.3-1 libpcap-1.10.3-1 libplacebo-5.229.1-2
libproxy-0.4.18-2 libpsl-0.21.2-1 libraqm-0.10.0-1 libraw-0.21.1-1
libreoffice-still-7.3.7-2 librevenge-0.0.5-2 libsigc++-2.12.0-1 libsm-1.2.4-1
libsndfile-1.2.0-1 libsoxr-0.1.3-3 libspectre-0.2.12-1 libtiff-4.5.0-1
libva-2.17.0-1 libvirt-1:8.10.0-1 libwebp-1.3.0-2 libwireplumber-0.4.13-1
libwmf-0.2.12-3 libx11-1.8.3-5 libxau-1.0.11-1 libxcomposite-0.4.6-1
libxdamage-1.1.6-1 libxfce4ui-4.18.1-1 libxfce4util-4.18.1-1 libxkbcommon-1.5.0-1
libxkbcommon-x11-1.5.0-1 libxkbfile-1.1.2-1 libxres-1.2.2-1 libxshmfence-1.3.2-1
libxv-1.0.12-1 linux-6.1.6.arch1-1 linux-atm-2.5.2-8
linux-firmware-20221214.f3c283e-1 linux-firmware-whence-20221214.f3c283e-1
linux-hardened-6.1.6.hardened2-1 linux-headers-6.1.6.arch1-1
linux-zen-6.1.6.zen1-1 linux-zen-headers-6.1.6.zen1-1 logrotate-3.21.0-2
lsof-4.96.5-1 lua-5.4.4-3 luajit-2.1.0.beta3.r467.gd0e88930-1 lvm2-2.03.18-1
make-4.4-1 man-db-2.11.2-1 man-pages-6.02-1 mbedtls-2.28.2-1 mesa-22.3.3-1
mkinitcpio-34-2 mobile-broadband-provider-info-20221107-2 modemmanager-1.20.4-1
mpfr-4.2.0-1 mpg123-1.31.2-1 multipath-tools-0.9.4-1 nano-7.1-1 ncurses-6.4-1
ndctl-75-1 netpbm-10.73.42-2 networkmanager-1.40.10-1 nftables-1:1.0.6-1
nilfs-utils-2.2.9-2 nss-3.87-1 ntp-4.2.8.p15-3 okular-22.12.1-1
openjpeg2-2.5.0-2 openssl-3.0.7-4 osinfo-db-20221130-1 pacman-contrib-1.8.2-1
pacman-mirrorlist-20221204-1 pahole-1:1.24+r29+g02d67c5-1 parallel-20221222-1
pciutils-3.9.0-2 pcsclite-1.9.9-2 perl-5.36.0-3 perl-encode-locale-1.05-10
perl-html-tagset-3.20-13 perl-http-date-6.05-6 perl-http-negotiate-6.01-11
perl-lwp-mediatypes-6.04-3 perl-www-robotrules-6.02-11 pinta-2.1-1
pipewire-1:0.3.64-1 pipewire-alsa-1:0.3.64-1 pipewire-audio-1:0.3.64-1
pipewire-jack-1:0.3.64-1 pipewire-pulse-1:0.3.64-1 plasma-framework-5.102.0-1
poppler-23.01.0-3 poppler-glib-23.01.0-3 poppler-qt5-23.01.0-3 psmisc-23.6-1
purpose-5.102.0-1 python-3.10.9-1 python-cairo-1.23.0-2 python-chardet-5.1.0-1
python-distro-1.8.0-2 python-pydantic-1.10.4-1 python-setproctitle-1.3.2-1
python-termcolor-2.2.0-1 python-trove-classifiers-2023.1.12-1
qemu-audio-alsa-7.2.0-1 qemu-audio-dbus-7.2.0-1 qemu-audio-jack-7.2.0-1
qemu-audio-oss-7.2.0-1 qemu-audio-pa-7.2.0-1 qemu-audio-sdl-7.2.0-1
qemu-audio-spice-7.2.0-1 qemu-block-curl-7.2.0-1 qemu-block-dmg-7.2.0-1
qemu-block-nfs-7.2.0-1 qemu-block-ssh-7.2.0-1 qemu-chardev-spice-7.2.0-1
qemu-common-7.2.0-1 qemu-desktop-7.2.0-1 qemu-hw-display-qxl-7.2.0-1
qemu-hw-display-virtio-gpu-7.2.0-1 qemu-hw-display-virtio-gpu-gl-7.2.0-1
qemu-hw-display-virtio-gpu-pci-7.2.0-1 qemu-hw-display-virtio-gpu-pci-gl-7.2.0-1
qemu-hw-display-virtio-vga-7.2.0-1 qemu-hw-display-virtio-vga-gl-7.2.0-1
qemu-hw-s390x-virtio-gpu-ccw-7.2.0-1 qemu-hw-usb-host-7.2.0-1
qemu-hw-usb-redirect-7.2.0-1 qemu-hw-usb-smartcard-7.2.0-1 qemu-img-7.2.0-1
qemu-pr-helper-7.2.0-1 qemu-system-x86-7.2.0-1 qemu-system-x86-firmware-7.2.0-1
qemu-tools-7.2.0-1 qemu-ui-curses-7.2.0-1 qemu-ui-dbus-7.2.0-1
qemu-ui-egl-headless-7.2.0-1 qemu-ui-gtk-7.2.0-1 qemu-ui-opengl-7.2.0-1
qemu-ui-sdl-7.2.0-1 qemu-ui-spice-app-7.2.0-1 qemu-ui-spice-core-7.2.0-1
qemu-vhost-user-gpu-7.2.0-1 qemu-virtiofsd-7.2.0-1 qrencode-4.1.1-2
qt5-base-5.15.8+kde+r162-1 qt5-declarative-5.15.8+kde+r24-2
qt5-graphicaleffects-5.15.8-1 qt5-location-5.15.8+kde+r3-1
qt5-multimedia-5.15.8+kde+r1-1 qt5-quickcontrols-5.15.8-1
qt5-quickcontrols2-5.15.8+kde+r7-1 qt5-speech-5.15.8+kde+r1-1
qt5-svg-5.15.8+kde+r8-1 qt5-tools-5.15.8+kde+r1-1 qt5-translations-5.15.8-1
qt5-wayland-5.15.8+kde+r57-1 qt5-webchannel-5.15.8+kde+r3-1
qt5-webengine-5.15.12-2 qt5-x11extras-5.15.8-1 qt6-base-6.4.2-1
qt6-declarative-6.4.2-1 qt6-translations-6.4.2-1 rav1e-0.6.3-1 re2-1:20221201-2
ripgrep-13.0.0-3 ristretto-0.12.4-1 rsync-3.2.7-3 rust-1:1.66.1-1 sdl2-2.26.2-1
sdl2_image-2.6.2-3 shaderc-2022.4-1 shadow-4.13-1
signon-kwallet-extension-22.12.1-1 slang-2.3.3-2 smbclient-4.17.4-4
sof-firmware-2.2.4-1 solid-5.102.0-1 sonnet-5.102.0-1 spandsp-0.0.6-4
spdlog-1.11.0-2 spirv-tools-2022.4-1 sqlite-3.40.1-1 suitesparse-6.0.3-1
svt-av1-1.4.1-1 systemd-252.4-2 systemd-libs-252.4-2 systemd-sysvcompat-252.4-2
texinfo-7.0.1-1 threadweaver-5.102.0-1 thunar-4.18.2-1 thunar-volman-4.18.0-1
tor-0.4.7.13-1 torbrowser-launcher-0.3.6-1 tracker3-3.4.2-1
ttf-bitstream-vera-1.10-15 tumbler-4.18.0-1 unrar-1:6.2.3-1 usbutils-015-2
virglrenderer-0.10.4-1 vlc-3.0.18-6 vte-common-0.70.2-1 vte3-0.70.2-1
vulkan-mesa-layers-22.3.3-1 vulkan-radeon-22.3.3-1 wavpack-5.6.0-1
webkit2gtk-2.38.3-1 webkit2gtk-4.1-2.38.3-1 welcome-3.45-1 whois-5.5.15-1
wildmidi-0.4.5-1 wireplumber-0.4.13-1 wolfssl-5.5.4-1 wpa_supplicant-2:2.10-8
xapp-2.4.2-1 xcb-util-0.4.1-1 xfce4-appfinder-4.18.0-1
xfce4-datetime-plugin-0.8.3-1 xfce4-notifyd-0.6.5-1 xfce4-panel-4.18.1-1
xfce4-power-manager-4.18.0-1 xfce4-screenshooter-1.10.3-1 xfce4-session-4.18.0-1
xfce4-settings-4.18.1-1 xfce4-taskmanager-1.5.5-1 xfconf-4.18.0-1
xfdesktop-4.18.0-1 xfsprogs-6.1.1-2 xfwm4-4.18.0-1 xorg-server-21.1.6-1
xorg-server-common-21.1.6-1 xorg-xhost-1.0.9-1 xorg-xinit-1.4.2-1
xorg-xkbcomp-1.4.6-1 xorg-xprop-1.2.6-1 xorg-xrandr-1.5.2-1 xorg-xset-1.2.5-1
xz-5.4.1-1 yad-eos-12.3-1 yay-11.3.2-1 zvbi-0.2.39-1 zxing-cpp-2.0.0-1
Total Download Size: 1708.26 MiB
Total Installed Size: 5420.01 MiB
Net Upgrade Size: 82.84 MiB
linux-6.1.6.arch1-1-x86_64 145.9 MiB 1825 KiB/s 01:22 [--------------------------------] 100%
linux-hardened-6.1.6.harde... 73.1 MiB 486 KiB/s 02:34 [--------------------------------] 100%
rust-1:1.66.1-1-x86_64 91.4 MiB 883 KiB/s 01:46 [--------------------------------] 100%
go-2:1.19.5-1-x86_64 76.7 MiB 1065 KiB/s 01:14 [--------------------------------] 100%
firefox-108.0.2-1-x86_64 64.1 MiB 1339 KiB/s 00:49 [--------------------------------] 100%
linux-firmware-20221214.f3... 136.3 MiB 607 KiB/s 03:50 [--------------------------------] 100%
linux-zen-headers-6.1.6.ze... 27.4 MiB 1246 KiB/s 00:23 [--------------------------------] 100%
linux-headers-6.1.6.arch1-... 26.8 MiB 815 KiB/s 00:34 [--------------------------------] 100%
qt5-webengine-5.15.12-2-x86_64 48.7 MiB 669 KiB/s 01:15 [--------------------------------] 100%
webkit2gtk-4.1-2.38.3-1-x86_64 24.0 MiB 767 KiB/s 00:32 [--------------------------------] 100%
