Xorg log content:
[ 6.819]
X.Org X Server 1.21.1.5
X Protocol Version 11, Revision 0
[ 6.819] Current Operating System: Linux LenovoLegion5 6.0.12-arch1-1 #1 SMP PREEMPT_DYNAMIC Thu, 08 Dec 2022 11:03:38 +0000 x86_64
[ 6.819] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=f466c175-4048-4b5b-9c8e-d9ab89e767e3 rw rootflags=subvol=@ quiet loglevel=3 nowatchdog nvme_load=YES nvidia-drm.modeset=1
[ 6.819]
[ 6.819] Current version of pixman: 0.42.2
[ 6.819] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 6.819] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 6.819] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 19 16:04:30 2022
[ 6.820] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.820] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.820] (==) ServerLayout "layout"
[ 6.820] (**) |-->Screen "integrated" (0)
[ 6.820] (**) | |-->Monitor "<default monitor>"
[ 6.821] (**) | |-->Device "integrated"
[ 6.821] (**) | |-->GPUDevice "nvidia"
[ 6.821] (==) No monitor specified for screen "integrated".
Using a default monitor configuration.
[ 6.821] (**) |-->Inactive Device "nvidia"
[ 6.821] (==) Automatically adding devices
[ 6.821] (==) Automatically enabling devices
[ 6.821] (==) Automatically adding GPU devices
[ 6.821] (==) Automatically binding GPU devices
[ 6.821] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.821] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 6.821] Entry deleted from font path.
[ 6.821] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 6.821] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 6.821] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.821] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.821] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.821] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.821] (==) FontPath set to:
[ 6.821] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 6.821] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 6.821] (II) Module ABI versions:
[ 6.821] X.Org ANSI C Emulation: 0.4
[ 6.821] X.Org Video Driver: 25.2
[ 6.821] X.Org XInput driver : 24.4
[ 6.821] X.Org Server Extension : 10.0
[ 6.822] (++) using VT number 7
[ 6.822] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.822] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.822] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card1
[ 6.846] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.846] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.0/drm/card0
[ 6.861] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 6.862] (--) PCI: (1@0:0:0) 10de:1f15:17aa:3a47 rev 161, Mem @ 0xd0000000/16777216, 0x1ffc0000000/268435456, 0x1ffd0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 6.862] (--) PCI:*(5@0:0:0) 1002:1636:17aa:3a47 rev 198, Mem @ 0x1ffe0000000/268435456, 0x1fff0000000/2097152, 0xd1500000/524288, I/O @ 0x00001000/256
[ 6.862] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.862] (II) LoadModule: "glx"
[ 6.862] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.872] (II) Module glx: vendor="X.Org Foundation"
[ 6.872] compiled for 1.21.1.5, module version = 1.0.0
[ 6.872] ABI class: X.Org Server Extension, version 10.0
[ 6.872] (II) LoadModule: "modesetting"
[ 6.872] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.875] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.875] compiled for 1.21.1.5, module version = 1.21.1
[ 6.875] Module class: X.Org Video Driver
[ 6.875] ABI class: X.Org Video Driver, version 25.2
[ 6.875] (II) LoadModule: "nvidia"
[ 6.875] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 6.881] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 6.882] compiled for 1.6.99.901, module version = 1.0.0
[ 6.882] Module class: X.Org Video Driver
[ 6.882] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.882] (II) NVIDIA dlloader X Driver 525.60.11 Wed Nov 23 22:56:57 UTC 2022
[ 6.882] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.900] (II) modeset(0): using drv /dev/dri/card0
[ 6.901] (II) Loading sub module "fb"
[ 6.901] (II) LoadModule: "fb"
[ 6.901] (II) Module "fb" already built-in
[ 6.901] (II) Loading sub module "wfb"
[ 6.901] (II) LoadModule: "wfb"
[ 6.901] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 6.902] (II) Module wfb: vendor="X.Org Foundation"
[ 6.902] compiled for 1.21.1.5, module version = 1.0.0
[ 6.902] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.902] (II) Loading sub module "ramdac"
[ 6.902] (II) LoadModule: "ramdac"
[ 6.902] (II) Module "ramdac" already built-in
[ 6.902] (II) modeset(0): Creating default Display subsection in Screen section
"integrated" for depth/fbbpp 24/32
[ 6.902] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 6.902] (==) modeset(0): RGB weight 888
[ 6.903] (==) modeset(0): Default visual is TrueColor
[ 6.903] (II) Loading sub module "glamoregl"
[ 6.903] (II) LoadModule: "glamoregl"
[ 6.903] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 6.907] (II) Module glamoregl: vendor="X.Org Foundation"
[ 6.908] compiled for 1.21.1.5, module version = 1.0.1
[ 6.908] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.113] (II) modeset(0): glamor X acceleration enabled on AMD Radeon Graphics (renoir, LLVM 14.0.6, DRM 3.48, 6.0.12-arch1-1)
[ 7.113] (II) modeset(0): glamor initialized
[ 7.113] (==) modeset(0): VariableRefresh: disabled
[ 7.113] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 7.115] (II) modeset(0): Output eDP-1 has no monitor section
