In the last couple days my two systems running endeavour have both lost the ability to access the web. Both systems are running GNOME, I’ve tried both wired and wifi connections, reset router several times ect. I can access my router’s admin login page my typing 192.168.0.1 but no web access.
I am typing this from my laptop running Fedora that is completely unaffected.
Has anyone else noticed issues due to a recent update or anything?
Thanks for the reply. That did work. DNS issue I guess. Would you mind getting me pointed in the right direction about how I might be able to troubleshoot that?
Oh yeah… I was using a VPN with both and it seemed to coincide with the issue in both cases. The contents of /ect/resolv.conf are the same on both machines:
Generated by NetworkManager
nameserver ::1
I don’t see anything in the GNOME settings about DNS settings. Is that where you meant or is there a seperate network manager settings I should be referring to?
lmao… yeah I’ve just now found that turning the VPN back on restores connectivity. Is this as simple as fixing /ect/resolv.confor does this go deeper than that?