webkit2gtk-2.38.3-1-x86_64 24.0 MiB 1192 KiB/s 00:21 [--------------------------------] 100%
electron19-19.1.9-3-x86_64 54.8 MiB 490 KiB/s 01:55 [--------------------------------] 100%
dotnet-runtime-6.0-6.0.13.... 22.0 MiB 1200 KiB/s 00:19 [--------------------------------] 100%
suitesparse-6.0.3-1-x86_64 20.8 MiB 1103 KiB/s 00:19 [--------------------------------] 100%
dotnet-runtime-7.0.2.sdk10... 22.8 MiB 806 KiB/s 00:29 [--------------------------------] 100%
gimp-2.10.32-3-x86_64 20.1 MiB 1755 KiB/s 00:12 [--------------------------------] 100%
code-1.74.3-1-x86_64 14.1 MiB 1014 KiB/s 00:14 [--------------------------------] 100%
ghostscript-10.0.0-4-x86_64 15.4 MiB 912 KiB/s 00:17 [--------------------------------] 100%
perl-5.36.0-3-x86_64 15.6 MiB 592 KiB/s 00:27 [--------------------------------] 100%
qt6-base-6.4.2-1-x86_64 12.8 MiB 1110 KiB/s 00:12 [--------------------------------] 100%
qt5-base-5.15.8+kde+r162-1... 13.0 MiB 811 KiB/s 00:16 [--------------------------------] 100%
python-3.10.9-1-x86_64 12.0 MiB 915 KiB/s 00:13 [--------------------------------] 100%
endeavouros-theming-22.12.... 11.8 MiB 874 KiB/s 00:14 [--------------------------------] 100%
vlc-3.0.18-6-x86_64 11.5 MiB 1024 KiB/s 00:12 [--------------------------------] 100%
lib32-mesa-22.3.3-1-x86_64 10.2 MiB 1954 KiB/s 00:05 [--------------------------------] 100%
libreoffice-still-7.3.7-2-... 113.6 MiB 273 KiB/s 07:05 [--------------------------------] 100%
mesa-22.3.3-1-x86_64 10.5 MiB 1140 KiB/s 00:09 [--------------------------------] 100%
libvirt-1:8.10.0-1-x86_64 8.0 MiB 1593 KiB/s 00:05 [--------------------------------] 100%
gtk3-1:3.24.36-1-x86_64 7.7 MiB 1821 KiB/s 00:04 [--------------------------------] 100%
kio-5.102.0-1-x86_64 8.2 MiB 1312 KiB/s 00:06 [--------------------------------] 100%
qt6-declarative-6.4.2-1-x86_64 10.8 MiB 615 KiB/s 00:18 [--------------------------------] 100%
binutils-2.39-4-x86_64 6.9 MiB 2.18 MiB/s 00:03 [--------------------------------] 100%
okular-22.12.1-1-x86_64 7.1 MiB 1494 KiB/s 00:05 [--------------------------------] 100%
grub-2:2.06.r415.g1a241e05... 6.8 MiB 863 KiB/s 00:08 [--------------------------------] 100%
smbclient-4.17.4-4-x86_64 6.7 MiB 1293 KiB/s 00:05 [--------------------------------] 100%
systemd-252.4-2-x86_64 7.4 MiB 768 KiB/s 00:10 [--------------------------------] 100%
qt5-tools-5.15.8+kde+r1-1-... 5.3 MiB 2.70 MiB/s 00:02 [--------------------------------] 100%
man-pages-6.02-1-any 5.5 MiB 2.03 MiB/s 00:03 [--------------------------------] 100%
qt5-declarative-5.15.8+kde... 4.8 MiB 2001 KiB/s 00:02 [--------------------------------] 100%
qemu-system-x86-7.2.0-1-x86_64 5.7 MiB 980 KiB/s 00:06 [--------------------------------] 100%
openssl-3.0.7-4-x86_64 5.1 MiB 1459 KiB/s 00:04 [--------------------------------] 100%
git-2.39.0-1-x86_64 6.6 MiB 844 KiB/s 00:08 [--------------------------------] 100%
graphviz-7.0.6-1-x86_64 3.6 MiB 2.19 MiB/s 00:02 [--------------------------------] 100%
glib2-2.74.4-1-x86_64 3.7 MiB 1501 KiB/s 00:03 [--------------------------------] 100%
plasma-framework-5.102.0-1... 4.0 MiB 1260 KiB/s 00:03 [--------------------------------] 100%
kwidgetsaddons-5.102.0-1-x... 4.8 MiB 1301 KiB/s 00:04 [--------------------------------] 100%
kwayland-5.102.0-1-x86_64 3.1 MiB 2.02 MiB/s 00:02 [--------------------------------] 100%
geoip-database-20221227-1-any 3.1 MiB 1600 KiB/s 00:02 [--------------------------------] 100%
gegl-0.4.40-4-x86_64 3.1 MiB 1277 KiB/s 00:02 [--------------------------------] 100%
networkmanager-1.40.10-1-x... 3.5 MiB 827 KiB/s 00:04 [--------------------------------] 100%
elementary-icon-theme-7.1.... 2.6 MiB 2.16 MiB/s 00:01 [--------------------------------] 100%
tor-0.4.7.13-1-x86_64 2.7 MiB 1892 KiB/s 00:01 [--------------------------------] 100%
imagemagick-7.1.0.57-2-x86_64 2.9 MiB 1498 KiB/s 00:02 [--------------------------------] 100%
glslang-11.13.0-2-x86_64 3.0 MiB 1279 KiB/s 00:02 [--------------------------------] 100%
yay-11.3.2-1-x86_64 2.5 MiB 1340 KiB/s 00:02 [--------------------------------] 100%
gst-plugins-base-libs-1.20... 2.1 MiB 1083 KiB/s 00:02 [--------------------------------] 100%
gst-plugins-bad-libs-1.20.... 2.1 MiB 765 KiB/s 00:03 [--------------------------------] 100%
vulkan-radeon-22.3.3-1-x86_64 2.1 MiB 2.28 MiB/s 00:01 [--------------------------------] 100%
lib32-vulkan-radeon-22.3.3... 2.2 MiB 672 KiB/s 00:03 [--------------------------------] 100%
libx11-1.8.3-5-x86_64 2.0 MiB 264 KiB/s 00:08 [--------------------------------] 100%
svt-av1-1.4.1-1-x86_64 2047.2 KiB 340 KiB/s 00:06 [--------------------------------] 100%
qemu-img-7.2.0-1-x86_64 2.0 MiB 347 KiB/s 00:06 [--------------------------------] 100%
gst-plugins-good-1.20.5-5-... 2010.2 KiB 266 KiB/s 00:08 [--------------------------------] 100%
pinta-2.1-1-any 2008.0 KiB 193 KiB/s 00:10 [--------------------------------] 100%
qemu-common-7.2.0-1-x86_64 1971.6 KiB 507 KiB/s 00:04 [--------------------------------] 100%
bind-9.18.10-1-x86_64 1972.9 KiB 262 KiB/s 00:08 [--------------------------------] 100%
ki18n-5.102.0-1-x86_64 1978.3 KiB 246 KiB/s 00:08 [--------------------------------] 100%
qt5-translations-5.15.8-1-any 1929.2 KiB 704 KiB/s 00:03 [--------------------------------] 100%
python-pydantic-1.10.4-1-x... 1869.5 KiB 871 KiB/s 00:02 [--------------------------------] 100%
lvm2-2.03.18-1-x86_64 1906.7 KiB 696 KiB/s 00:03 [--------------------------------] 100%
libwmf-0.2.12-3-x86_64 1876.7 KiB 766 KiB/s 00:02 [--------------------------------] 100%
cython-0.29.33-1-x86_64 1926.0 KiB 620 KiB/s 00:03 [--------------------------------] 100%
kxmlgui-5.102.0-1-x86_64 1741.9 KiB 1100 KiB/s 00:02 [--------------------------------] 100%
qt6-translations-6.4.2-1-any 1734.4 KiB 999 KiB/s 00:02 [--------------------------------] 100%
ntp-4.2.8.p15-3-x86_64 1827.9 KiB 718 KiB/s 00:03 [--------------------------------] 100%
gstreamer-1.20.5-5-x86_64 1813.6 KiB 756 KiB/s 00:02 [--------------------------------] 100%
linux-zen-6.1.6.zen1-1-x86_64 149.0 MiB 304 KiB/s 08:22 [--------------------------------] 100%
wpa_supplicant-2:2.10-8-x86_64 1659.8 KiB 1158 KiB/s 00:01 [--------------------------------] 100%
