Tracker-miner-fs-3 massive CPU usage
Hi,
I have a massive CPU usage (99%) from “tracker-miner-fs-3” each time I open my file manager.
My OS Endeavouros is up-to-date.
I use Gnome as a desktop manager.
killall tracker
return > tracker: no process found
Any idea how to resolve this problem?
This is supposed to act on the command that you provide tracker, which does not exist.
Find the specific command:
pgrep -a tracker
and either kill 9 the PID, or killall <command_name>.
OTOH, I would check more about this, with htop, or other process manager, to see what it is doing.
Actually, using htop, you can also do the above (find and kill) :person_shrugging:
Happy hunting! :cowboy_hat_face:
I don’t use Gnome and i don’t know much about this tracker miner. Seems like it is used for indexing among other things? :thinking:
https://man.archlinux.org/man/tracker-miner-fs-3.1.en
https://wiki.gnome.org/Projects/Tracker
Edit: I use Kde Btw! :wink:
I experienced the same issue the last couple of days. I am using gnome since a long time now. But this problem with CPU load for tracker-miner-fs-3 just started some days ago. Must have something to do with a recent update.
I also saw multiple coredumps related to the miner and the extract tool:
╰─# coredumpctl --no-pager
TIME                           PID  UID  GID SIG     COREFILE EXE                           SIZE
Sat 2023-03-18 23:21:14 CET  10041 1000 1000 SIGSEGV missing  /usr/lib/tracker-miner-fs-3      -
Sat 2023-03-18 23:21:48 CET  10616 1000 1000 SIGSEGV missing  /usr/lib/tracker-miner-fs-3      -
Sat 2023-03-18 23:21:58 CET  10791 1000 1000 SIGSEGV missing  /usr/lib/tracker-miner-fs-3      -
Sat 2023-03-18 23:22:39 CET  11158 1000 1000 SIGSEGV missing  /usr/lib/tracker-miner-fs-3      -
Wed 2023-03-22 10:50:09 CET  23349 1000 1000 SIGSEGV present  /usr/lib/tracker-miner-fs-3 327.1K
Wed 2023-03-22 10:51:38 CET  24594 1000 1000 SIGSEGV present  /usr/lib/tracker-miner-fs-3 326.5K
Wed 2023-03-22 10:53:46 CET  25964 1000 1000 SIGSEGV present  /usr/lib/tracker-miner-fs-3 326.0K
Wed 2023-03-22 11:02:11 CET  15386 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3   12.9M
Wed 2023-03-22 11:02:12 CET  34172 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3    8.6M
Wed 2023-03-22 12:54:07 CET   9728 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3   14.4M
Wed 2023-03-22 12:54:07 CET 209760 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3    4.9M
Wed 2023-03-22 13:15:03 CET 209872 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3   13.0M
Wed 2023-03-22 14:25:03 CET 373400 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3   13.7M
Wed 2023-03-22 15:05:03 CET 933355 1000 1000 SIGSEGV present  /usr/lib/tracker-extract-3   13.7M
Then I saw in the journal that the miner has some issue with specific AVI files in a specific folder. The error messages look like this
tracker-extract: Failed to update ignored file 'file:///myfolder/DSCFxxxx.AVI':
I found thousands of them in the log. I used dconf-editor to put *.AVI files on the exclusion list and I renamed that folder. Now the CPU load issue does not occur anymore.
I wonder why there is no such report on the Gnome Bug Tracker…
https://gitlab.gnome.org/groups/GNOME/-/issues
I mean it could be a Bug related to avi file format indeed.
I can try reproducing.
And as a hint if you do not use Gnome apps like music and documents and you arte not browsing/searching a huge bunch of files over the filebrowser itself you can sevely disable the tracker-miner.
here is a good summary of Gnome tracker.
It appears that Gnome Tracker is a core part of Gnome and is hard to eliminate,
but you might be interested in the How can I disable Tracker in GNOME? section.
Pudge
I’ll never use Gnome again even though it has been many years since, there getting as bad as TikToc.
Thanks for Openbox.
I actually do not want to disable it. I like the functionality it offers. I am an in the file manager nautilus and do a search, it not only searches for filenames but also for file content.
In the meantime I have reverted the changes I mentioned earlier. I removed *.AVI from the file exclusion list (in fact I am using default exclusions again) and I renamed the folder with the AVI files back to its original name. I rebooted and everything is normal. No CPU load.
But I do see a new core dump:
Thu 2023-03-23 16:27:24 CET 13707 1000 1000 SIGSEGV present /usr/lib/tracker-miner-fs-3 326.7K
The timestamp indicates that this happened directly after I reverted the changes. I wil monitor this now and see if it is getting worse again.
I get a core dump every time I do a “tracker3 info ...” on a movie file. If it is mkv, mp4 or avi. Is that the same for you?
╰─# tracker3 info Steve-Jobs.mkv
Querying information for entity: 'Steve-Jobs.mkv'
  No metadata available for that URI
Data object ?/data/media/Filme/MKV/Steve-Jobs.mkv? currently exists
results in:
Mär 23 16:58:14 rakete kernel: tracker-miner-f[33848]: segfault at 5562a7de8b3c ip 00007f141fbb2c3e sp 00007ffd28a04ac0 error 4 in libtracker-sparql-3.0.so.0.500.0[7f141fbad000+73000] likely on CPU 22 (core 12, socket 0)
Mär 23 16:58:14 rakete kernel: Code: 74 11 48 89 df ff 15 49 0a 0b 00 85 c0 0f 84 19 01 00 00 48 85 ed 74 54 ff 15 96 0d 0b 00 48 89 c6 48 8b 45 00 48 85 c0 74 05 <48> 39 30 74 3d 48 89 ef ff 15 1c 0a 0b 00 85 c0 75 30 48 8d 15 81
Mär 23 16:58:15 rakete systemd[1]: Started Process Core Dump (PID 33853/UID 0).
