Trouble with Shutter Encoder
When I try to install Shutter Encoder, I get this and am unable to install the program…
yay -S shutter-encoder
AUR Explicit (1): shutter-encoder-18.2-1
:: PKGBUILD up to date, skipping download: shutter-encoder
  1 shutter-encoder                  (Build Files Exist)
==> Packages to cleanBuild?
==> Diffs to show?
==> Making package: shutter-encoder 18.2-1 (Sat 03 Aug 2024 08:30:42 PM CDT)
==> Retrieving sources...
  -> Found Shutter%20Encoder%2018.2%20Linux%2064bits.deb
==> WARNING: Skipping verification of source file PGP signatures.
==> Validating source files with sha256sums...
    Shutter%20Encoder%2018.2%20Linux%2064bits.deb ... FAILED
==> ERROR: One or more files did not pass the validity check!
 -> error downloading sources: /home/arthurzw/.cache/yay/shutter-encoder
	 context: exit status 1
:: (1/1) Parsing SRCINFO: shutter-encoder
==> Making package: shutter-encoder 18.2-1 (Sat 03 Aug 2024 08:30:43 PM CDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
 -> error making: shutter-encoder-exit status 1
 -> Failed to install the following packages. Manual intervention is required:
shutter-encoder - exit status 1
@WrenchInThePlan
yay -S shutter-encoder-bin
has been installed (version 18.3-1) with no errors here.
and AppImage also works from here
Did you try update
yay
before installation?
Looks like it works fine for me with the Appimage download. Thanks for letting me know about it.
