I have the same problem than @Chewing_Bever
I wanted to use the OBS virtual cam feature to stream some games to my friends via Discord, but it’s refusing to output a signal. I’ve installed the v4l2loopback-dkms
package, which enabled the option in OBS. When I click Start Virtual Camera
, a popup shows up asking for root privileges for running modprobe, and afterwarts, a new camera output is created named OBS Virtual Camera
. Sadly, this device doesn’t actually output anything. I’ve used both Discord and Zoom for testing, an both confirm that no output is coming through the loopback device. I’ve tried both a scene with just my webcam and one with screen share + webcam, neither work.
Reproduce the probleme :
- install
obs-studio
27.1.3 and v4l2loopback-dkms
- try to use the virtual cam with jitsi : meet.jit.si/
I’ve tried many Obs-studio version in AUR, without output. No Obs Cam is output.
Virtual Cam in Obs studio only work with a flatpak install.
Is there a workaround to make it work, with arch install ?
Best regards
what DE/WM do you use? as there are issues with OBS under XFCE4 and i do have issues on i3 also.
And Nvidia Drivers can be troublesome also.
So, problem may be, in my case, XFCE or Nvidia.
#################### inxi -Fxxc0z ########################
System: Kernel: 5.15.2-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0
tk: Gtk 3.24.29 wm: xfwm dm: LightDM Distro: EndeavourOS base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 5861 date: 08/10/2021
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ rev: 2 cache:
L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86424
Speed: 3062 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3062
2: 2206 3: 4265 4: 2125 5: 2158 6: 2135 7: 4251 8: 2122 9: 2741 10: 2118 11: 2176
12: 2120
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 495.44 bus-ID: 08:00.0
chip-ID: 10de:1c03
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-2:3
chip-ID: 046d:0825
Display: x11 server: X.org 1.21.1.1 compositor: xfwm4 driver: loaded: nvidia
resolution: <missing: xdpyinfo>
Audio: Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 10de:10f1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457
Device-3: Corsair VOID PRO Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-14:2 chip-ID: 1b1c:0a14
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-2:3
chip-ID: 046d:0825
Sound Server-1: ALSA v: k5.15.2-arch1-1 running: yes
Sound Server-2: sndio v: N/A running: no
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: e000
bus-ID: 06:00.0 chip-ID: 8086:1539
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb
v: 0.8 bus-ID: 3-1:2 chip-ID: 0a12:0001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Drives: Local Storage: total: 2.27 TiB used: 80.58 GiB (3.5%)
ID-1: /dev/sda vendor: Seagate model: ST2000DM006-2DM164 size: 1.82 TiB speed: 6.0 Gb/s
serial: <filter>
ID-2: /dev/sdb vendor: Western Digital model: WD2500JD-00GBB0 size: 232.89 GiB
speed: 1.5 Gb/s serial: <filter>
ID-3: /dev/sdc vendor: Crucial model: CT250MX500SSD4 size: 232.89 GiB speed: 6.0 Gb/s
serial: <filter>
Partition: ID-1: / size: 29.3 GiB used: 22.91 GiB (78.2%) fs: btrfs dev: /dev/sdc5
ID-2: /boot/efi size: 96 MiB used: 29.8 MiB (31.1%) fs: vfat dev: /dev/sdc1
ID-3: /home size: 71.45 GiB used: 57.64 GiB (80.7%) fs: ext4 dev: /dev/sdc6
ID-4: /var/log size: 29.3 GiB used: 22.91 GiB (78.2%) fs: btrfs dev: /dev/sdc5
Swap: ID-1: swap-1 type: partition size: 7.96 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc7
Sensors: Message: No sensor data found. Is lm-sensors configured?
Info: Processes: 340 Uptime: 3m Memory: 15.59 GiB used: 1.47 GiB (9.4%) Init: systemd v: 249
Compilers: gcc: 11.1.0 Packages: 1218 pacman: 1213 flatpak: 5 Client: shell wrapper
v: 5.1.8-release inxi: 3.3.07
So, I must use a flatpack install, if I understand correctly.