texinfo-7.0.1-1-x86_64 1592.3 KiB 1052 KiB/s 00:02 [--------------------------------] 100%
nss-3.87-1-x86_64 1581.8 KiB 957 KiB/s 00:02 [--------------------------------] 100%
sqlite-3.40.1-1-x86_64 1606.1 KiB 935 KiB/s 00:02 [--------------------------------] 100%
hwdata-0.366-1-any 1567.8 KiB 1458 KiB/s 00:01 [--------------------------------] 100%
rav1e-0.6.3-1-x86_64 1564.2 KiB 3.30 MiB/s 00:00 [--------------------------------] 100%
qt5-quickcontrols2-5.15.8+... 1550.2 KiB 1874 KiB/s 00:01 [--------------------------------] 100%
poppler-23.01.0-3-x86_64 1564.1 KiB 1529 KiB/s 00:01 [--------------------------------] 100%
libetonyek-0.1.10-3-x86_64 1508.6 KiB 1103 KiB/s 00:01 [--------------------------------] 100%
thunar-4.18.2-1-x86_64 1483.8 KiB 1312 KiB/s 00:01 [--------------------------------] 100%
xorg-server-21.1.6-1-x86_64 1476.8 KiB 2045 KiB/s 00:01 [--------------------------------] 100%
xfdesktop-4.18.0-1-x86_64 1400.0 KiB 945 KiB/s 00:01 [--------------------------------] 100%
spirv-tools-2022.4-1-x86_64 1448.5 KiB 941 KiB/s 00:02 [--------------------------------] 100%
kcoreaddons-5.102.0-1-x86_64 1381.8 KiB 811 KiB/s 00:02 [--------------------------------] 100%
db-6.2.32-1-x86_64 1360.3 KiB 610 KiB/s 00:02 [--------------------------------] 100%
modemmanager-1.20.4-1-x86_64 1323.2 KiB 742 KiB/s 00:02 [--------------------------------] 100%
ripgrep-13.0.0-3-x86_64 1312.0 KiB 1284 KiB/s 00:01 [--------------------------------] 100%
netpbm-10.73.42-2-x86_64 1268.0 KiB 634 KiB/s 00:02 [--------------------------------] 100%
krb5-1.20.1-1-x86_64 1271.1 KiB 549 KiB/s 00:02 [--------------------------------] 100%
libtiff-4.5.0-1-x86_64 1262.4 KiB 534 KiB/s 00:02 [--------------------------------] 100%
qt5-location-5.15.8+kde+r3... 1204.6 KiB 845 KiB/s 00:01 [--------------------------------] 100%
db5.3-5.3.28-2-x86_64 1229.3 KiB 478 KiB/s 00:03 [--------------------------------] 100%
libopenraw-0.3.3-1-x86_64 1199.9 KiB 935 KiB/s 00:01 [--------------------------------] 100%
shadow-4.13-1-x86_64 1196.2 KiB 747 KiB/s 00:02 [--------------------------------] 100%
kconfig-5.102.0-1-x86_64 1192.6 KiB 1129 KiB/s 00:01 [--------------------------------] 100%
gst-plugins-bad-1.20.5-5-x... 1184.9 KiB 1353 KiB/s 00:01 [--------------------------------] 100%
curl-7.87.0-3-x86_64 1178.0 KiB 1239 KiB/s 00:01 [--------------------------------] 100%
ncurses-6.4-1-x86_64 1182.1 KiB 886 KiB/s 00:01 [--------------------------------] 100%
archlinux-keyring-20221220... 1153.7 KiB 782 KiB/s 00:01 [--------------------------------] 100%
kconfigwidgets-5.102.0-1-x... 1161.5 KiB 704 KiB/s 00:02 [--------------------------------] 100%
lib32-nss-3.87-1-x86_64 1151.1 KiB 951 KiB/s 00:01 [--------------------------------] 100%
libnm-1.40.10-1-x86_64 1127.2 KiB 2035 KiB/s 00:01 [--------------------------------] 100%
libgusb-0.4.3-1-x86_64 1122.8 KiB 1620 KiB/s 00:01 [--------------------------------] 100%
qt5-wayland-5.15.8+kde+r57... 1121.5 KiB 2.01 MiB/s 00:01 [--------------------------------] 100%
iproute2-6.1.0-3-x86_64 1113.1 KiB 1346 KiB/s 00:01 [--------------------------------] 100%
man-db-2.11.2-1-x86_64 1110.5 KiB 1493 KiB/s 00:01 [--------------------------------] 100%
harfbuzz-6.0.0-1-x86_64 1048.9 KiB 1939 KiB/s 00:01 [--------------------------------] 100%
kparts-5.102.0-1-x86_64 1036.2 KiB 1793 KiB/s 00:01 [--------------------------------] 100%
xfsprogs-6.1.1-2-x86_64 1029.9 KiB 2035 KiB/s 00:01 [--------------------------------] 100%
firewalld-1.3.0-1-any 1025.5 KiB 1384 KiB/s 00:01 [--------------------------------] 100%
gvfs-1.50.3-1-x86_64 1021.6 KiB 1087 KiB/s 00:01 [--------------------------------] 100%
hwinfo-22.2-1-x86_64 1018.7 KiB 1264 KiB/s 00:01 [--------------------------------] 100%
pipewire-1:0.3.64-1-x86_64 1007.7 KiB 1297 KiB/s 00:01 [--------------------------------] 100%
sdl2-2.26.2-1-x86_64 987.3 KiB 1097 KiB/s 00:01 [--------------------------------] 100%
mbedtls-2.28.2-1-x86_64 985.8 KiB 899 KiB/s 00:01 [--------------------------------] 100%
gnome-boxes-43.2-1-x86_64 962.0 KiB 1344 KiB/s 00:01 [--------------------------------] 100%
btrfs-progs-6.1.2-1-x86_64 953.9 KiB 1206 KiB/s 00:01 [--------------------------------] 100%
djvulibre-3.5.28-4-x86_64 958.9 KiB 1043 KiB/s 00:01 [--------------------------------] 100%
openjpeg2-2.5.0-2-x86_64 928.5 KiB 1207 KiB/s 00:01 [--------------------------------] 100%
qt5-quickcontrols-5.15.8-1... 928.1 KiB 1886 KiB/s 00:00 [--------------------------------] 100%
libbluray-1.3.4-1-x86_64 902.0 KiB 1776 KiB/s 00:01 [--------------------------------] 100%
xfce4-settings-4.18.1-1-x86_64 889.1 KiB 1892 KiB/s 00:00 [--------------------------------] 100%
ktextwidgets-5.102.0-1-x86_64 860.3 KiB 1874 KiB/s 00:00 [--------------------------------] 100%
pipewire-audio-1:0.3.64-1-... 860.2 KiB 1973 KiB/s 00:00 [--------------------------------] 100%
lib32-krb5-1.20.1-1-x86_64 849.5 KiB 1922 KiB/s 00:00 [--------------------------------] 100%
libgit2-1:1.5.0-2-x86_64 847.7 KiB 1602 KiB/s 00:01 [--------------------------------] 100%
wolfssl-5.5.4-1-x86_64 843.6 KiB 1565 KiB/s 00:01 [--------------------------------] 100%
solid-5.102.0-1-x86_64 838.8 KiB 1626 KiB/s 00:01 [--------------------------------] 100%
libcamera-0.0.3-3-x86_64 837.6 KiB 1523 KiB/s 00:01 [--------------------------------] 100%
kwindowsystem-5.102.0-1-x86_64 837.1 KiB 1210 KiB/s 00:01 [--------------------------------] 100%
slang-2.3.3-2-x86_64 826.1 KiB 1735 KiB/s 00:00 [--------------------------------] 100%
xfce4-panel-4.18.1-1-x86_64 786.4 KiB 1763 KiB/s 00:00 [--------------------------------] 100%
libmm-glib-1.20.4-1-x86_64 786.2 KiB 2026 KiB/s 00:00 [--------------------------------] 100%
qt5-multimedia-5.15.8+kde+... 763.0 KiB 1817 KiB/s 00:00 [--------------------------------] 100%
clucene-2.3.3.4-13-x86_64 748.4 KiB 1603 KiB/s 00:00 [--------------------------------] 100%
kservice-5.102.0-1-x86_64 736.1 KiB 1487 KiB/s 00:00 [--------------------------------] 100%
kcmutils-5.102.0-1-x86_64 727.7 KiB 1500 KiB/s 00:00 [--------------------------------] 100%
libopenmpt-0.6.7-1-x86_64 687.7 KiB 1512 KiB/s 00:00 [--------------------------------] 100%