[ 7.117] (II) modeset(0): EDID for output eDP-1
[ 7.117] (II) modeset(0): Manufacturer: BOE Model: 8df Serial#: 0
[ 7.117] (II) modeset(0): Year: 2019 Week: 37
[ 7.117] (II) modeset(0): EDID Version: 1.4
[ 7.117] (II) modeset(0): Digital Display Input
[ 7.117] (II) modeset(0): 8 bits per channel
[ 7.117] (II) modeset(0): Digital interface is DisplayPort
[ 7.117] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 7.117] (II) modeset(0): Gamma: 2.20
[ 7.117] (II) modeset(0): No DPMS capabilities specified
[ 7.117] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 7.117] (II) modeset(0): Default color space is primary color space
[ 7.117] (II) modeset(0): First detailed timing is preferred mode
[ 7.117] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 7.117] (II) modeset(0): Display is continuous-frequency
[ 7.117] (II) modeset(0): redX: 0.653 redY: 0.329 greenX: 0.298 greenY: 0.605
[ 7.117] (II) modeset(0): blueX: 0.150 blueY: 0.061 whiteX: 0.313 whiteY: 0.329
[ 7.117] (II) modeset(0): Manufacturer's mask: 0
[ 7.117] (II) modeset(0): Supported detailed timing:
[ 7.117] (II) modeset(0): clock: 352.2 MHz Image Size: 344 x 194 mm
[ 7.117] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 7.117] (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1089 v_blanking: 1176 v_border: 0
[ 7.117] (II) modeset(0): BOE CQ
[ 7.117] (II) modeset(0): NV156FHM-NY4
[ 7.117] (II) modeset(0): EDID (in hex):
[ 7.117] (II) modeset(0): 00ffffffffffff0009e5df0800000000
[ 7.117] (II) modeset(0): 251d0104a52213780754a5a7544c9b26
[ 7.117] (II) modeset(0): 0f505400000001010101010101010101
[ 7.117] (II) modeset(0): 010101010101988980a0703860403020
[ 7.117] (II) modeset(0): 360058c21000001a0000000000000000
[ 7.117] (II) modeset(0): 00000000000000000000000000fe0042
[ 7.117] (II) modeset(0): 4f452043510a202020202020000000fe
[ 7.117] (II) modeset(0): 004e5631353646484d2d4e59340a00fd
[ 7.118] (II) modeset(0): Printing probed modes for output eDP-1
[ 7.118] (II) modeset(0): Modeline "1920x1080"x144.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 7.118] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 7.118] (II) modeset(0): Modeline "1680x1050"x144.0 352.24 1680 1968 2000 2080 1050 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x1024"x144.0 352.24 1280 1968 2000 2080 1024 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1440x900"x144.0 352.24 1440 1968 2000 2080 900 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x800"x144.0 352.24 1280 1968 2000 2080 800 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x720"x144.0 352.24 1280 1968 2000 2080 720 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x144.0 352.24 1024 1968 2000 2080 768 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "1024x768"x170.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x150.1 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x768i"x43.5 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x720"x170.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x720"x150.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "928x696"x150.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "896x672"x150.1 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x144.0 352.24 800 1968 2000 2080 600 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "800x600"x170.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x150.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x140.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x130.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "700x525"x149.5 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x512"x170.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x512"x150.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x144.0 352.24 640 1968 2000 2080 480 1083 1089 1176 +hsync -vsync (169.3 kHz e)
[ 7.118] (II) modeset(0): Modeline "640x480"x170.2 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "576x432"x150.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x384"x170.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x384"x150.1 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x384"x140.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "416x312"x149.3 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "400x300"x170.5 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "400x300"x144.4 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "400x300"x150.2 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 7.118] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 7.118] (II) modeset(0): Modeline "320x240"x170.4 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 7.118] (II) modeset(0): Modeline "320x240"x145.6 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "320x240"x150.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 7.118] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 7.118] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 7.118] (II) modeset(0): Modeline "360x200"x170.1 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 7.118] (II) modeset(0): Modeline "320x200"x170.5 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 7.119] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 7.119] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 7.119] (II) modeset(0): Modeline "320x175"x170.5 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 7.119] (II) modeset(0): Output eDP-1 connected
