When an Android is connected to my pc using USB cable via mtp: , if I try to copy/move multiple files at once, transfer stops after 1st file/after some time.
Also dolphin stops displaying Android directories if we refresh the tab.
To fix that I need to re-plug my phone using usb cable.
Please help me fixing this. I need to transfer folders of multiple files and I cannot do that now.
This may be the android device itself also, I have a similar issue on one of my phones and have put it down to the device as I don’t get it on other androids and it seems to have quite a few other issues/oddities when using it as I would normally use any other phone
That is up to you. I mean I know there are apps like Airdroid (or atleast used to be) I don’t know the state of these types of apps anymore however as i am comfortable keeping everything local.
You will need to have some expertise with Android and Linux command Line if you choose to do so. I’m not sure what android-file-transfer is I never heard of it until @Hystrix post. I don’t know if that would require USB debugging or not.
Edit: Yes I’m to lazy to go search besides its time for me to cook dinner
