I recently found, though, a dangerous area for the average user.
I would have thought this was a bad idea - if only because you probably would lose track of whether you were ‘in’ sudo or not… which can lead to permissions problems at the very least! I actually use su-c_wrapper to distinguish between ‘normal’ sudo and ‘really pay attention’ sudo type commands.
It doesn’t take long to ‘hard-wire’ the sudo password into your brain, so the effort this ‘saves’ is pretty minimal too. Not to mention what a mistyped entry in the config file will do!
Bad idea - better to make your sudo password really easy if it bothers you!!
Yes
My password is 123. I’m not trying to keep my laptop secure from other humans, but just want to give myself some thought before running command with sudo