Mär 23 16:58:15 rakete systemd-coredump[33854]: [🡕] Process 33848 (tracker-miner-f) of user 1000 dumped core.
                                                 Stack trace of thread 33848:
                                                 #0  0x00007f141fbb2c3e tracker_sparql_connection_new (libtracker-sparql-3.0.so.0 + 0x1ec3e)
                                                 #1  0x00005567f109ac38 main (tracker-miner-fs-3 + 0xec38)
                                                 #2  0x00007f141f955790 n/a (libc.so.6 + 0x23790)
                                                 #3  0x00007f141f95584a __libc_start_main (libc.so.6 + 0x2384a)
                                                 #4  0x00005567f109bf45 _start (tracker-miner-fs-3 + 0xff45)
                                                 Stack trace of thread 33851:
                                                 #0  0x00007f141fe452d4 g_socket_condition_check (libgio-2.0.so.0 + 0x972d4)
                                                 #1  0x00007f141fec4a8a n/a (libgio-2.0.so.0 + 0x116a8a)
                                                 #2  0x00007f141fec4ba9 n/a (libgio-2.0.so.0 + 0x116ba9)
                                                 #3  0x00007f141fec617d n/a (libgio-2.0.so.0 + 0x11817d)
                                                 #4  0x00007f141fe567f4 n/a (libgio-2.0.so.0 + 0xa87f4)
                                                 #5  0x00007f141fe5a5ed n/a (libgio-2.0.so.0 + 0xac5ed)
                                                 #6  0x00007f141fec4931 n/a (libgio-2.0.so.0 + 0x116931)
                                                 #7  0x00007f141fe41ebe n/a (libgio-2.0.so.0 + 0x93ebe)
                                                 #8  0x00007f141ffddafb g_main_context_dispatch (libglib-2.0.so.0 + 0x5aafb)
                                                 #9  0x00007f142003a5d9 n/a (libglib-2.0.so.0 + 0xb75d9)
                                                 #10 0x00007f141ffdd0cf g_main_loop_run (libglib-2.0.so.0 + 0x5a0cf)
                                                 #11 0x00007f141febde4c n/a (libgio-2.0.so.0 + 0x10fe4c)
                                                 #12 0x00007f142000b7c5 n/a (libglib-2.0.so.0 + 0x887c5)
                                                 #13 0x00007f141f9b7bb5 n/a (libc.so.6 + 0x85bb5)
                                                 #14 0x00007f141fa39d90 n/a (libc.so.6 + 0x107d90)
                                                 Stack trace of thread 33850:
                                                 #0  0x00007f141fa2c9df __poll (libc.so.6 + 0xfa9df)
                                                 #1  0x00007f142003a53f n/a (libglib-2.0.so.0 + 0xb753f)
                                                 #2  0x00007f141ffdb382 g_main_context_iteration (libglib-2.0.so.0 + 0x58382)
                                                 #3  0x00007f141ffdb3d2 n/a (libglib-2.0.so.0 + 0x583d2)
                                                 #4  0x00007f142000b7c5 n/a (libglib-2.0.so.0 + 0x887c5)
                                                 #5  0x00007f141f9b7bb5 n/a (libc.so.6 + 0x85bb5)
                                                 #6  0x00007f141fa39d90 n/a (libc.so.6 + 0x107d90)
                                                 Stack trace of thread 33849:
                                                 #0  0x00007f141fa320dd syscall (libc.so.6 + 0x1000dd)
                                                 #1  0x00007f142002ea35 g_cond_wait (libglib-2.0.so.0 + 0xaba35)
                                                 #2  0x00007f141ffa7fc4 n/a (libglib-2.0.so.0 + 0x24fc4)
                                                 #3  0x00007f142000d43e n/a (libglib-2.0.so.0 + 0x8a43e)
                                                 Stack trace of thread 33852:
                                                 #3  0x00007f141eca2fde n/a (libdconfsettings.so + 0x5fde)
                                                 ELF object binary architecture: AMD x86-64
EDIT:
The core dump also happens with jpg and png files. It does not happen for txt, ods, odt, pdf.
its quite easy to disable tracker, its the first thing i always do, done it for years, no problems
sudo systemctl mask tracker-miner-fs-3.service tracker-store.service tracker-miner-fs.service tracker-miner-rss.service tracker-extract.service tracker-miner-apps.service tracker-writeback.service
might need a reboot
to revert i guess you do unmask
I want to make it work. I do not want to disable it.
let me check…
i do not have this here it just works fine and shows file infos…
But … i do use gnome unstable (44) currently…
same on current…
what does:
LANG=C tracker3 status show on yours?
Easy to disable it …just install KDE! :rofl:
╰─# LANG=C tracker3 status
Currently indexed: 11009 files, 892 folders
Remaining space on database partition: 317,8?GB (78,52%)
All data miners are idle, indexing complete
2 recorded failures
Path        Message
?path/f0598c6dfaee4909b1169b822035e537.gif Could not get any metadata for uri:'file:///home/matthias/Dokumente/?
/path-in-home//xyzxyz.pdf                         ?ms.tex? is not an absolute IRI
But then you have to disable baloo :tired_face:
Pudge
Not always… :wink:
