umask=0077 is the default after installing Arch using systemd-boot.
# <file system> <dir> <type> <options> <dump> <pass>
UUID=3DE2-72E6 /boot vfat umask=0077 0 2
What I posted was from a Vanilla Arch install as well.
The entry was produced by genfstab before installing Grub even ![]()
Maybe depending on when systems have been installed, something has changed?
Or could it be depending where ESP is mounted? Mine is mounted at /boot/efi. I see yours is mounted at /boot.
That means, it allows other users in the group to read and execute files in the esp partition without requiring root permission.
https://wiki.archlinux.org/title/Genfstab
UUID=E5C7-6DD7 /efi vfat rw,relatime,fmask=0077,dmask=0077, …
Interesting!
I have no explanation as why genfstab generated those permissions on my end ![]()
I haven’t changed them myself. That’s for sure.
Nothing jumps at me at a first glance but you have still these:
Jan 28 11:26:05 ryzen bootctl[759]: ! Mount point '/efi' which backs the random seed file is world accessible, which is a security hole! !
Jan 28 11:26:05 ryzen bootctl[759]: ! Random seed file '/efi/loader/random-seed' is world accessible, which is a security hole! !
Jan 28 11:26:06 ryzen systemd-logind[783]: /efi/loader/loader.conf:5: Unknown line 'reboot-for-bitlocker', ignoring.
If mounting your /home partition gives you more issues in the continuation as was shown in the picture you posted, consider running a disk health check on that NVME drive:
I think genfstab has no AI and would not know that /boot/efi is the ESP partition, maybe a normal partition, and then it generates a line of vfat with fmask=0022,dmask=0022 to allow other users to access files and directories.
Could be.
/boot/efi is not where Arch actually recommends to mount ESP either.
The recommendation is /boot or /efi.
So your explanation is plausible.
This is my smarctl --info for /home device
sudo smartctl --info /dev/nvme1n1
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.14-1-lts] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: Samsung SSD 980 PRO 1TB
Serial Number: S5GXNL0W407287A
Firmware Version: 5B2QGXA7
PCI Vendor/Subsystem ID: 0x144d
IEEE OUI Identifier: 0x002538
Total NVM Capacity: 1.000.204.886.016 [1,00 TB]
Unallocated NVM Capacity: 0
Controller ID: 6
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1.000.204.886.016 [1,00 TB]
Namespace 1 Utilization: 641.254.617.088 [641 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 002538 b431a6b43e
Local Time is: Sun Jan 28 11:54:48 2024 CET
and smartctl -c
sudo smartctl -c /dev/nvme1n1
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0057): Comp Wr_Unc DS_Mngmt Sav/Sel_Feat Timestmp
Log Page Attributes (0x0f): S/H_per_NS Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size: 128 Pages
Warning Comp. Temp. Threshold: 82 Celsius
Critical Comp. Temp. Threshold: 85 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 8.49W - - 0 0 0 0 0 0
1 + 4.48W - - 1 1 1 1 0 200
2 + 3.18W - - 2 2 2 2 0 1000
3 - 0.0400W - - 3 3 3 3 2000 1200
4 - 0.0050W - - 4 4 4 4 500 9500
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
Run:
sudo smartctl -d nvme,0xffffffff -t short /dev/nvme1n1
to run a short test. Wait a couple of minutes till it is done.
Run:
sudo smartctl -l selftest /dev/nvme1n1
to get a list of recent tests.
Check with:
sudo smartctl -x /dev/nvme1n1
to show detailed information.
Or just for a short health check assessment:
sudo smartctl -H /dev/nvme1n1
➜ sudo smartctl -l selftest /dev/nvme1n1
=== START OF SMART DATA SECTION ===
Read Self-test Log failed: Invalid Field in Command (0x002)
Does that mean selftest isnt finished?
Controller ID: 6
NVMe Version: 1.3
Namespace 1 Utilization: 641.256.398.848 [641 GB]
Local Time is: Sun Jan 28 12:24:14 2024 CET
0 + 512 0 0
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 32 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Read: 21.852.617 [11,1 TB]
Data Units Written: 10.631.340 [5,44 TB]
Host Read Commands: 111.247.659
Host Write Commands: 128.790.438
Controller Busy Time: 943
Power Cycles: 314
Power On Hours: 190
Unsafe Shutdowns: 16
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 32 Celsius
Temperature Sensor 2: 36 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
It seems drive is fully functionally.
Yes. Looks good.
The issue with the failing dependency for /home might have been due to some filesystem corruption or inconsistency. Hopefully running the check from the live usb has fixed it.
My bad. It should have been:
sudo smartctl -d nvme,0xffffffff -l selftest /dev/nvme1n1
as you are running KDE, you can also check kinfocenter → Devices → SMART Status for drive health
What does a poor GNOME user know of such KDE subtleties? ![]()
It seems that my drive is completely ok. I think the check from the live USB hopefully helped
Now i should fix this error:
ryzen bootctl[758]: ! Mount point '/efi' which backs the random seed file is world accessible, which is a security hole! !
ryzen bootctl[758]: ! Random seed file '/efi/loader/random-seed' is world accessible, which is a security hole!
is it sufficient to edit the fstab as follows? Did I understand this correctly?
UUID=D3E2-C3D4 /efi vfat defaults,noatime,umask=0077 0 2
Can I reload the fstab with which command? or is it only relevant with a restart?
Yes.
sudo systemctl daemon-reload
and then:
sudo mount -a
Also look into this.
As I mentioned before, I couldn’t see any reference to reboot-for-bitlocker in man loader.conf.
Not sure if this is added by EnOS’ for those dualbooting with Windows ![]()
At any rate, I think in your case, it should be safe to remove it (or at least commenting it out).
I got this error message
➜ LANG=C sudo mount -a
mount: 0: unknown filesystem type '0'.
dmesg(1) may have more information after failed mount system call.
Does sudo findmnt --verify give more info?