[ 7.119] (II) modeset(0): Using exact sizes for initial modes
[ 7.119] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 7.119] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.119] (==) modeset(0): DPI set to (96, 96)
[ 7.119] (II) Loading sub module "fb"
[ 7.119] (II) LoadModule: "fb"
[ 7.119] (II) Module "fb" already built-in
[ 7.119] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 7.119] (==) NVIDIA(G0): RGB weight 888
[ 7.119] (==) NVIDIA(G0): Default visual is TrueColor
[ 7.119] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.119] (**) Option "AllowNVIDIAGpuScreens"
[ 7.119] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 7.119] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 7.119] (**) NVIDIA(G0): Option "Coolbits" "28"
[ 7.119] (**) NVIDIA(G0): Enabling 2D acceleration
[ 7.119] (II) Loading sub module "glxserver_nvidia"
[ 7.119] (II) LoadModule: "glxserver_nvidia"
[ 7.119] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.158] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.158] compiled for 1.6.99.901, module version = 1.0.0
[ 7.158] Module class: X.Org Server Extension
[ 7.158] (II) NVIDIA GLX Module 525.60.11 Wed Nov 23 22:51:25 UTC 2022
[ 7.158] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 7.159] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 7.159] (--) NVIDIA(0): DFP-0
[ 7.159] (--) NVIDIA(0): DFP-1
[ 7.159] (--) NVIDIA(0): DFP-2
[ 7.159] (--) NVIDIA(0): DFP-3
[ 7.160] (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce RTX 2060 (TU106-A) at PCI:1:0:0
[ 7.160] (II) NVIDIA(G0): (GPU-0)
[ 7.160] (--) NVIDIA(G0): Memory: 6291456 kBytes
[ 7.160] (--) NVIDIA(G0): VideoBIOS: 90.06.5b.00.41
[ 7.160] (II) NVIDIA(G0): Detected PCI Express Link width: 16X
[ 7.160] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 7.160] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 7.160] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 7.160] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 7.160] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 7.160] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 7.160] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 7.160] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 7.160] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 7.160] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 7.160] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 7.160] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 7.165] (II) NVIDIA(G0): Validated MetaModes:
[ 7.165] (II) NVIDIA(G0): "NULL"
[ 7.165] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 7.165] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 7.165] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 7.194] (==) modeset(0): Backing store enabled
[ 7.194] (==) modeset(0): Silken mouse enabled
[ 7.195] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 7.195] (==) modeset(0): DPMS enabled
[ 7.195] (WW) modeset(0): Option "DRI" is not used
[ 7.195] (II) modeset(0): [DRI2] Setup complete
[ 7.195] (II) modeset(0): [DRI2] DRI driver: radeonsi
[ 7.195] (II) modeset(0): [DRI2] VDPAU driver: radeonsi
[ 7.195] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 7.195] (II) NVIDIA: access.
[ 7.203] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 7.203] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 7.204] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 7.204] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 7.204] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 7.204] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 7.204] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 7.204] (II) NVIDIA(G0): Config Options in the README.
[ 7.217] (II) NVIDIA(G0): Setting mode "NULL"
[ 7.228] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 7.228] (==) NVIDIA(G0): Backing store enabled
[ 7.228] (==) NVIDIA(G0): Silken mouse enabled
[ 7.228] (==) NVIDIA(G0): DPMS enabled
[ 7.228] (II) Loading sub module "dri2"
[ 7.228] (II) LoadModule: "dri2"
[ 7.228] (II) Module "dri2" already built-in
[ 7.228] (II) NVIDIA(G0): [DRI2] Setup complete
[ 7.228] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 7.228] (II) Initializing extension Generic Event Extension
[ 7.228] (II) Initializing extension SHAPE
[ 7.228] (II) Initializing extension MIT-SHM
[ 7.228] (II) Initializing extension XInputExtension
[ 7.228] (II) Initializing extension XTEST
[ 7.228] (II) Initializing extension BIG-REQUESTS
[ 7.228] (II) Initializing extension SYNC
[ 7.229] (II) Initializing extension XKEYBOARD
[ 7.229] (II) Initializing extension XC-MISC
[ 7.229] (II) Initializing extension SECURITY
[ 7.229] (II) Initializing extension XFIXES
[ 7.229] (II) Initializing extension RENDER
[ 7.229] (II) Initializing extension RANDR
[ 7.229] (II) Initializing extension COMPOSITE
[ 7.229] (II) Initializing extension DAMAGE
[ 7.229] (II) Initializing extension MIT-SCREEN-SAVER
[ 7.229] (II) Initializing extension DOUBLE-BUFFER
[ 7.229] (II) Initializing extension RECORD
[ 7.229] (II) Initializing extension DPMS
[ 7.229] (II) Initializing extension Present
[ 7.229] (II) Initializing extension DRI3
[ 7.229] (II) Initializing extension X-Resource
[ 7.229] (II) Initializing extension XVideo
[ 7.229] (II) Initializing extension XVideo-MotionCompensation
[ 7.229] (II) Initializing extension GLX
[ 7.230] (II) Indirect GLX disabled.
