Is there a way to have EOS re engage with a display, (in my case it’s a oled 4k tv), if it’s been turned off and turned back on say two hours later?
Following.
I had this happen to me a little bit ago. My main display (a 4K OLED TV) powered off. When I sat back down and turned the display back on, EOS wouldn’t display to it (even though it “was there”), until I went on my other normal monitor and disabled/re-enabled the TV display.
I’m not sure I understand.
While not OLED, I’m using a 32" 4K Samsung smart TV / Monitor. If I leave for any length of time, and the PC goes to sleep, all I have to do is hit any key on the keyboard and the TV / Monitor turns on and I see the login screen. If I actually turn the TV / Monitor off manually and come back later and turn the TV / Monitor back on, I hit any key on the keyboard and the login screen is there. Should be normal behavior.
That’s definitely the expected behavior. And preferred if I’m honest lol. But it for sure jacks up my display like I described. Not sure if the OP is experiencing this same problem though and I don’t want to completely hijack the thread lol
I do this (on purpose) all the time, but it’s not a 4K OLED TV. Just a 1080p LED TV. I don’t have to do anything special. I disabled automatic screenlock, but I think the same applies when that’s on, too.
kscreen-doctor --dpms off
Turns my laptop screen off, you could try something like:
#!/bin/bash
sleep 20m
kscreen-doctor --dpms on
But any keyboard or mouse movement will override.
I have sleep disabled. When its enabled, and it goes to sleep the same thing happens. The display will not display.
Yea I’ve disabled sleep as well. Sounds like we are experiencing the same issue then.
