(Using Vivaldi)
Includes this forum. Unless I disable UBlock, any post I click refuses to load. Other sites are experiencing partial failures as well. Since I’ve been using UBlock with Vivaldi for many months without issue, I was wondering if this was happening to anyone else.
Not me. Which filter lists do you have loaded?
Just the default ones. I haven’t made any changes since the initial install.
It happens for me on a domain registrar, after login, the site doesn’t render until I disable uBlock, but everything else keeps working without issues.
I’m going to purge everything and reload the extension; maybe something got corrupted.
Resetting everything seems to have worked, just wish I knew what the actual cause was.
First clear the filter cache and reload all filter lists:
The full reset did that for me; thanks for that.
But would not have been necessary …
I use ublock origin but only with defaults as installed and no issues.
I think I had only the defaults, but I did play around with font blocking a while ago.
