Issue: Second seat (seat1) will not login. Upon entering password, the screen goes blank and then resets the greeter.
Following this guide: https://wiki.archlinux.org/title/Xorg_multiseat
I’m using lightdm and lightdm-gtk-greeter and made sure “greeter-session=lightdm-gtk-greeter” is set in the lightdm.conf
No custom Xorg configs
I verified users are in appropriate groups.
Any help or pointers in the right direction would be much appreciated.
## lightdm.log ##
[+7903.45s] DEBUG: User duckman authorized
[+7903.46s] DEBUG: Greeter requests session plasma
[+7903.46s] DEBUG: Seat seat1: Creating display server of type wayland
[+7903.46s] DEBUG: Seat seat1: Display server ready, running session
[+7903.46s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session6
[+7903.46s] DEBUG: Session pid=10888: Running command /etc/lightdm/Xsession /usr/lib/plasma-dbus-run-session-if-needed /usr/bin/startplasma-wayland
[+7903.46s] DEBUG: Creating shared data directory /var/lib/lightdm-data/duckman
[+7903.46s] DEBUG: Session pid=10888: Logging to .xsession-errors
[+7903.53s] DEBUG: Activating VT 0
[+7903.53s] WARNING: Error using VT_ACTIVATE 0 on /dev/tty0: No such device or address
[+7903.53s] DEBUG: Seat seat1: Stopping greeter
[+7903.53s] DEBUG: Terminating login1 session c7
[+7903.53s] DEBUG: Session pid=10871: Sending SIGTERM
[+7903.53s] DEBUG: Activating login1 session 10
[+7903.53s] DEBUG: Seat seat1 changes active session to 10
[+7903.53s] DEBUG: Session 10 is already active
[+7903.54s] DEBUG: Greeter closed communication channel
[+7903.54s] DEBUG: Session pid=10871: Exited with return value 0
[+7903.54s] DEBUG: Seat seat1: Session stopped
[+7903.54s] DEBUG: Seat seat1: Stopping display server, no sessions require it
[+7903.54s] DEBUG: Sending signal 15 to process 10831
[+7903.64s] DEBUG: Process 10831 exited with return value 0
[+7903.64s] DEBUG: XServer 1: X server stopped
[+7903.64s] DEBUG: XServer 1: Removing X server authority /run/lightdm/root/:1
[+7903.64s] DEBUG: Seat seat1: Display server stopped
[+7903.64s] DEBUG: Seat seat1: Active display server stopped, starting greeter
[+7903.64s] DEBUG: Seat seat1: Creating greeter session
[+7903.64s] DEBUG: Seat seat1: Creating display server of type x
[+7903.64s] DEBUG: Seat seat1: Starting local X display
[+7903.64s] DEBUG: XServer 1: Logging to /var/log/lightdm/x-1.log
[+7903.64s] DEBUG: XServer 1: Writing X server authority to /run/lightdm/root/:1
[+7903.64s] DEBUG: XServer 1: Launching X Server
[+7903.64s] DEBUG: Launching process 11951: /usr/bin/X :1 -seat seat1 -auth /run/lightdm/root/:1 -nolisten tcp
[+7903.64s] DEBUG: XServer 1: Waiting for ready signal from X server :1
[+7903.81s] DEBUG: Session pid=10888: Exited with return value 4
[+7903.81s] DEBUG: Seat seat1: Session stopped
[+7903.81s] DEBUG: Seat seat1: Stopping display server, no sessions require it
[+7903.81s] DEBUG: Seat seat1: Display server stopped
[+7903.81s] DEBUG: Seat seat1: Active display server stopped, starting greeter
[+7903.81s] DEBUG: Seat seat1: Switching to existing greeter
[+7904.25s] DEBUG: Got signal 10 from process 11951
[+7904.25s] DEBUG: XServer 1: Got signal from X server :1
[+7904.25s] DEBUG: XServer 1: Connecting to XServer :1
[+7904.25s] DEBUG: Seat seat1: Display server ready, starting session authentication
[+7904.25s] DEBUG: Session: Not setting XDG_VTNR
[+7904.25s] DEBUG: Session pid=12034: Started with service 'lightdm-greeter', username 'lightdm'
[+7904.26s] DEBUG: Session pid=12034: Authentication complete with return value 0: Success
[+7904.26s] DEBUG: Seat seat1: Session authenticated, running command
[+7904.26s] DEBUG: Session pid=12034: Not setting XDG_VTNR
[+7904.26s] DEBUG: Session pid=12034: Running command /usr/bin/lightdm-gtk-greeter
[+7904.26s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+7904.26s] DEBUG: Session pid=12034: Logging to /var/log/lightdm/seat1-greeter.log
[+7904.27s] DEBUG: Activating login1 session c8
[+7904.27s] DEBUG: Seat seat1 changes active session to c8
[+7904.27s] DEBUG: Session c8 is already active
[+7904.34s] DEBUG: Greeter connected version=1.32.0 api=1 resettable=false
[+7904.42s] DEBUG: Greeter start authentication for duckman
[+7904.42s] DEBUG: Session: Not setting XDG_VTNR
[+7904.42s] DEBUG: Session pid=12054: Started with service 'lightdm', username 'duckman'
[+7904.44s] DEBUG: Session pid=12054: Got 1 message(s) from PAM
[+7904.44s] DEBUG: Prompt greeter with 1 message(s)
