✗ LANG=C sudo findmnt --verify
none
[W] non-bind mount source /swapfile is a directory or regular file
0
[E] unreachable on boot required target: No such file or directory
[E] unsupported source tag: iocharset=utf8,vers=1.0
[W] 0 seems unsupported by the current kernel
[W] cannot detect on-disk filesystem type (No such file or directory)
0 parse errors, 2 errors, 3 warnings
i have the line uncommented
Maybe the linebreak here is the issue.
Try putting everything in one line and reload.
Ok putting in it one line.
systemctl daemon-reload
done
➜ sudo mount -a
mount error(16): Device or resource busy
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
Not sure why is that but I guess it should be fine now.
Check again with sudo findmnt --verify and see if the [E] lines are gone.
Yes it seems fine now
➜ LANG=C sudo findmnt --verify
none
0 parse errors, 0 errors, 1 warning
Reboot for good measure ![]()
All is doing fine.
https://0x0.st/HDsb.txt
@pebcak @BS86 @Zesko @Stephane
You guys are awesome. Many, many thanks to all of you !!
i installed eos fresh yesterday (just before the neo iso arrived, so just gallileo)
i also got fmask=0137,dmask=0027
i installed on premade partitions, not full disk install/overwrite or what its called