tracker3-3.4.2-1-x86_64 686.9 KiB 1279 KiB/s 00:01 [--------------------------------] 100%
sonnet-5.102.0-1-x86_64 671.4 KiB 1286 KiB/s 00:01 [--------------------------------] 100%
lib32-sqlite-3.40.1-1-x86_64 669.1 KiB 1720 KiB/s 00:00 [--------------------------------] 100%
lib32-systemd-252.4-1-x86_64 653.2 KiB 2.01 MiB/s 00:00 [--------------------------------] 100%
sof-firmware-2.2.4-1-x86_64 646.4 KiB 1390 KiB/s 00:00 [--------------------------------] 100%
lib32-libx11-1.8.3-1-x86_64 632.8 KiB 3.36 MiB/s 00:00 [--------------------------------] 100%
systemd-libs-252.4-2-x86_64 641.9 KiB 1061 KiB/s 00:01 [--------------------------------] 100%
kcompletion-5.102.0-1-x86_64 624.6 KiB 1432 KiB/s 00:00 [--------------------------------] 100%
kirigami2-5.102.0-1-x86_64 618.1 KiB 1267 KiB/s 00:00 [--------------------------------] 100%
libical-3.0.16-4-x86_64 614.2 KiB 883 KiB/s 00:01 [--------------------------------] 100%
nano-7.1-1-x86_64 598.2 KiB 1671 KiB/s 00:00 [--------------------------------] 100%
kbookmarks-5.102.0-1-x86_64 595.9 KiB 2.20 MiB/s 00:00 [--------------------------------] 100%
kwallet-5.102.0-1-x86_64 577.4 KiB 1462 KiB/s 00:00 [--------------------------------] 100%
zxing-cpp-2.0.0-1-x86_64 570.9 KiB 1071 KiB/s 00:01 [--------------------------------] 100%
librevenge-0.0.5-2-x86_64 569.1 KiB 934 KiB/s 00:01 [--------------------------------] 100%
imlib2-1.10.0-2-x86_64 561.2 KiB 1871 KiB/s 00:00 [--------------------------------] 100%
iwd-2.1-1-x86_64 560.5 KiB 2.36 MiB/s 00:00 [--------------------------------] 100%
kiconthemes-5.102.0-1-x86_64 526.6 KiB 1651 KiB/s 00:00 [--------------------------------] 100%
xfce4-power-manager-4.18.0... 545.1 KiB 1522 KiB/s 00:00 [--------------------------------] 100%
libarchive-3.6.2-2-x86_64 522.3 KiB 1128 KiB/s 00:00 [--------------------------------] 100%
make-4.4-1-x86_64 519.2 KiB 1564 KiB/s 00:00 [--------------------------------] 100%
gdk-pixbuf2-2.42.10-2-x86_64 516.7 KiB 2.10 MiB/s 00:00 [--------------------------------] 100%
xz-5.4.1-1-x86_64 511.5 KiB 1619 KiB/s 00:00 [--------------------------------] 100%
kitemviews-5.102.0-1-x86_64 516.1 KiB 1144 KiB/s 00:00 [--------------------------------] 100%
kdeclarative-5.102.0-1-x86_64 505.8 KiB 1076 KiB/s 00:00 [--------------------------------] 100%
wavpack-5.6.0-1-x86_64 494.6 KiB 2.18 MiB/s 00:00 [--------------------------------] 100%
xfwm4-4.18.0-1-x86_64 493.6 KiB 2.66 MiB/s 00:00 [--------------------------------] 100%
fmt-9.1.0-4-x86_64 462.4 KiB 2028 KiB/s 00:00 [--------------------------------] 100%
knotifications-5.102.0-1-x... 487.2 KiB 1408 KiB/s 00:00 [--------------------------------] 100%
threadweaver-5.102.0-1-x86_64 461.9 KiB 1045 KiB/s 00:00 [--------------------------------] 100%
hunspell-1.7.2-1-x86_64 460.6 KiB 2.11 MiB/s 00:00 [--------------------------------] 100%
mpg123-1.31.2-1-x86_64 438.1 KiB 2.34 MiB/s 00:00 [--------------------------------] 100%
libraw-0.21.1-1-x86_64 450.0 KiB 1601 KiB/s 00:00 [--------------------------------] 100%
mpfr-4.2.0-1-x86_64 427.3 KiB 1074 KiB/s 00:00 [--------------------------------] 100%
spandsp-0.0.6-4-x86_64 424.1 KiB 763 KiB/s 00:01 [--------------------------------] 100%
qemu-tools-7.2.0-1-x86_64 420.2 KiB 1236 KiB/s 00:00 [--------------------------------] 100%
karchive-5.102.0-1-x86_64 407.9 KiB 933 KiB/s 00:00 [--------------------------------] 100%
dnsmasq-2.88-1-x86_64 408.8 KiB 854 KiB/s 00:00 [--------------------------------] 100%
iana-etc-20221215-1-any 395.6 KiB 1055 KiB/s 00:00 [--------------------------------] 100%
libplacebo-5.229.1-2-x86_64 392.7 KiB 1176 KiB/s 00:00 [--------------------------------] 100%
nftables-1:1.0.6-1-x86_64 386.5 KiB 1204 KiB/s 00:00 [--------------------------------] 100%
audit-3.0.9-1-x86_64 387.3 KiB 1041 KiB/s 00:00 [--------------------------------] 100%
kjs-5.102.0-1-x86_64 391.7 KiB 852 KiB/s 00:00 [--------------------------------] 100%
file-5.44-1-x86_64 385.2 KiB 778 KiB/s 00:00 [--------------------------------] 100%
libxfce4ui-4.18.1-1-x86_64 377.4 KiB 1001 KiB/s 00:00 [--------------------------------] 100%
zvbi-0.2.39-1-x86_64 374.3 KiB 1012 KiB/s 00:00 [--------------------------------] 100%
kcodecs-5.102.0-1-x86_64 363.8 KiB 1042 KiB/s 00:00 [--------------------------------] 100%
ndctl-75-1-x86_64 360.9 KiB 1168 KiB/s 00:00 [--------------------------------] 100%
kguiaddons-5.102.0-1-x86_64 358.1 KiB 923 KiB/s 00:00 [--------------------------------] 100%
libglvnd-1.6.0-1-x86_64 355.2 KiB 647 KiB/s 00:01 [--------------------------------] 100%
arc-gtk-theme-eos-20221218... 371.5 KiB 286 KiB/s 00:01 [--------------------------------] 100%
ca-certificates-mozilla-3.... 354.3 KiB 890 KiB/s 00:00 [--------------------------------] 100%
eos-apps-info-1.5-1-any 364.2 KiB 246 KiB/s 00:01 [--------------------------------] 100%
multipath-tools-0.9.4-1-x86_64 349.2 KiB 889 KiB/s 00:00 [--------------------------------] 100%
libwebp-1.3.0-2-x86_64 345.0 KiB 1058 KiB/s 00:00 [--------------------------------] 100%
purpose-5.102.0-1-x86_64 339.2 KiB 879 KiB/s 00:00 [--------------------------------] 100%
kpackage-5.102.0-1-x86_64 337.0 KiB 1221 KiB/s 00:00 [--------------------------------] 100%
lib32-vulkan-mesa-layers-2... 337.5 KiB 1058 KiB/s 00:00 [--------------------------------] 100%
xfce4-session-4.18.0-1-x86_64 336.1 KiB 1054 KiB/s 00:00 [--------------------------------] 100%
qemu-pr-helper-7.2.0-1-x86_64 330.8 KiB 1034 KiB/s 00:00 [--------------------------------] 100%
rsync-3.2.7-3-x86_64 336.0 KiB 1028 KiB/s 00:00 [--------------------------------] 100%
kactivities-5.102.0-1-x86_64 329.8 KiB 1486 KiB/s 00:00 [--------------------------------] 100%
kjobwidgets-5.102.0-1-x86_64 327.6 KiB 1040 KiB/s 00:00 [--------------------------------] 100%
gst-plugins-base-1.20.5-5-... 327.4 KiB 1359 KiB/s 00:00 [--------------------------------] 100%
kauth-5.102.0-1-x86_64 324.7 KiB 2.76 MiB/s 00:00 [--------------------------------] 100%
parallel-20221222-1-any 322.4 KiB 1295 KiB/s 00:00 [--------------------------------] 100%
luajit-2.1.0.beta3.r467.gd... 320.9 KiB 972 KiB/s 00:00 [--------------------------------] 100%
vulkan-mesa-layers-22.3.3-... 321.2 KiB 887 KiB/s 00:00 [--------------------------------] 100%
