Hi. I encountered my first problem with yt videos, but somehow managed to find a solution. It occured that, perhaps when I was solving some bluetooth problem, I installed Pipeware or PulseAudio server (as a second one). Right now Pipeware is enabled, but is there any possibility to just get rid of one of the servers? I want to keep it clean.
I messed something up and want to make it perfect at once, not to forget it
Well, what I did was installing the pulse audio (didn’t know about pipeware then). After that collisions started to happen, so i figured out I have two servers. Tried to uninstall Pipeware and stuff with Pacman -Rs but it didnt run well. So I disabled one of the servers. Now everything works.
EDIT: In progress - i managed to remove pulseaudio-bluetooth and pulseaudio-jack by hand one by one. After that whole pulseaudio package could be removed without problems. We will see.
You need to have one or the another. If you choose Pulseaudio and it works for you, fine, but Pipewire is default for EnOS. If you are content, I am not going to dispute
It is described in the link I posted. When installing pipewire, it wants most probably remove other pulse packages. Let it remove them. Please read carefully the article. All you need to do is there.
Thank you. I found a solution there. Uninstalled everything from pulseaudio (only pulseaudio-gtk left) and installed pipeware once again. Right now only one active server exists and it seems everything id fine with sound and videos.
