System won't boot because /boot/vmlinuz-linux not found
Hey everyone! Basically as the title says, I am having trouble booting because when it tries to load the kernel it throws the error
“file ‘/@/boot/vmzlinuz-linux’ not found”
I went ahead and took a picture if it’ll be helpful, though I do apologize because it’s not a screenshot
Anyone know what I can do to recover my system? Am using BTRFS if that’s relevant
arch-chroot into your system and reinstall the package linux
That typically happens when an update is interrupted
Would I need to do that off a live USB?
yes
Edit:
look here, for more information.
is your /boot also btrfs ?
Hey everyone, I’ve gone ahead and chrooted into my system and updated the kernel. It is now giving me a separate error
It seemed that other people who had this error had to run the command mkinitcpio -P
to fix their issues, but when I did this it just gave me an error saying it failed to detect root filesystem.
When I tried to just update everything on my system instead, that gave write errors. Indeed when I decided to test it out by just creating a random .txt file somewhere, Vim wouldn’t alllow me to write it
Does anyone have any suggestions for the way forward? And thank you everyone for all the help so far :slight_smile:
How can I check this?
You see in etc/fstab… was curius about @ sign in the picture
Doesn’t seem so, says boot/efi is classified under vfat while everything else is btrfs
If your disk has gone read-only then this implies it has errors.
There may be ways to fix this, but the quickest and easiest workaround would be to reinstall.
/@/boot
No seperate boot partition. The boot directory is under / which is a subvolume (@) in a btrfs filesystem.
ok :slight_smile: cool