exo-4.18.0-1-x86_64 319.9 KiB 1022 KiB/s 00:00 [--------------------------------] 100%
libnice-0.1.21-1-x86_64 314.5 KiB 1052 KiB/s 00:00 [--------------------------------] 100%
libsndfile-1.2.0-1-x86_64 316.2 KiB 991 KiB/s 00:00 [--------------------------------] 100%
pahole-1:1.24+r29+g02d67c5... 313.0 KiB 1288 KiB/s 00:00 [--------------------------------] 100%
linux-atm-2.5.2-8-x86_64 312.3 KiB 1031 KiB/s 00:00 [--------------------------------] 100%
lua-5.4.4-3-x86_64 310.0 KiB 1111 KiB/s 00:00 [--------------------------------] 100%
device-mapper-2.03.18-1-x86_64 297.6 KiB 1626 KiB/s 00:00 [--------------------------------] 100%
inxi-3.3.24.1-4-any 302.9 KiB 1396 KiB/s 00:00 [--------------------------------] 100%
lib32-curl-7.87.0-1-x86_64 291.9 KiB 1397 KiB/s 00:00 [--------------------------------] 100%
vte3-0.70.2-1-x86_64 291.3 KiB 1019 KiB/s 00:00 [--------------------------------] 100%
poppler-glib-23.01.0-3-x86_64 289.3 KiB 1001 KiB/s 00:00 [--------------------------------] 100%
libpcap-1.10.3-1-x86_64 285.1 KiB 1371 KiB/s 00:00 [--------------------------------] 100%
kglobalaccel-5.102.0-1-x86_64 270.2 KiB 850 KiB/s 00:00 [--------------------------------] 100%
fluidsynth-2.3.1-1-x86_64 267.6 KiB 959 KiB/s 00:00 [--------------------------------] 100%
qemu-virtiofsd-7.2.0-1-x86_64 267.2 KiB 777 KiB/s 00:00 [--------------------------------] 100%
libheif-1.14.2-1-x86_64 264.7 KiB 1161 KiB/s 00:00 [--------------------------------] 100%
psmisc-23.6-1-x86_64 250.7 KiB 1194 KiB/s 00:00 [--------------------------------] 100%
ristretto-0.12.4-1-x86_64 245.9 KiB 1217 KiB/s 00:00 [--------------------------------] 100%
qemu-vhost-user-gpu-7.2.0-... 237.8 KiB 1062 KiB/s 00:00 [--------------------------------] 100%
ell-0.55-1-x86_64 236.3 KiB 1136 KiB/s 00:00 [--------------------------------] 100%
python-chardet-5.1.0-1-any 235.6 KiB 1155 KiB/s 00:00 [--------------------------------] 100%
kdbusaddons-5.102.0-1-x86_64 234.6 KiB 1325 KiB/s 00:00 [--------------------------------] 100%
ttf-bitstream-vera-1.10-15-any 232.5 KiB 1748 KiB/s 00:00 [--------------------------------] 100%
lib32-ncurses-6.4-1-x86_64 226.6 KiB 1542 KiB/s 00:00 [--------------------------------] 100%
virglrenderer-0.10.4-1-x86_64 224.0 KiB 953 KiB/s 00:00 [--------------------------------] 100%
poppler-qt5-23.01.0-3-x86_64 223.6 KiB 1003 KiB/s 00:00 [--------------------------------] 100%
gst-plugins-ugly-1.20.5-5-... 221.4 KiB 719 KiB/s 00:00 [--------------------------------] 100%
libwireplumber-0.4.13-1-x86_64 220.7 KiB 968 KiB/s 00:00 [--------------------------------] 100%
lcms2-2.14-2-x86_64 214.4 KiB 1246 KiB/s 00:00 [--------------------------------] 100%
yad-eos-12.3-1-x86_64 217.9 KiB 414 KiB/s 00:01 [--------------------------------] 100%
kpty-5.102.0-1-x86_64 211.5 KiB 377 KiB/s 00:01 [--------------------------------] 100%
wireplumber-0.4.13-1-x86_64 207.6 KiB 218 KiB/s 00:01 [--------------------------------] 100%
libxkbcommon-1.5.0-1-x86_64 203.2 KiB 202 KiB/s 00:01 [--------------------------------] 100%
lib32-libglvnd-1.6.0-1-x86_64 202.7 KiB 250 KiB/s 00:01 [--------------------------------] 100%
xapp-2.4.2-1-x86_64 202.3 KiB 236 KiB/s 00:01 [--------------------------------] 100%
jasper-4.0.0-1-x86_64 201.9 KiB 625 KiB/s 00:00 [--------------------------------] 100%
dialog-1:1.3_20221229-1-x86_64 200.1 KiB 744 KiB/s 00:00 [--------------------------------] 100%
osinfo-db-20221130-1-any 199.1 KiB 503 KiB/s 00:00 [--------------------------------] 100%
libnma-common-1.10.6-1-x86_64 192.1 KiB 480 KiB/s 00:00 [--------------------------------] 100%
ethtool-1:6.1-1-x86_64 193.8 KiB 394 KiB/s 00:00 [--------------------------------] 100%
xfconf-4.18.0-1-x86_64 184.2 KiB 700 KiB/s 00:00 [--------------------------------] 100%
libva-2.17.0-1-x86_64 183.2 KiB 814 KiB/s 00:00 [--------------------------------] 100%
spdlog-1.11.0-2-x86_64 183.5 KiB 672 KiB/s 00:00 [--------------------------------] 100%
xfce4-screenshooter-1.10.3... 182.1 KiB 582 KiB/s 00:00 [--------------------------------] 100%
duktape-2.7.0-5-x86_64 176.9 KiB 325 KiB/s 00:01 [--------------------------------] 100%
libmodplug-0.8.9.0-5-x86_64 166.9 KiB 409 KiB/s 00:00 [--------------------------------] 100%
tumbler-4.18.0-1-x86_64 165.4 KiB 701 KiB/s 00:00 [--------------------------------] 100%
garcon-4.18.0-1-x86_64 166.8 KiB 686 KiB/s 00:00 [--------------------------------] 100%
pipewire-pulse-1:0.3.64-1-... 164.2 KiB 451 KiB/s 00:00 [--------------------------------] 100%
xfce4-appfinder-4.18.0-1-x... 162.7 KiB 554 KiB/s 00:00 [--------------------------------] 100%
gd-2.3.3-6-x86_64 155.6 KiB 899 KiB/s 00:00 [--------------------------------] 100%
dotnet-host-7.0.2.sdk102-1... 158.1 KiB 815 KiB/s 00:00 [--------------------------------] 100%
re2-1:20221201-2-x86_64 159.5 KiB 693 KiB/s 00:00 [--------------------------------] 100%
shaderc-2022.4-1-x86_64 154.3 KiB 638 KiB/s 00:00 [--------------------------------] 100%
pipewire-jack-1:0.3.64-1-x... 149.3 KiB 1435 KiB/s 00:00 [--------------------------------] 100%
qt5-svg-5.15.8+kde+r8-1-x86_64 149.1 KiB 1331 KiB/s 00:00 [--------------------------------] 100%
libksba-1.6.3-1-x86_64 139.7 KiB 1154 KiB/s 00:00 [--------------------------------] 100%
unrar-1:6.2.3-1-x86_64 140.4 KiB 713 KiB/s 00:00 [--------------------------------] 100%
libkexiv2-22.12.1-1-x86_64 136.6 KiB 441 KiB/s 00:00 [--------------------------------] 100%
aalib-1.4rc5-15-x86_64 134.9 KiB 893 KiB/s 00:00 [--------------------------------] 100%
libxfce4util-4.18.1-1-x86_64 135.1 KiB 809 KiB/s 00:00 [--------------------------------] 100%
kcrash-5.102.0-1-x86_64 136.4 KiB 710 KiB/s 00:00 [--------------------------------] 100%
thunar-volman-4.18.0-1-x86_64 131.5 KiB 843 KiB/s 00:00 [--------------------------------] 100%
xfce4-notifyd-0.6.5-1-x86_64 133.9 KiB 687 KiB/s 00:00 [--------------------------------] 100%
gupnp-1:1.6.3-1-x86_64 123.9 KiB 1441 KiB/s 00:00 [--------------------------------] 100%
fuse3-3.13.0-1-x86_64 123.6 KiB 1490 KiB/s 00:00 [--------------------------------] 100%
kaccounts-integration-22.1... 123.9 KiB 1050 KiB/s 00:00 [--------------------------------] 100%
