I am using kde on the 2022 ROG G14 GA402RK model.
The very bottom strip of my touchpad is not working for cursor movement, but it works for click and tap, and other area of the touchpad are all good.
And in BIOS, the cursor moves with the bottom part of the touchpad with no issue, so I think it is not the hardware issue?
any fix?
Solved by removing xf86-input-synaptics, (leave the libinput installed)
