I’m unable to import assets to the Unity Game Engine. When being done with .unitypackage files, it gets to the step where it says “Preparing Package” and then stops. Dragging assets into Unity also does not work, even when Dolphin is set to X11 mode
Opening the Editor.log reveals the following error repeated multiple times:
(Unity:974809): GLib-GIO-CRITICAL **: 14:19:59.657: g_dbus_proxy_call_sync_internal: assertion ‘G_IS_DBUS_PROXY (proxy)’ failed
I have already attempted running Dolphin in X11 mode, giving full permissions to the Unity cache folder, and using different versions of Unity Hub to launch projects (Unity Hub AUR, Unity Hub Appimage, Unityhubnative, and ALCOM)
Welcome to the community!
Please describe how you “use Dolphin in X11 mode”.
Also, please share the output of this command from a terminal:
inxi -Fxxc0z
When you paste the output in your reply, please select it, then press “CTRL+E
Thanks for the reply
Apologies. I read that there was an issue with Unity on Wayland preventing files from being dragged and dropped and that setting the Environment Variable “WAYLAND_DISPLAY=” on Dolphin fixes it. It doesn’t solve all of the issues, though
Here’s the output from the command
Kernel: 6.10.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: ProArt X670E-CREATOR WIFI v: Rev 1.xx
serial: <superuser required> part-nu: SKU UEFI: American Megatrends v: 0805
date: 11/04/2022
Info: 16-core model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4
rev: 2 cache: L1: 1024 KiB L2: 16 MiB L3: 64 MiB
Speed (MHz): avg: 5487 min/max: 400/5881 cores: 1: 5487 2: 5487 3: 5487
4: 5487 5: 5487 6: 5487 7: 5487 8: 5487 9: 5487 10: 5487 11: 5487 12: 5487
13: 5487 14: 5487 15: 5487 16: 5487 17: 5487 18: 5487 19: 5487 20: 5487
21: 5487 22: 5487 23: 5487 24: 5487 25: 5487 26: 5487 27: 5487 28: 5487
29: 5487 30: 5487 31: 5487 32: 5487 bogomips: 287565
Device-1: NVIDIA GA102 [GeForce RTX 3080] driver: nvidia v: 560.35.03
arch: Ampere pcie: speed: 16 GT/s lanes: 16 ports: active: none off: DP-1,
DP-2, DP-3, HDMI-A-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:2206
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-4, DP-5, HDMI-A-2, Writeback-1 bus-ID: 6c:00.0
chip-ID: 1002:164e temp: 44.0 C
Device-3: Valve 3D Camera driver: uvcvideo type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 bus-ID: 4-2.1:4 chip-ID: 28de:2400
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa dri: radeonsi gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 6000x1640 s-dpi: 107
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-center
model: Dell AW3423DWF res: 3440x1440 dpi: 109 diag: 868mm (34.2")
Monitor-2: not-matched mapped: DP-3 pos: bottom-l res: 1280x1024 dpi: 96
diag: 434mm (17.09")
Monitor-3: not-matched mapped: DP-4 size-res: N/A
Monitor-4: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: Dell 1708FP res: 1280x1024 dpi: 96 diag: 433mm (17")
API: EGL v: 1.5 platforms: device: 0 drv: nvidia device: 2 drv: radeonsi
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11:
drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
API: Vulkan v: 1.3.295 surfaces: xcb,xlib device: 0 type: discrete-gpu
driver: nvidia device-ID: 10de:2206
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
speed: 16 GT/s lanes: 16 bus-ID: 6c:00.1 chip-ID: 1002:1640
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s
lanes: 16 bus-ID: 6c:00.6 chip-ID: 1022:15e3
Device-4: Valve VR Radio driver: cdc_acm,hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 3-2.3.2:9 chip-ID: 28de:2102
Device-5: Valve VR Radio & HMD Mic
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 bus-ID: 3-2.3.3:12 chip-ID: 28de:2102
Device-6: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 bus-ID: 3-5:7 chip-ID: 1038:12e0
Device-7: Audio-Technica AT2020USB+
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 bus-ID: 9-2:2 chip-ID: 0909:001c
API: ALSA v: k6.10.10-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel pcie: speed: 5 GT/s lanes: 1
bus-ID: 08:00.0 chip-ID: 14c3:0616
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Aquantia AQtion AQC113CS NBase-T/IEEE 802.3an Ethernet [Antigua
10G] vendor: ASUSTeK ProArt X570-CREATOR WIFI driver: atlantic v: kernel
pcie: speed: 16 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 1d6a:94c0
IF: eno2 state: down mac: <filter>
Bluetooth:
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 bus-ID: 3-6:10 chip-ID: 0489:e0e2
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 4.55 TiB used: 1.4 TiB (30.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 1TB size: 931.51 GiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 53.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 44.9 C
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO Plus 500GB
size: 465.76 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 44.9 C
ID-4: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
speed: 6.0 Gb/s serial: <filter>
ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-6: /dev/sdc vendor: Samsung model: PSSD T7 size: 931.51 GiB type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 serial: <filter>
ID-1: / size: 930.51 GiB used: 183.69 GiB (19.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /home size: 930.51 GiB used: 183.69 GiB (19.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-3: /var/log size: 930.51 GiB used: 183.69 GiB (19.7%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 60.5 C mobo: 52.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 50 C fan: 30% device: amdgpu
temp: 44.0 C
Memory: total: 32 GiB note: est. available: 30.49 GiB
used: 21.23 GiB (69.6%)
Processes: 753 Power: uptime: 7h 42m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: 1558 pm: pacman pkgs: 1537 pm: flatpak pkgs: 21 Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.36
No need for apologies.
This shows that you are currently using an X11 session. Were you using Wayland when attempting the fix, or were you using X11?
If you were using X11, I imagine it shouldn’t work, because you wouldn’t be in the right environment (Wayland).
Also, the variable looks like it is missing an argument. Where did you find the fix?
I was using Wayland when attempting the Dolphin fix, yes. Removing the variable prevents dragging and dropping to Unity entirely on Wayland. X11 works regardless of it. The fix was from https://github.com/flathub/com.unity.UnityHub/issues/97
The ‘G_IS_DBUS_PROXY (proxy)’ failed error continues to run regardless of the variable. It seems to happen both while attempting to drag and drop files as well as when attempting to import .unitypackage files