libomxil-bellagio-0.9.3-4-... 122.3 KiB 893 KiB/s 00:00 [--------------------------------] 100%
nilfs-utils-2.2.9-2-x86_64 116.0 KiB 535 KiB/s 00:00 [--------------------------------] 100%
xfce4-taskmanager-1.5.5-1-... 111.2 KiB 1309 KiB/s 00:00 [--------------------------------] 100%
lsof-4.96.5-1-x86_64 111.8 KiB 1270 KiB/s 00:00 [--------------------------------] 100%
libnma-1.10.6-1-x86_64 114.6 KiB 849 KiB/s 00:00 [--------------------------------] 100%
libass-0.17.0-1-x86_64 111.1 KiB 958 KiB/s 00:00 [--------------------------------] 100%
pciutils-3.9.0-2-x86_64 110.3 KiB 638 KiB/s 00:00 [--------------------------------] 100%
lib32-xz-5.4.1-1-x86_64 106.5 KiB 1638 KiB/s 00:00 [--------------------------------] 100%
python-cairo-1.23.0-2-x86_64 94.6 KiB 996 KiB/s 00:00 [--------------------------------] 100%
pcsclite-1.9.9-2-x86_64 96.3 KiB 972 KiB/s 00:00 [--------------------------------] 100%
gst-libav-1.20.5-5-x86_64 93.0 KiB 1094 KiB/s 00:00 [--------------------------------] 100%
wildmidi-0.4.5-1-x86_64 91.8 KiB 556 KiB/s 00:00 [--------------------------------] 100%
cifs-utils-7.0-2-x86_64 90.4 KiB 1329 KiB/s 00:00 [--------------------------------] 100%
xorg-xkbcomp-1.4.6-1-x86_64 89.9 KiB 927 KiB/s 00:00 [--------------------------------] 100%
usbutils-015-2-x86_64 88.2 KiB 873 KiB/s 00:00 [--------------------------------] 100%
libproxy-0.4.18-2-x86_64 86.6 KiB 1019 KiB/s 00:00 [--------------------------------] 100%
libmpc-1.3.1-1-x86_64 84.2 KiB 1053 KiB/s 00:00 [--------------------------------] 100%
libpsl-0.21.2-1-x86_64 81.8 KiB 1091 KiB/s 00:00 [--------------------------------] 100%
liblc3-1.0.1-1-x86_64 80.1 KiB 989 KiB/s 00:00 [--------------------------------] 100%
lib32-libtirpc-1.3.3-2-x86_64 80.2 KiB 743 KiB/s 00:00 [--------------------------------] 100%
libsoxr-0.1.3-3-x86_64 78.3 KiB 718 KiB/s 00:00 [--------------------------------] 100%
libice-1.1.1-1-x86_64 78.5 KiB 713 KiB/s 00:00 [--------------------------------] 100%
libxkbfile-1.1.2-1-x86_64 75.3 KiB 1046 KiB/s 00:00 [--------------------------------] 100%
qt5-webchannel-5.15.8+kde+... 75.0 KiB 1000 KiB/s 00:00 [--------------------------------] 100%
qt5-graphicaleffects-5.15.... 73.2 KiB 904 KiB/s 00:00 [--------------------------------] 100%
whois-5.5.15-1-x86_64 73.6 KiB 897 KiB/s 00:00 [--------------------------------] 100%
eos-translations-23-4-any 75.2 KiB 388 KiB/s 00:00 [--------------------------------] 100%
libsigc++-2.12.0-1-x86_64 68.2 KiB 588 KiB/s 00:00 [--------------------------------] 100%
mobile-broadband-provider-... 63.2 KiB 1003 KiB/s 00:00 [--------------------------------] 100%
sdl2_image-2.6.2-3-x86_64 66.0 KiB 815 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-dbus-7.2.0-1-x86_64 60.9 KiB 569 KiB/s 00:00 [--------------------------------] 100%
torbrowser-launcher-0.3.6-... 60.3 KiB 361 KiB/s 00:00 [--------------------------------] 100%
kded-5.102.0-1-x86_64 60.1 KiB 910 KiB/s 00:00 [--------------------------------] 100%
libmfx-22.6.4-1-x86_64 56.8 KiB 451 KiB/s 00:00 [--------------------------------] 100%
vte-common-0.70.2-1-x86_64 56.8 KiB 710 KiB/s 00:00 [--------------------------------] 100%
eos-quickstart-1.3.1-1-x86_64 51.9 KiB 374 KiB/s 00:00 [--------------------------------] 100%
gvfs-mtp-1.50.3-1-x86_64 48.8 KiB 346 KiB/s 00:00 [--------------------------------] 100%
qt5-speech-5.15.8+kde+r1-1... 49.2 KiB 266 KiB/s 00:00 [--------------------------------] 100%
gvfs-gphoto2-1.50.3-1-x86_64 48.2 KiB 669 KiB/s 00:00 [--------------------------------] 100%
mkinitcpio-34-2-any 47.4 KiB 687 KiB/s 00:00 [--------------------------------] 100%
logrotate-3.21.0-2-x86_64 47.4 KiB 470 KiB/s 00:00 [--------------------------------] 100%
gst-plugin-pipewire-1:0.3.... 46.7 KiB 530 KiB/s 00:00 [--------------------------------] 100%
a52dec-0.7.4-12-x86_64 45.8 KiB 243 KiB/s 00:00 [--------------------------------] 100%
libsm-1.2.4-1-x86_64 45.9 KiB 210 KiB/s 00:00 [--------------------------------] 100%
eos-bash-shared-1.41-1-any 46.1 KiB 195 KiB/s 00:00 [--------------------------------] 100%
libcddb-1.3.2-7-x86_64 45.7 KiB 299 KiB/s 00:00 [--------------------------------] 100%
chromaprint-1.5.1-6-x86_64 45.5 KiB 248 KiB/s 00:00 [--------------------------------] 100%
gvfs-afc-1.50.3-1-x86_64 43.6 KiB 545 KiB/s 00:00 [--------------------------------] 100%
pacman-contrib-1.8.2-1-x86_64 42.5 KiB 532 KiB/s 00:00 [--------------------------------] 100%
qrencode-4.1.1-2-x86_64 39.9 KiB 449 KiB/s 00:00 [--------------------------------] 100%
xfce4-datetime-plugin-0.8.... 38.3 KiB 468 KiB/s 00:00 [--------------------------------] 100%
xorg-xrandr-1.5.2-1-x86_64 36.5 KiB 263 KiB/s 00:00 [--------------------------------] 100%
libxv-1.0.12-1-x86_64 35.5 KiB 326 KiB/s 00:00 [--------------------------------] 100%
amd-ucode-20221214.f3c283e... 35.3 KiB 491 KiB/s 00:00 [--------------------------------] 100%
endeavouros-skel-xfce4-3.3... 35.5 KiB 338 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-qxl-7.2.0-... 35.0 KiB 310 KiB/s 00:00 [--------------------------------] 100%
libwbclient-4.17.4-4-x86_64 35.1 KiB 212 KiB/s 00:00 [--------------------------------] 100%
welcome-3.45-1-any 34.0 KiB 373 KiB/s 00:00 [--------------------------------] 100%
libiec61883-1.2.0-7-x86_64 32.7 KiB 355 KiB/s 00:00 [--------------------------------] 100%
libraqm-0.10.0-1-x86_64 32.3 KiB 333 KiB/s 00:00 [--------------------------------] 100%
grub-btrfs-4.12-2-any 33.8 KiB 194 KiB/s 00:00 [--------------------------------] 100%
python-distro-1.8.0-2-any 31.8 KiB 227 KiB/s 00:00 [--------------------------------] 100%
libspectre-0.2.12-1-x86_64 30.7 KiB 472 KiB/s 00:00 [--------------------------------] 100%
gnu-netcat-0.7.1-9-x86_64 29.8 KiB 403 KiB/s 00:00 [--------------------------------] 100%
linux-firmware-whence-2022... 29.7 KiB 349 KiB/s 00:00 [--------------------------------] 100%
gvfs-smb-1.50.3-1-x86_64 29.6 KiB 349 KiB/s 00:00 [--------------------------------] 100%
hidapi-0.13.1-1-x86_64 29.6 KiB 215 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-gtk-7.2.0-1-x86_64 28.6 KiB 340 KiB/s 00:00 [--------------------------------] 100%
alsa-card-profiles-1:0.3.6... 27.6 KiB 341 KiB/s 00:00 [--------------------------------] 100%
