I have multiple drives on my system but two with OS, one with Endeavour and the other with Windows. I have been trying to reinstall Grub since I installed Windows 2nd but when I boot Endeavour from a live usb, I open the luks partitions and my issue comes when I try to mount them. Here is the drive info from
sudo parted -l
Model: Samsung SSD 980 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 963GB 963GB primary boot
2 963GB 1000GB 36.9GB primary
Model: KINGSTON OM3PDP3256B-A01 (nvme)
Disk /dev/nvme1n1: 256GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp, no_automount
2 106MB 123MB 16.8MB Microsoft reserved partition msftres, no_automount
3 123MB 255GB 255GB ntfs Basic data partition msftdata
4 255GB 256GB 794MB ntfs hidden, diag, no_automount
Here is the output when I try and open the luks partitions and mount them:
[liveuser@eos-2023.11.17 ~]$ sudo cryptsetup luksOpen /dev/nvme0n1p1 nvme01
Enter passphrase for /dev/nvme0n1p1:
[liveuser@eos-2023.11.17 ~]$ sudo cryptsetup luksOpen /dev/nvme0n1p2 nvme02
Enter passphrase for /dev/nvme0n1p2:**strong text**
[liveuser@eos-2023.11.17 ~]$ sudo mount /dev/mapper/nvme01 /part01
mount: /part01: mount point does not exist.
dmesg(1) may have more information after failed mount system call.
