I get the following errors printed in red on the OEM splash screen (ASUS):
Error meassuring loader.conf into TPM: Volume full
Then on a new black screen, also printed in red:
Unable to add load options (i.e. kernel command) line measurements to PCR 12: Volume full
Couldn’t find an option to disable TPM in BIOS.
journalctl -k -b -0 --grep=tpm
dec 10 22:14:13 ux330 kernel: Command line: initrd=\5c066686c58c45bb92c458439675e6d7\6.12.1-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=6b4a244a-88ab-422a-b9ad-7db428927688 rw root=UUID=6b4a244a-88ab-422a-b9ad-7db4>
dec 10 22:14:13 ux330 kernel: efi: TPMFinalLog=0x9ad87000 ESRT=0x9b173e58 ACPI=0x9a96d000 ACPI 2.0=0x9a96d000 SMBIOS=0x9b16f000 SMBIOS 3.0=0x9b16e000 RNG=0x9a96c018 INITRD=0x94a314d8 TPMEventLog=0x9a964018
dec 10 22:14:13 ux330 kernel: ACPI: TPM2 0x000000009A9A2920 000034 (v03 Tpm2Tabl 00000001 AMI 00000000)
dec 10 22:14:13 ux330 kernel: ACPI: Reserving TPM2 table memory at [mem 0x9a9a2920-0x9a9a2953]
dec 10 22:14:13 ux330 kernel: Kernel command line: initrd=\5c066686c58c45bb92c458439675e6d7\6.12.1-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=6b4a244a-88ab-422a-b9ad-7db428927688 rw root=UUID=6b4a244a-88ab-422a-b9>
dec 10 22:14:14 ux330 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
dec 10 22:14:14 ux330 systemd[1]: systemd 256.9-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPT>
dec 10 22:14:16 ux330 systemd[1]: systemd 256.9-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPT>
dec 10 22:14:16 ux330 systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
dec 10 22:14:16 ux330 systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
dec 10 22:14:16 ux330 systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
dec 10 22:14:16 ux330 systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
The system boots without problems after this.
I didn’t get the error on my previous manjaro install.
