Too many issues from dummy in Sway+NWg-shell
Hi!
I installed Sway+Nwg-shell and not at all works well. Who can I ask my questions how configure, resolve problems,etc.?
Post the correct problem.. Whit unspecified problem nobady can help.
But I recommend nwg shell with hyperland… works great.. And with undocumented problem even author of nwg she’ll can help, it’s nice guy. It helped me with something that was unexpected behavior of nwg login wit my specific config needs.
How did you install Sway?
sudo pacman -S sway
In real now I have removed Sway because Sway doesn't display titlebar - #4 by eso I wantd to manage windows of apps to the same like in DE
murzilka-eos@murzilka$ nwg-shell-config-hyprland
HYPRLAND_INSTANCE_SIGNATURE not found, terminating
I cannot install to hyprland
I just installed NWG-Shell with both Hyprland and Sway- the version is from April 2026 (I believe). I have only begun testing sway, but that works splendidly. Thus far I have encountered no problems. I followed the instructions here: https://wiki.archlinux.org/title/Nwg-shell
EDIT:
FWIW I just figured out that hyprland does NOT officially support nvidia drivers. I use nvidia for my local AI. Therefore, I’ll bypass trying hyprland until they support nvidia.
