Touchpad not working after sleep
The recover from suspension/sleep mostly work (hybrid suspension). When i wakeup my pc the wifi is off, but all i need to do is click the icon. The main issue is the disabled touchpad.
Browsing around i’ve found the working command to re-enable it:
sudo modprobe -r psmouse
sudo modprobe psmouse
any way to re-enable the touchpad (and if possible the wifi) after sleep with some script or something?
Update: following a (totally not ai) guide, ive added a “restart-touchpad” script in /lib/systemd/system-sleep/
instead of his command i used the one i knew works
if [[ $1 == post ]]; then
fi
with right click i select it as exeguible. After a couple of restart somehow now my touchpad works so i think i didn’t screw up too badly.
