Systemd | Hibernation fails after upgrading from 253.7 to 254 when failing to parse the resume_offset setting
After upgrading from systemd 253.7 to 254 I noticed hibernation stopped working and seeing the following eror in the system journals:
Aug 01 17:23:42 mani systemd-hibernate-resume-generator[100]: Failed to parse resume_offset=36151296..: Invalid argument
Aug 01 17:23:42 mani systemd-hibernate-resume-generator[100]: Failed to parse kernel command line, ignoring: Invalid argument
I confirmed hibernation was failing from terminal:
❯ systemctl hibernate
Call to Hibernate failed: Not enough swap space for hibernation
Note that my swap\hibernation file is 7.5 GB where my physical memory is 16 GB.
In order to get Hibernation to work again I downgraded to systemd build 253.7 (which was previously installed.
Defect:
Looks like the resume_offset= is now being parsed by systemd-hibernate-resume-generator. So the “…” in mine is now considered invalid.
So not a bug but a feature.