xorg-server-common-21.1.6-... 27.8 KiB 319 KiB/s 00:00 [--------------------------------] 100%
xorg-xprop-1.2.6-1-x86_64 25.4 KiB 229 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-gpu... 24.6 KiB 286 KiB/s 00:00 [--------------------------------] 100%
libxkbcommon-x11-1.5.0-1-x... 22.5 KiB 239 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-usb-redirect-7.2.0... 24.3 KiB 256 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-spice-core-7.2.0-1... 24.4 KiB 154 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-usb-host-7.2.0-1-x... 22.3 KiB 191 KiB/s 00:00 [--------------------------------] 100%
libkeybinder3-0.3.2-4-x86_64 20.7 KiB 232 KiB/s 00:00 [--------------------------------] 100%
gvfs-nfs-1.50.3-1-x86_64 21.2 KiB 235 KiB/s 00:00 [--------------------------------] 100%
http-parser-2.9.4-1-x86_64 21.8 KiB 180 KiB/s 00:00 [--------------------------------] 100%
perl-lwp-mediatypes-6.04-3-any 19.4 KiB 220 KiB/s 00:00 [--------------------------------] 100%
eos-log-tool-1.14-4-any 20.1 KiB 165 KiB/s 00:00 [--------------------------------] 100%
xorg-xset-1.2.5-1-x86_64 19.1 KiB 265 KiB/s 00:00 [--------------------------------] 100%
qemu-system-x86-firmware-7... 18.1 KiB 192 KiB/s 00:00 [--------------------------------] 100%
endeavouros-skel-default-1... 17.5 KiB 165 KiB/s 00:00 [--------------------------------] 100%
xorg-xinit-1.4.2-1-x86_64 17.2 KiB 218 KiB/s 00:00 [--------------------------------] 100%
eos-hooks-1.10-1-any 17.1 KiB 173 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-sdl-7.2.0-1-x86_64 16.9 KiB 188 KiB/s 00:00 [--------------------------------] 100%
qemu-block-ssh-7.2.0-1-x86_64 16.8 KiB 164 KiB/s 00:00 [--------------------------------] 100%
libfontenc-1.1.7-1-x86_64 15.4 KiB 227 KiB/s 00:00 [--------------------------------] 100%
gtk-update-icon-cache-1:4.... 16.3 KiB 203 KiB/s 00:00 [--------------------------------] 100%
eos-packagelist-2.1-1-any 15.2 KiB 131 KiB/s 00:00 [--------------------------------] 100%
qt5-x11extras-5.15.8-1-x86_64 14.8 KiB 227 KiB/s 00:00 [--------------------------------] 100%
python-trove-classifiers-2... 14.4 KiB 153 KiB/s 00:00 [--------------------------------] 100%
python-setproctitle-1.3.2-... 14.4 KiB 135 KiB/s 00:00 [--------------------------------] 100%
signon-kwallet-extension-2... 14.0 KiB 145 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-curses-7.2.0-1-x86_64 13.8 KiB 186 KiB/s 00:00 [--------------------------------] 100%
eos-lightdm-slick-theme-3.... 13.8 KiB 109 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-gpu... 13.7 KiB 191 KiB/s 00:00 [--------------------------------] 100%
endeavouros-xfce4-terminal... 13.5 KiB 208 KiB/s 00:00 [--------------------------------] 100%
endeavouros-mirrorlist-4.1... 13.5 KiB 193 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-usb-smartcard-7.2.... 13.5 KiB 136 KiB/s 00:00 [--------------------------------] 100%
qemu-block-curl-7.2.0-1-x86_64 13.4 KiB 187 KiB/s 00:00 [--------------------------------] 100%
qemu-block-nfs-7.2.0-1-x86_64 12.9 KiB 192 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-opengl-7.2.0-1-x86_64 12.5 KiB 129 KiB/s 00:00 [--------------------------------] 100%
xcb-util-0.4.1-1-x86_64 12.4 KiB 197 KiB/s 00:00 [--------------------------------] 100%
perl-www-robotrules-6.02-1... 12.3 KiB 140 KiB/s 00:00 [--------------------------------] 100%
xorg-xhost-1.0.9-1-x86_64 12.0 KiB 148 KiB/s 00:00 [--------------------------------] 100%
perl-http-negotiate-6.01-1... 12.3 KiB 119 KiB/s 00:00 [--------------------------------] 100%
libxcomposite-0.4.6-1-x86_64 11.6 KiB 166 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-dbus-7.2.0-1-x86_64 11.5 KiB 160 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-alsa-7.2.0-1-x86_64 11.9 KiB 134 KiB/s 00:00 [--------------------------------] 100%
webp-pixbuf-loader-0.0.7-1... 11.1 KiB 121 KiB/s 00:00 [--------------------------------] 100%
perl-html-tagset-3.20-13-any 11.0 KiB 87.3 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-pa-7.2.0-1-x86_64 10.8 KiB 141 KiB/s 00:00 [--------------------------------] 100%
libxau-1.0.11-1-x86_64 10.9 KiB 124 KiB/s 00:00 [--------------------------------] 100%
perl-encode-locale-1.05-10-any 10.8 KiB 120 KiB/s 00:00 [--------------------------------] 100%
python-termcolor-2.2.0-1-any 10.5 KiB 141 KiB/s 00:00 [--------------------------------] 100%
libxres-1.2.2-1-x86_64 10.4 KiB 155 KiB/s 00:00 [--------------------------------] 100%
lib32-libxdmcp-1.1.4-1-x86_64 10.2 KiB 109 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-oss-7.2.0-1-x86_64 9.9 KiB 153 KiB/s 00:00 [--------------------------------] 100%
perl-http-date-6.05-6-any 9.7 KiB 129 KiB/s 00:00 [--------------------------------] 100%
qemu-chardev-spice-7.2.0-1... 9.6 KiB 90.6 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-jack-7.2.0-1-x86_64 9.6 KiB 147 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-spice-app-7.2.0-1-... 7.9 KiB 130 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-sdl-7.2.0-1-x86_64 8.5 KiB 123 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-vga... 8.0 KiB 65.1 KiB/s 00:00 [--------------------------------] 100%
harfbuzz-icu-6.0.0-1-x86_64 7.8 KiB 137 KiB/s 00:00 [--------------------------------] 100%
pacman-mirrorlist-20221204... 7.8 KiB 116 KiB/s 00:00 [--------------------------------] 100%
qemu-ui-egl-headless-7.2.0... 7.5 KiB 123 KiB/s 00:00 [--------------------------------] 100%
qemu-audio-spice-7.2.0-1-x... 7.6 KiB 110 KiB/s 00:00 [--------------------------------] 100%
libxdamage-1.1.6-1-x86_64 7.2 KiB 98.7 KiB/s 00:00 [--------------------------------] 100%
lib32-libxau-1.0.11-1-x86_64 7.0 KiB 57.7 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-s390x-virtio-gpu-c... 6.3 KiB 88.5 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-gpu... 6.7 KiB 86.9 KiB/s 00:00 [--------------------------------] 100%
lib32-libxdamage-1.1.6-1-x... 6.2 KiB 85.5 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-vga... 6.1 KiB 47.8 KiB/s 00:00 [--------------------------------] 100%
systemd-sysvcompat-252.4-2... 6.1 KiB 52.9 KiB/s 00:00 [--------------------------------] 100%
