Unity breaks sound
When using Unity sound crashes and there is no sound in headphones (bluetooth) at all. Reboot and closing Unity helps. I am new to OS so I dont know how it relates to previous releases
hello @Salieri,
welcome to the purple universe :enos: :enos_flag: :penguin_face: :rocketa_purple:
if you use bluez, then note the following thread(briefly explained, it hangs with the bluez update)
This is how you can find out whether bluez is installed:
yay -Qs bluez
if then a result is there as by me
[pycrk@eno ~]$ yay -Qs bluez
local/bluez 5.67-1
    Daemons for the bluetooth protocol stack
local/bluez-libs 5.67-1
    Deprecated libraries for the bluetooth protocol stack
local/bluez-qt 5.107.0-1 (kf5)
    Qt wrapper for Bluez 5 DBus API
local/bluez-utils 5.67-1
    Development and debugging utilities for the bluetooth protocol stack
[pycrk@eno ~]$
then bluez( bluez 5.67-1) is installed on your system
Thanks, glad to be here)
Now when you asked I cant catch the issue(
But when I switched to wired mode of headphones all started work perfectly. And also I had exactly same issues as user from post that you quoted, so at least I can assure you that this is problem with bluez.
If I catch this problem - I will reply here with thread
probably best to downgrade bluez and wait for the next update
closed