[ 7.233] (II) AIGLX: Loaded and initialized radeonsi
[ 7.233] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 7.233] (II) Initializing extension XFree86-VidModeExtension
[ 7.233] (II) Initializing extension XFree86-DGA
[ 7.233] (II) Initializing extension XFree86-DRI
[ 7.233] (II) Initializing extension DRI2
[ 7.233] (II) Initializing extension NV-GLX
[ 7.233] (II) Initializing extension NV-CONTROL
[ 7.233] (II) modeset(0): Damage tracking initialized
[ 7.233] (II) modeset(0): Setting screen physical size to 508 x 285
[ 7.272] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.272] (**) Power Button: Applying InputClass "devname"
[ 7.272] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.272] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.272] (II) LoadModule: "libinput"
[ 7.272] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.276] (II) Module libinput: vendor="X.Org Foundation"
[ 7.276] compiled for 1.21.1.3, module version = 1.2.1
[ 7.276] Module class: X.Org XInput Driver
[ 7.276] ABI class: X.Org XInput driver, version 24.4
[ 7.276] (II) Using input driver 'libinput' for 'Power Button'
[ 7.276] (**) Power Button: always reports core events
[ 7.276] (**) Option "Device" "/dev/input/event2"
[ 7.278] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.278] (II) event2 - Power Button: device is a keyboard
[ 7.278] (II) event2 - Power Button: device removed
[ 7.316] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 7.317] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.317] (**) Option "xkb_layout" "us"
[ 7.317] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.317] (II) event2 - Power Button: device is a keyboard
[ 7.318] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 7.318] (**) Video Bus: Applying InputClass "devname"
[ 7.318] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.318] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.318] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.318] (**) Video Bus: always reports core events
[ 7.318] (**) Option "Device" "/dev/input/event4"
[ 7.318] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 7.318] (II) event4 - Video Bus: device is a keyboard
[ 7.318] (II) event4 - Video Bus: device removed
[ 7.353] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input4/event4"
[ 7.353] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 7.353] (**) Option "xkb_layout" "us"
[ 7.354] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 7.354] (II) event4 - Video Bus: device is a keyboard
[ 7.355] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[ 7.355] (**) Video Bus: Applying InputClass "devname"
[ 7.355] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.355] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.355] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.355] (**) Video Bus: always reports core events
[ 7.355] (**) Option "Device" "/dev/input/event5"
[ 7.355] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 7.355] (II) event5 - Video Bus: device is a keyboard
[ 7.355] (II) event5 - Video Bus: device removed
[ 7.389] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:16/LNXVIDEO:01/input/input5/event5"
[ 7.390] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 7.390] (**) Option "xkb_layout" "us"
[ 7.390] (II) event5 - Video Bus: is tagged by udev as: Keyboard
[ 7.390] (II) event5 - Video Bus: device is a keyboard
[ 7.391] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.391] (**) Power Button: Applying InputClass "devname"
[ 7.391] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.391] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.391] (II) Using input driver 'libinput' for 'Power Button'
[ 7.391] (**) Power Button: always reports core events
[ 7.391] (**) Option "Device" "/dev/input/event1"
[ 7.391] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.391] (II) event1 - Power Button: device is a keyboard
[ 7.391] (II) event1 - Power Button: device removed
[ 7.409] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 7.409] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 7.409] (**) Option "xkb_layout" "us"
[ 7.410] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.410] (II) event1 - Power Button: device is a keyboard
[ 7.411] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 7.411] (**) Lid Switch: Applying InputClass "devname"
[ 7.411] (II) Using input driver 'libinput' for 'Lid Switch'
[ 7.411] (**) Lid Switch: always reports core events
[ 7.411] (**) Option "Device" "/dev/input/event0"
[ 7.411] (II) event0 - Lid Switch: is tagged by udev as: Switch
[ 7.411] (II) event0 - Lid Switch: device is a switch device
[ 7.411] (II) event0 - Lid Switch: device removed
[ 7.426] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0/event0"
[ 7.426] (II) XINPUT: Adding extended input device "Lid Switch" (type: KEYBOARD, id 10)
[ 7.427] (II) event0 - Lid Switch: is tagged by udev as: Switch
[ 7.427] (II) event0 - Lid Switch: device is a switch device
[ 7.428] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event17)
[ 7.428] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[ 7.428] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[ 7.428] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[ 7.428] (**) Option "Device" "/dev/input/event17"
[ 7.428] (II) event17 - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[ 7.463] (II) event17 - not using input device '/dev/input/event17'.
[ 7.463] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event17
[ 7.463] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[ 7.463] (II) UnloadModule: "libinput"
[ 7.463] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event18)
[ 7.463] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[ 7.463] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[ 7.463] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[ 7.463] (**) Option "Device" "/dev/input/event18"
[ 7.464] (II) event18 - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[ 7.499] (II) event18 - not using input device '/dev/input/event18'.
[ 7.500] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event18
[ 7.500] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[ 7.500] (II) UnloadModule: "libinput"
[ 7.500] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[ 7.500] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[ 7.500] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[ 7.500] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[ 7.500] (**) Option "Device" "/dev/input/event19"
[ 7.501] (II) event19 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[ 7.553] (II) event19 - not using input device '/dev/input/event19'.
[ 7.553] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event19
[ 7.553] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[ 7.553] (II) UnloadModule: "libinput"
[ 7.554] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[ 7.554] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[ 7.554] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[ 7.554] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[ 7.554] (**) Option "Device" "/dev/input/event20"
[ 7.554] (II) event20 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[ 7.589] (II) event20 - not using input device '/dev/input/event20'.
