I have installed gvfs-mtp, thunar-volman, android-tools, android-udev & enabled file transfer on the phone, which is running Android 11. I shouldn’t have to, but I have also enabled usb debugging and authorized the fingerprint. I have enabled Volume Management in Thunar, and enabled ‘mount removable drives when hot-plugged’, ‘mount removable media when inserted’, and ‘browse removable media when inserted’. I have also tried two different usb cables and usb ports.
The phone mounts fine in Nemo. Manually specifying the mtp adress in Thunar does not work. This does not affect usb drives, which are automatically mounted in both file managers.
Output of pacman -Si thunar
Repository : extra
Version : 4.16.10-1
Description : Modern file manager for Xfce
Architecture : x86_64
URL : https://docs.xfce.org/xfce/thunar/start
Licenses : GPL2 LGPL2.1
Groups : xfce4
Provides : None
Depends On : desktop-file-utils libexif hicolor-icon-theme libnotify libgudev exo libxfce4util libxfce4ui libpng
Optional Deps : gvfs: trash support, mounting with udisk and remote filesystems
tumbler: thumbnail previews
thunar-volman: removable device management
thunar-archive-plugin: archive creation and extraction
thunar-media-tags-plugin: view/edit ID3/OGG tags
What more can I do?