qemu-hw-display-virtio-gpu... 5.9 KiB 102 KiB/s 00:00 [--------------------------------] 100%
libxshmfence-1.3.2-1-x86_64 5.7 KiB 96.8 KiB/s 00:00 [--------------------------------] 100%
qemu-block-dmg-7.2.0-1-x86_64 6.0 KiB 94.2 KiB/s 00:00 [--------------------------------] 100%
hwdetect-2023.01-1-any 5.6 KiB 42.9 KiB/s 00:00 [--------------------------------] 100%
qemu-desktop-7.2.0-1-x86_64 5.1 KiB 46.2 KiB/s 00:00 [--------------------------------] 100%
lib32-libxshmfence-1.3.2-1... 4.9 KiB 70.6 KiB/s 00:00 [--------------------------------] 100%
pipewire-alsa-1:0.3.64-1-x... 4.8 KiB 68.1 KiB/s 00:00 [--------------------------------] 100%
fuse-common-3.13.0-1-x86_64 2.6 KiB 31.2 KiB/s 00:00 [--------------------------------] 100%
default-cursors-2-1-any 2.2 KiB 20.2 KiB/s 00:00 [--------------------------------] 100%
Total (426/426) 1708.3 MiB 3.03 MiB/s 09:23 [--------------------------------] 100%
error: failed retrieving file 'linux-6.1.6.arch1-1-x86_64.pkg.tar.zst' from mirrors.vectair.net : OpenSSL SSL_read: Connection reset by peer, errno 104
error: failed retrieving file 'linux-zen-6.1.6.zen1-1-x86_64.pkg.tar.zst' from mirrors.vectair.net : OpenSSL SSL_read: Connection reset by peer, errno 104
error: failed retrieving file 'libreoffice-still-7.3.7-2-x86_64.pkg.tar.zst' from mirrors.vectair.net : OpenSSL SSL_read: Connection reset by peer, errno 104
warning: too many errors from mirrors.vectair.net, skipping for the remainder of this transaction
error: failed retrieving file 'linux-hardened-6.1.6.hardened2-1-x86_64.pkg.tar.zst' from mirrors.vectair.net : OpenSSL SSL_read: Connection reset by peer, errno 104
error: failed retrieving file 'linux-firmware-20221214.f3c283e-1-any.pkg.tar.zst' from mirrors.vectair.net : OpenSSL SSL_read: Connection reset by peer, errno 104
(426/426) checking keys in keyring [--------------------------------] 100%
downloading required keys...
:: Import PGP key 003DB8B0CB23504F, "EndeavourOS <info@endeavouros.com>"? [Y/n] y
error: key "003DB8B0CB23504F" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
AUR update check:
:: Searching AUR for updates...
-> slippi-online-appimage: local (2.5.2-1) is newer than AUR (2.4.0-0)
-> supergfxctl: local (5.0.1-2) is newer than AUR (5.0.1-1)
-> Missing AUR Packages: grub-tools grub2-theme-endeavouros ipw2100-fw ipw2200-fw
-> Orphaned AUR Packages: kesl kesl-gui
-> Flagged Out Of Date AUR Packages: kesl kesl-gui
:: 2 Packages to upgrade.
2 aur/asusctl 4.5.1.r0.gaad4dc9-1 -> 4.5.8-1
1 aur/pacseek 1.7.6-1 -> 1.7.7-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
==> 2
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] pacseek-1.7.7-1
1 pacseek (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> N
:: (1/1) Downloaded PKGBUILD: pacseek
==> Diffs to show?
==> N
:: (1/1) Parsing SRCINFO: pacseek
==> Making package: pacseek 1.7.7-1 (Tue 17 Jan 2023 09:15:16 AM MST)
==> Retrieving sources...
-> Downloading v1.7.7.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 678k 0 678k 0 0 586k 0 --:--:-- 0:00:01 --:--:-- 3548k
==> Validating source files with sha256sums...
v1.7.7.tar.gz ... Passed
==> Making package: pacseek 1.7.7-1 (Tue 17 Jan 2023 09:15:19 AM MST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
-> Found v1.7.7.tar.gz
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Extracting v1.7.7.tar.gz with bsdtar
==> Starting prepare()...
==> Sources are ready.
==> Making package: pacseek 1.7.7-1 (Tue 17 Jan 2023 09:15:23 AM MST)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
go: downloading github.com/pborman/getopt/v2 v2.1.0
go: downloading github.com/rivo/tview v0.0.0-20230104153304-892d1a2eb0da
go: downloading github.com/lithammer/fuzzysearch v1.1.5
go: downloading github.com/mmcdole/gofeed v1.1.3
go: downloading github.com/patrickmn/go-cache v2.1.0+incompatible
go: downloading github.com/gdamore/tcell/v2 v2.5.5-0.20230109002058-5e9dd83b5281
go: downloading github.com/Morganamilo/go-pacmanconf v0.0.0-20210502114700-cff030e927a5
go: downloading github.com/alecthomas/chroma v0.10.0
go: downloading github.com/Jguer/go-alpm/v2 v2.1.2
go: downloading golang.org/x/text v0.6.0
go: downloading github.com/gdamore/encoding v1.0.0
go: downloading github.com/lucasb-eyer/go-colorful v1.2.0
go: downloading golang.org/x/term v0.4.0
go: downloading github.com/mattn/go-runewidth v0.0.14
go: downloading golang.org/x/sys v0.4.0
go: downloading github.com/json-iterator/go v1.1.12
go: downloading github.com/mmcdole/goxpp v1.0.0
go: downloading golang.org/x/net v0.5.0
go: downloading github.com/PuerkitoBio/goquery v1.8.0
go: downloading github.com/dlclark/regexp2 v1.7.0
go: downloading github.com/rivo/uniseg v0.4.3
go: downloading github.com/modern-go/reflect2 v1.0.2
go: downloading github.com/modern-go/concurrent v0.0.0-20180306012644-bacd9c7ef1dd
go: downloading github.com/andybalholm/cascadia v1.3.1
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "pacseek"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: pacseek 1.7.7-1 (Tue 17 Jan 2023 09:15:48 AM MST)
==> Cleaning up...
[sudo] password for oneshinyboi:
sudo: timed out reading password
sudo: a password is required
-> exit status 1
I followed the same steps mentioned above by @Pudge but with this modifier only for it to fail again. I’ve not yet tried disabling signature checking but other than that I’ve tried all the steps on the wiki article.
pebcak
January 17, 2023, 4:53pm
34
Save this page as enos.pgp
https://keyserver.ubuntu.com/pks/lookup?op=get&search=0x003db8b0cb23504f
Go into the folder where it is saved and open a terminal:
sudo pacman-key --add enos.pgp
Try updating: sudo pacman -Syu
Bad mirrors not synced … If the info isn’t fetched then it can’t update. Did you try using US mirrors.
Arch Mirrors or EndeavorOS Mirrors? Or does it matter?
I gave that a try along with updating the mirrors for both EndeavorOS and Arch and got the exact same result as listed above.
Seems to be a mirror-issue. Try running reflector and point it to some other country, like US (as said before).
https://wiki.archlinux.org/title/reflector
I’ll try that. But in case it fails how secure would it be to disable signature checking? Or would it be better at that point to just reinstall the OS from scratch?