[ 7.590] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event20
[ 7.590] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[ 7.590] (II) UnloadModule: "libinput"
[ 7.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event21)
[ 7.590] (**) HDA NVidia HDMI/DP,pcm=10: Applying InputClass "devname"
[ 7.590] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=10'
[ 7.590] (**) HDA NVidia HDMI/DP,pcm=10: always reports core events
[ 7.590] (**) Option "Device" "/dev/input/event21"
[ 7.591] (II) event21 - HDA NVidia HDMI/DP,pcm=10: is tagged by udev as: Switch
[ 7.646] (II) event21 - not using input device '/dev/input/event21'.
[ 7.646] (EE) libinput: HDA NVidia HDMI/DP,pcm=10: Failed to create a device for /dev/input/event21
[ 7.646] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=10"
[ 7.646] (II) UnloadModule: "libinput"
[ 7.647] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event8)
[ 7.647] (**) Integrated Camera: Integrated C: Applying InputClass "devname"
[ 7.647] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 7.647] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 7.647] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 7.647] (**) Integrated Camera: Integrated C: always reports core events
[ 7.648] (**) Option "Device" "/dev/input/event8"
[ 7.648] (II) event8 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 7.648] (II) event8 - Integrated Camera: Integrated C: device is a keyboard
[ 7.648] (II) event8 - Integrated Camera: Integrated C: device removed
[ 7.693] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb3/3-3/3-3:1.0/input/input9/event8"
[ 7.693] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 11)
[ 7.693] (**) Option "xkb_layout" "us"
[ 7.695] (II) event8 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 7.695] (II) event8 - Integrated Camera: Integrated C: device is a keyboard
[ 7.697] (II) config/udev: Adding input device SPEEDLINK TORID (/dev/input/event10)
[ 7.697] (**) SPEEDLINK TORID: Applying InputClass "devname"
[ 7.697] (II) Using input driver 'libinput' for 'SPEEDLINK TORID'
[ 7.697] (**) SPEEDLINK TORID: always reports core events
[ 7.697] (**) Option "Device" "/dev/input/event10"
[ 7.755] (II) event10 - SPEEDLINK TORID: is tagged by udev as: Joystick
[ 7.755] (II) event10 - SPEEDLINK TORID: device is a joystick or a gamepad, ignoring
[ 7.786] (II) event10 - not using input device '/dev/input/event10'.
[ 7.786] (EE) libinput: SPEEDLINK TORID: Failed to create a device for /dev/input/event10
[ 7.786] (EE) PreInit returned 2 for "SPEEDLINK TORID"
[ 7.786] (II) UnloadModule: "libinput"
[ 7.788] (II) config/udev: Adding input device SPEEDLINK TORID (/dev/input/js0)
[ 7.788] (**) SPEEDLINK TORID: Applying InputClass "devname"
[ 7.788] (II) Using input driver 'libinput' for 'SPEEDLINK TORID'
[ 7.788] (**) SPEEDLINK TORID: always reports core events
[ 7.788] (**) Option "Device" "/dev/input/js0"
[ 7.886] (II) js0 - not using input device '/dev/input/js0'.
[ 7.886] (EE) libinput: SPEEDLINK TORID: Failed to create a device for /dev/input/js0
[ 7.886] (EE) PreInit returned 2 for "SPEEDLINK TORID"
[ 7.886] (II) UnloadModule: "libinput"
[ 7.888] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event15)
[ 7.888] (**) Logitech Wireless Mouse: Applying InputClass "devname"
[ 7.888] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 7.888] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 7.888] (**) Logitech Wireless Mouse: always reports core events
[ 7.888] (**) Option "Device" "/dev/input/event15"
[ 7.891] (II) event15 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 7.891] (II) event15 - Logitech Wireless Mouse: device is a pointer
[ 7.891] (II) event15 - Logitech Wireless Mouse: device removed
[ 7.946] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb5/5-1/5-1.2/5-1.2:1.1/0003:046D:C534.0005/0003:046D:4054.0006/input/input34/event15"
[ 7.946] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 12)
[ 7.947] (**) Option "AccelerationScheme" "none"
[ 7.947] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[ 7.947] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 7.947] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 7.950] (II) event15 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 7.950] (II) event15 - Logitech Wireless Mouse: device is a pointer
[ 7.952] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse2)
[ 7.952] (**) Logitech Wireless Mouse: Applying InputClass "devname"
[ 7.952] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 7.952] (**) Logitech Wireless Mouse: always reports core events
[ 7.952] (**) Option "Device" "/dev/input/mouse2"
[ 7.996] (II) mouse2 - not using input device '/dev/input/mouse2'.
