Hi Everyone, I am using the arc-dark theme and papirus icon theme.
I am having issue with Evolution mail app where the top bar doesn’t show the icons correctly. It is hard to read. If I change the theme to numix then I can see the icons correctly…
Is this GTK issue and any workaround? Any option to set custom theme per app?
Yaru-dark (yaru-gtk-theme) with papirus-dark (papirus-icon-theme), no issues. You might have to reconsider changing your theme or icon choice unfortunately as I don’t believe it’s a papirus icon issue. Feel free to make a bug report on the Papirus Github, they are quick to respond, but more than likely it’s more to do with the theme in combination with it than anything else.
