Just did a reinstall of EndeavourOS. My DE is KDE. I used to run XFCE. On XFCE, there was only x11 support, which I was comfortable with. When I installed KDE, I switched to Wayland, however I seem to have no brightness control anymore.
Any games I play seem dark, and if I move the brightness sliders, nothing happens. My system tray brightness control is at 100% and its still dark.
I tried brightnessctl, but my only options are 0 (0%) and 1 (100%). Setting it to either does nothing and the screen brightness stays the same.
Switching to x11 seems to fix the problem and I have my brightness controls again. Can anyone help? I can stick with x11 for now, but I would like to find a fix.
May need to adjust the config settings; the brightnessctl settings are not identical. From the man page:
brightnessctl set 50%-
Subtracts 50% of the maximum from the current brightness.
brightnessctl set +10%
Adds 10% of the maximum to the current brightness.
The minus and plus signs are on different sides of the amount to increase or decrease. I think this is to prevent the negative amount from being parsed as a command-line option.