[ 7.996] (EE) libinput: Logitech Wireless Mouse: Failed to create a device for /dev/input/mouse2
[ 7.996] (EE) PreInit returned 2 for "Logitech Wireless Mouse"
[ 7.996] (II) UnloadModule: "libinput"
[ 7.998] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Keyboard (/dev/input/event11)
[ 7.998] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "devname"
[ 7.998] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.998] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[ 7.998] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[ 7.998] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[ 7.998] (**) Option "Device" "/dev/input/event11"
[ 8.000] (II) event11 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[ 8.000] (II) event11 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[ 8.002] (II) event11 - ITE Tech. Inc. ITE Device(8910) Keyboard: device removed
[ 8.026] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: needs a virtual subdevice
[ 8.027] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb5/5-4/5-4:1.0/0003:048D:C100.0003/input/input17/event11"
[ 8.027] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: MOUSE, id 13)
[ 8.027] (**) Option "AccelerationScheme" "none"
[ 8.027] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) selected scheme none/0
[ 8.027] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration factor: 2.000
[ 8.027] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: (accel) acceleration threshold: 4
[ 8.029] (II) event11 - ITE Tech. Inc. ITE Device(8910) Keyboard: is tagged by udev as: Keyboard
[ 8.029] (II) event11 - ITE Tech. Inc. ITE Device(8910) Keyboard: device is a keyboard
[ 8.032] (II) config/udev: Adding input device ITE Tech. Inc. ITE Device(8910) Wireless Radio Control (/dev/input/event12)
[ 8.032] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "devname"
[ 8.032] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 8.032] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: Applying InputClass "system-keyboard"
[ 8.032] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Wireless Radio Control'
[ 8.032] (**) ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: always reports core events
[ 8.032] (**) Option "Device" "/dev/input/event12"
[ 8.034] (II) event12 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[ 8.034] (II) event12 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[ 8.035] (II) event12 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device removed
[ 8.086] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb5/5-4/5-4:1.0/0003:048D:C100.0003/input/input18/event12"
[ 8.086] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Wireless Radio Control" (type: KEYBOARD, id 14)
[ 8.086] (**) Option "xkb_layout" "us"
[ 8.089] (II) event12 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: is tagged by udev as: Keyboard
[ 8.089] (II) event12 - ITE Tech. Inc. ITE Device(8910) Wireless Radio Control: device is a keyboard
[ 8.090] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event13)
[ 8.091] (**) HD-Audio Generic Mic: Applying InputClass "devname"
[ 8.091] (II) Using input driver 'libinput' for 'HD-Audio Generic Mic'
[ 8.091] (**) HD-Audio Generic Mic: always reports core events
[ 8.091] (**) Option "Device" "/dev/input/event13"
[ 8.092] (II) event13 - HD-Audio Generic Mic: is tagged by udev as: Switch
[ 8.136] (II) event13 - not using input device '/dev/input/event13'.
[ 8.136] (EE) libinput: HD-Audio Generic Mic: Failed to create a device for /dev/input/event13
[ 8.136] (EE) PreInit returned 2 for "HD-Audio Generic Mic"
[ 8.136] (II) UnloadModule: "libinput"
[ 8.137] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event14)
[ 8.137] (**) HD-Audio Generic Headphone: Applying InputClass "devname"
[ 8.137] (II) Using input driver 'libinput' for 'HD-Audio Generic Headphone'
[ 8.137] (**) HD-Audio Generic Headphone: always reports core events
[ 8.137] (**) Option "Device" "/dev/input/event14"
[ 8.138] (II) event14 - HD-Audio Generic Headphone: is tagged by udev as: Switch
[ 8.179] (II) event14 - not using input device '/dev/input/event14'.
[ 8.180] (EE) libinput: HD-Audio Generic Headphone: Failed to create a device for /dev/input/event14
[ 8.180] (EE) PreInit returned 2 for "HD-Audio Generic Headphone"
[ 8.180] (II) UnloadModule: "libinput"
[ 8.180] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event9)
[ 8.180] (**) Ideapad extra buttons: Applying InputClass "devname"
[ 8.181] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 8.181] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 8.181] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 8.181] (**) Ideapad extra buttons: always reports core events
[ 8.181] (**) Option "Device" "/dev/input/event9"
[ 8.182] (II) event9 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 8.182] (II) event9 - Ideapad extra buttons: device is a keyboard
[ 8.182] (II) event9 - Ideapad extra buttons: device removed
[ 8.216] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input10/event9"
[ 8.216] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 15)
[ 8.216] (**) Option "xkb_layout" "us"
[ 8.218] (II) event9 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 8.218] (II) event9 - Ideapad extra buttons: device is a keyboard
[ 8.219] (II) config/udev: Adding input device MSFT0001:00 06CB:7F28 Mouse (/dev/input/event6)
[ 8.219] (**) MSFT0001:00 06CB:7F28 Mouse: Applying InputClass "devname"
