I installed EndeavourOS on my Lenevo ThinkBook 15 G5 and I tried to connect my SONY WH-CH720 headset using bluetooth. At first I faced the same issues which I am about to describe, but after removing, trusting, pairing and connecting for about 10 to 20 times, it connected. And after reboot the same problem appears
The problem as follows,
- I open
bluetoothctl
- Turn on my headset to pairing mode
- I scan → trust → pair → connect
[bluetooth]# power on
[bluetooth]# Changing power on succeeded
[bluetooth]# agent on
Agent is already registered
[bluetooth]# default-agent
[bluetooth]# Default agent request successful
[bluetooth]# scan on
[bluetooth]# SetDiscoveryFilter success
[bluetooth]# Discovery started
[bluetooth]# [CHG] Controller 4C:82:A9:24:23:58 Discovering: yes
[bluetooth]# [NEW] Device 84:D3:52:9D:EF:38 WH-CH720N
[bluetooth]# [NEW] Device AC:B6:87:8F:B9:C9 AC-B6-87-8F-B9-C9
[bluetooth]# [CHG] Device 84:D3:52:9D:EF:38 RSSI: 0xffffffc3 (-61)
[bluetooth]# trust 84:D3:52:9D:EF:38
[bluetooth]# [CHG] Device 84:D3:52:9D:EF:38 Trusted: yes
[bluetooth]# Changing 84:D3:52:9D:EF:38 trust succeeded
[bluetooth]# pair
84:D3:52:9D:EF:38 AC:B6:87:8F:B9:C9
[bluetooth]# pair 84:D3:52:9D:EF:38
Attempting to pair with 84:D3:52:9D:EF:38
[CHG] Device 84:D3:52:9D:EF:38 Connected: yes
[WH-CH720N]# [CHG] Device 84:D3:52:9D:EF:38 Bonded: yes
[CHG] Device AC:B6:87:8F:B9:C9 RSSI: 0xffffffb0 (-80)
[CHG] Device 84:D3:52:9D:EF:38 Connected: no
[bluetooth]# [CHG] Device 84:D3:52:9D:EF:38 Paired: yes
[bluetooth]# Pairing successful
[bluetooth]# connect 84:D3:52:9D:EF:38
Attempting to connect to 84:D3:52:9D:EF:38
[WH-CH720N]#
Note: Right after I type pair <MAC>
I get a notifcation that my headset is connected, and when the “Pairing successful” message shows up, I get a notification that my headset is disconnected.
When I then try to connect, it says connected: yes. but my headset doesn’t give off the connected chime which it usually gives when its connected to a device.
Around 2 minutes later after “connecting”, it disconnects (my headset doesnt sound the disconnected chime as well) and I get a notification that my headset got disconnected.
This is the output of systemctl -u bluetooth.service
Context: Time is May 24 16:41 at the time of command execution
May 24 16:30:05 eva systemd[1]: Stopped Bluetooth service.
May 24 16:30:05 eva systemd[1]: Starting Bluetooth service...
May 24 16:30:05 eva bluetoothd[32267]: Bluetooth daemon 5.76
May 24 16:30:05 eva systemd[1]: Started Bluetooth service.
May 24 16:30:05 eva bluetoothd[32267]: Starting SDP server
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support bap plugin
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support bass plugin
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support mcp plugin
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support vcp plugin
May 24 16:30:05 eva bluetoothd[32267]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support micp plugin
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support ccp plugin
May 24 16:30:05 eva bluetoothd[32267]: src/plugin.c:init_plugin() System does not support csip plugin
May 24 16:30:05 eva bluetoothd[32267]: Bluetooth management interface 1.22 initialized
May 24 16:30:05 eva bluetoothd[32267]: Battery Provider Manager created
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/ldac
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/aptx_hd
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_hd
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/aac
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aac
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc_xq
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc_xq
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/opus_05
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/opus_05
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 24 16:30:05 eva bluetoothd[32267]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 24 16:34:48 eva bluetoothd[32267]: src/device.c:search_cb() 84:D3:52:9D:EF:38: error updating services: Input/output error (5)
May 24 16:36:04 eva bluetoothd[32267]: src/device.c:search_cb() 84:D3:52:9D:EF:38: error updating services: Input/output error (5)
Searching for the error in last 2 lines doesnt give me much useful links, these are the ones I could find
- https://askubuntu.com/questions/1421177/bluetooth-headphones-keep-disconnecting
- https://github.com/blueman-project/blueman/issues/1836
The solutions for these are for pulseaudio, I am using pipewire and wireplumber
This is the output of info
Device 84:D3:52:9D:EF:38 (public)
Alias: WH-CH720N
Class: 0x00240404 (2360324)
Icon: audio-headset
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Vendor specific (fa349b5f-8050-0030-0010-00001bbb231d)
UUID: Vendor specific (00000000-deca-fade-deca-deafdecacaff)
What have I tried?
- I tried restarting bluetooth.service and performed the same steps as shown above
- Tried to remove the headset and pair it again as specified in https://discovery.endeavouros.com/audio/bluetooth/2021/03/
Output of systemctl status bluetooth
[bharath@eva ~]$ systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2024-05-24 16:30:05 IST; 17min ago
Docs: man:bluetoothd(8)
Main PID: 32267 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 16569)
Memory: 1.0M (peak: 1.3M)
CPU: 77ms
CGroup: /system.slice/bluetooth.service
└─32267 /usr/lib/bluetooth/bluetoothd
I have checked my headset and it is working properly, so the issue is not with the headset.
What might be causing this issue? and how can I fix it? any help will be greatly appreciated
