Hi Everyone, some of the emails on my gmail account has terrible font rendering issue. I’ve searched old threads but wasn’t sure if those solutions apply to my issue.
I have installed various font packs (Microsoft, Mac, Noto, Google etc…) but still facing the same issue.
It looks like Sans Sarif fonts or Calibri fonts aren’t displaying correctly in the mail apps (Evolution, Geary, and Thunderbird). However, when I open the same email in the Chromium app, I can read the emails just fine. No rendering issue.
In gnome or in kde, you can change the system font to multiple options. Maybe one of them is that horrible font and you change to a good one it will look better. The chromium browser is using the default on your system probably.
Obviously the font in use
Browsers use different fonts, depending on their default (browser) font and on the web page browsing.
I suggest you check which font is used in Chrome and try to use it (or a similar) in your system app in question (depends on toolkit used, GTK, QT, etc).
Either default Chrome font, or the one in Gmail web page (using dev tools).
I don’t remember or know exactly. If they have a font in-app setting try it. Else, according to their toolkit and user session, use respective configuration (Gnome settings/tweaks, kvantum, qt5ct, lxappearance, or other).
Never used Geary, but in Evolution : you can change the fonts in preferences. I use Open Sans regular and they appear fine on a 1366x768 laptop screen.
Ask about custom fonts here evolution-list@gnome.org
I suggest you to set your custom fonts manually in ~/.config/fontconfig/fonts.conf. Here is what mine looks like https://0x0.st/oP1h.xml. This should eliminate errors like this. After making your changes reboot or run fc-cache to rebuild fontconfig’s configuration and relaunch geary.
Thank you. This worked actually. I reverted my settings to the default (i.e minimum font size to be 0 in Evalution app) and added the following and it worked.