[ 8.219] (**) MSFT0001:00 06CB:7F28 Mouse: Applying InputClass "libinput pointer catchall"
[ 8.219] (II) Using input driver 'libinput' for 'MSFT0001:00 06CB:7F28 Mouse'
[ 8.219] (**) MSFT0001:00 06CB:7F28 Mouse: always reports core events
[ 8.219] (**) Option "Device" "/dev/input/event6"
[ 8.221] (II) event6 - MSFT0001:00 06CB:7F28 Mouse: is tagged by udev as: Mouse Pointingstick
[ 8.222] (II) event6 - MSFT0001:00 06CB:7F28 Mouse: device is a pointer
[ 8.224] (II) event6 - MSFT0001:00 06CB:7F28 Mouse: device removed
[ 8.266] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:06CB:7F28.0001/input/input25/event6"
[ 8.266] (II) XINPUT: Adding extended input device "MSFT0001:00 06CB:7F28 Mouse" (type: MOUSE, id 16)
[ 8.267] (**) Option "AccelerationScheme" "none"
[ 8.267] (**) MSFT0001:00 06CB:7F28 Mouse: (accel) selected scheme none/0
[ 8.267] (**) MSFT0001:00 06CB:7F28 Mouse: (accel) acceleration factor: 2.000
[ 8.267] (**) MSFT0001:00 06CB:7F28 Mouse: (accel) acceleration threshold: 4
[ 8.268] (II) event6 - MSFT0001:00 06CB:7F28 Mouse: is tagged by udev as: Mouse Pointingstick
[ 8.269] (II) event6 - MSFT0001:00 06CB:7F28 Mouse: device is a pointer
[ 8.272] (II) config/udev: Adding input device MSFT0001:00 06CB:7F28 Mouse (/dev/input/mouse0)
[ 8.272] (**) MSFT0001:00 06CB:7F28 Mouse: Applying InputClass "devname"
[ 8.272] (II) Using input driver 'libinput' for 'MSFT0001:00 06CB:7F28 Mouse'
[ 8.272] (**) MSFT0001:00 06CB:7F28 Mouse: always reports core events
[ 8.272] (**) Option "Device" "/dev/input/mouse0"
[ 8.316] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 8.316] (EE) libinput: MSFT0001:00 06CB:7F28 Mouse: Failed to create a device for /dev/input/mouse0
[ 8.316] (EE) PreInit returned 2 for "MSFT0001:00 06CB:7F28 Mouse"
[ 8.316] (II) UnloadModule: "libinput"
[ 8.317] (II) config/udev: Adding input device MSFT0001:00 06CB:7F28 Touchpad (/dev/input/event7)
[ 8.317] (**) MSFT0001:00 06CB:7F28 Touchpad: Applying InputClass "devname"
[ 8.317] (**) MSFT0001:00 06CB:7F28 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 8.317] (II) Using input driver 'libinput' for 'MSFT0001:00 06CB:7F28 Touchpad'
[ 8.317] (**) MSFT0001:00 06CB:7F28 Touchpad: always reports core events
[ 8.317] (**) Option "Device" "/dev/input/event7"
[ 8.319] (II) event7 - MSFT0001:00 06CB:7F28 Touchpad: is tagged by udev as: Touchpad
[ 8.322] (II) event7 - MSFT0001:00 06CB:7F28 Touchpad: device is a touchpad
[ 8.322] (II) event7 - MSFT0001:00 06CB:7F28 Touchpad: device removed
[ 8.376] (**) Option "Tapping" "on"
[ 8.377] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-MSFT0001:00/0018:06CB:7F28.0001/input/input26/event7"
[ 8.377] (II) XINPUT: Adding extended input device "MSFT0001:00 06CB:7F28 Touchpad" (type: TOUCHPAD, id 17)
[ 8.380] (**) Option "AccelerationScheme" "none"
[ 8.380] (**) MSFT0001:00 06CB:7F28 Touchpad: (accel) selected scheme none/0
[ 8.380] (**) MSFT0001:00 06CB:7F28 Touchpad: (accel) acceleration factor: 2.000
[ 8.380] (**) MSFT0001:00 06CB:7F28 Touchpad: (accel) acceleration threshold: 4
[ 8.382] (II) event7 - MSFT0001:00 06CB:7F28 Touchpad: is tagged by udev as: Touchpad
[ 8.384] (II) event7 - MSFT0001:00 06CB:7F28 Touchpad: device is a touchpad
[ 8.386] (II) config/udev: Adding input device MSFT0001:00 06CB:7F28 Touchpad (/dev/input/mouse1)
[ 8.386] (**) MSFT0001:00 06CB:7F28 Touchpad: Applying InputClass "devname"
[ 8.386] (II) Using input driver 'libinput' for 'MSFT0001:00 06CB:7F28 Touchpad'
[ 8.386] (**) MSFT0001:00 06CB:7F28 Touchpad: always reports core events
[ 8.386] (**) Option "Device" "/dev/input/mouse1"
[ 8.436] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 8.436] (EE) libinput: MSFT0001:00 06CB:7F28 Touchpad: Failed to create a device for /dev/input/mouse1
[ 8.436] (EE) PreInit returned 2 for "MSFT0001:00 06CB:7F28 Touchpad"
[ 8.436] (II) UnloadModule: "libinput"
[ 8.437] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 8.437] (**) AT Translated Set 2 keyboard: Applying InputClass "devname"
[ 8.437] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.437] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 8.437] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 8.437] (**) AT Translated Set 2 keyboard: always reports core events
[ 8.437] (**) Option "Device" "/dev/input/event3"
[ 8.438] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.438] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.441] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 8.470] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 8.470] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[ 8.470] (**) Option "xkb_layout" "us"
[ 8.471] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.472] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.494] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "devname"
[ 8.494] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.495] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: Applying InputClass "system-keyboard"
[ 8.495] (II) Using input driver 'libinput' for 'ITE Tech. Inc. ITE Device(8910) Keyboard'
[ 8.495] (**) ITE Tech. Inc. ITE Device(8910) Keyboard: always reports core events
[ 8.495] (**) Option "Device" "/dev/input/event11"
[ 8.495] (II) libinput: ITE Tech. Inc. ITE Device(8910) Keyboard: is a virtual subdevice
[ 8.495] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb5/5-4/5-4:1.0/0003:048D:C100.0003/input/input17/event11"
[ 8.495] (II) XINPUT: Adding extended input device "ITE Tech. Inc. ITE Device(8910) Keyboard" (type: KEYBOARD, id 19)
