Troubleshooting Advice for Deepin Greeter
Hello
This forum has never failed me. I’ve always been able to solve problems with input from our forum community members.
Okay now onto the problem.
I have testing & community-testing repos enable in pacman.conf. Also I development packages enabled in pamac-aur.
This problem only occurs on (restart or startup) to the login greeter display @user password prompt.
The display window is all black and I have to input my username password >> After that the default-chosen wallpaper displays.
Then I login again with password to enter the normal deepin session.
This display-session all black window started after a system update.
So my question for community is what package to downgrade in order to troubleshoot.
Should I downgrade >> deepin-session-shell
or
Should I downgrade >> deepin-session-ui
or
Should I downgrade >> lightdm
Thanks
Try setting auto login, it will bypass the buggy greeter :wink:
@antechdesigns antechdesigns
Isn’t that like bypassing Microsoft Windows and injecting ourselves into LINUX :rofl:
Not really the solution I was looking for but it works (smiles)
In my case a Downgrade might just be an Upgrade … LOL
Its the only work around concerning deepin it breaks every other update, that’s why I know how to fix it, It been like that for ages.
