I’ve seen the posts about a about serious grub issue from a few weeks ago. Sometime since then after running paru I get a message that grub tools are not in the aur directory, so I’m wondering if I should just delete it.
Second I’ve noticed that files I create end up posted with a times stamp an hour later than what I see on the system clock, which is set correctly. How is that fixed?
When I create a file in say, Libreoffice or Gnumeric, either one, save it then exit the program, then go right back in to either program, the time on the file before I reload it is an hour later than what the system clock at the lower right of the screen says.
[mark@mark-optiplex9020 ~]$ timedatectl
Local time: Sun 2022-10-16 09:10:58 EDT
Universal time: Sun 2022-10-16 13:10:58 UTC
RTC time: Sun 2022-10-16 13:10:58
Time zone: America/Indiana/Vincennes (EDT, -0400)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
Done. Thanks for the assist:
timedatectl
Local time: Sun 2022-10-16 08:15:29 CDT
Universal time: Sun 2022-10-16 13:15:29 UTC
RTC time: Sun 2022-10-16 13:15:29
Time zone: CST6CDT (CDT, -0500)
NTP service: active
RTC in local TZ: no
