hugo
June 18, 2023, 6:45pm
1
Hi,
when my system boots I am met with a frozen motherboard logo and nothing happens, but when I press F1 during boot and select EndeavourOS (6.3.8-arch1-1-fallback) instead of EndeavourOS (6.3.8-arch1-1), my system boots as normal. This has occured after updating my system after a 2 month break. How can I just boot into the working one by default or fix the default one?
Thanks
dalto
June 18, 2023, 6:59pm
2
Boot your system into the fallback and then try running sudo dracut-rebuild and see if that fixes it.
hugo
June 18, 2023, 7:40pm
3
I think my system is running on mkinitcpio as dracut doesn’t seem to be installed. Should I switch to dracut? Also I use systemd
dalto
June 18, 2023, 7:44pm
4
Oh, you probably were caught by that kernel-install-mkinitcpio issue.
No, you don’t need to.
Try running sudo reinstall-kernels
hugo
June 18, 2023, 7:46pm
5
That fixed it! Thank you very much
What is the difference between sudo dracut-rebuild and sudo reinstall-kernels?
pebcak
June 19, 2023, 11:58am
7
dzyndzla:
sudo dracut-rebuild
This rebuilds the initrds.
dzyndzla:
This rebuilds the initrds as well as creates/updates the boot entries.
Ref:
https://discovery.endeavouros.com/installation/dracut/2022/12/
https://discovery.endeavouros.com/installation/systemd-boot/2022/12/
dalto
June 19, 2023, 12:39pm
8
reinstall-kernels does 4 things:
Rebuilds the initrds
Installs the kernel(s) to the EFI partition
Installs the microcode to the EFI partition(mkinitcpio only)
Creates/updates the boot entries
