Disclaimer: I did this using a freshly installed (cloned) virtual machine. Your experience might be different according to your hardware and setup.
First, you need to install KDE. You can use our online installer to do this or you can install KDE manually. But I recommend installing KDE using our online installer.
If you wish to install KDE manually. Then follow the below steps.
NOTE: If you want to install KDE manually it is best you start without a desktop environment.
Open the terminal (Konsol). Run the below command,
wget https://raw.githubusercontent.com/endeavouros-team/EndeavourOS-packages-lists/master/plasma
This file should be downloaded into your home folder. Unless you changed the location. -
After downloading the application list run the below command.
sudo pacman -S --needed - < plasma
← Need to be run within the application list directory. We downloaded it in the above step. -
Once KDE is installed restart/reboot the system.
Now let’s install
i3-wm
. To do that first run the below command in the terminal.
wget https://raw.githubusercontent.com/endeavouros-team/endeavouros-i3wm-setup/main/i3_install
Above command will download a
shell
script. This should be in your/home
folder as well. But it’s not executable so we need to give it permission to run. To do that use the below command.
sudo chmod -R +x i3_install
Execute the file
i3_install
by using the below command.
./i3_install
If everything goes well you should have KDE + i3 installed. Before using the system we need to stop the KDE native windows manager which is KWin
. To do that you need to mask or disable the Kwin service (Recommend masking it. Which will stop it from accidentally starting.).
To disable the service run the below command. DO NOT USE SUDO.
systemctl mask plasma-kwin_x11.service
After that, we need to remove lightdm
. Run the below command to remove lightdm
and it’s components.
sudo yay -Rnc lightdm
or sudo pacman -Rnc lightdm
That’s pretty much it. No need to use the other steps described in the Arch wiki here. I did try those but they didn’t work. KDEs display manager SDDM
does pick up the i3-wm
session. You just have to change the session from Plasma
to i3
from SDDM
screen.
After you log in.
P.S.: I’m creating a more refined KDE + i3
repo just like the XFCE + i3
one. Will see what I can come up with in the future. But for now, the above will work. Remember to tweak the .config
file to fit your needs.