[ 8.495] (**) Option "xkb_layout" "us"
[ 9.684] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 18.998] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 18.998] (II) modeset(0): Printing DDC gathered Modelines:
[ 18.998] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 19.000] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 19.001] (II) modeset(0): Printing DDC gathered Modelines:
[ 19.001] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 19.001] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 19.001] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 19.001] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 19.001] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 19.001] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 19.001] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 19.001] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 19.001] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 19.001] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 19.001] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 19.001] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 19.001] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 49.384] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 49.384] (II) modeset(0): Printing DDC gathered Modelines:
[ 49.384] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 49.386] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 49.386] (II) modeset(0): Printing DDC gathered Modelines:
[ 49.386] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 49.387] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 49.387] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 49.387] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 49.387] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 49.387] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 49.387] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 49.387] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 49.387] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 49.387] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 49.387] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 49.387] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 49.387] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 52.990] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 52.990] (II) modeset(0): Printing DDC gathered Modelines:
[ 52.990] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 52.993] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 52.993] (II) modeset(0): Printing DDC gathered Modelines:
[ 52.993] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 52.993] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 52.993] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 52.993] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 52.994] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 52.994] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 52.994] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 52.994] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 52.994] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 52.994] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 52.994] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 52.994] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 52.994] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
[ 83.009] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/js0)
[ 83.009] (**) Microsoft X-Box 360 pad: Applying InputClass "devname"
[ 83.009] (II) Using input driver 'libinput' for 'Microsoft X-Box 360 pad'
[ 83.009] (**) Microsoft X-Box 360 pad: always reports core events
[ 83.009] (**) Option "Device" "/dev/input/js0"
[ 83.086] (II) js0 - not using input device '/dev/input/js0'.
[ 83.086] (EE) libinput: Microsoft X-Box 360 pad: Failed to create a device for /dev/input/js0
[ 83.086] (EE) PreInit returned 2 for "Microsoft X-Box 360 pad"
[ 83.086] (II) UnloadModule: "libinput"
[ 83.108] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/event10)
[ 83.108] (**) Microsoft X-Box 360 pad: Applying InputClass "devname"
[ 83.108] (II) Using input driver 'libinput' for 'Microsoft X-Box 360 pad'
[ 83.108] (**) Microsoft X-Box 360 pad: always reports core events
[ 83.108] (**) Option "Device" "/dev/input/event10"
[ 83.109] (II) event10 - Microsoft X-Box 360 pad: is tagged by udev as: Joystick
[ 83.109] (II) event10 - Microsoft X-Box 360 pad: device is a joystick or a gamepad, ignoring
[ 83.169] (II) event10 - not using input device '/dev/input/event10'.
[ 83.169] (EE) libinput: Microsoft X-Box 360 pad: Failed to create a device for /dev/input/event10
[ 83.169] (EE) PreInit returned 2 for "Microsoft X-Box 360 pad"
[ 83.169] (II) UnloadModule: "libinput"
[ 84.963] (II) config/udev: Adding input device Microsoft X-Box 360 pad 0 (/dev/input/js1)
[ 84.963] (**) Microsoft X-Box 360 pad 0: Applying InputClass "devname"
[ 84.963] (II) Using input driver 'libinput' for 'Microsoft X-Box 360 pad 0'
[ 84.963] (**) Microsoft X-Box 360 pad 0: always reports core events
[ 84.963] (**) Option "Device" "/dev/input/js1"
[ 85.009] (II) js1 - not using input device '/dev/input/js1'.
[ 85.009] (EE) libinput: Microsoft X-Box 360 pad 0: Failed to create a device for /dev/input/js1
[ 85.009] (EE) PreInit returned 2 for "Microsoft X-Box 360 pad 0"
[ 85.009] (II) UnloadModule: "libinput"
[ 85.010] (II) config/udev: Adding input device Microsoft X-Box 360 pad 0 (/dev/input/event16)
[ 85.010] (**) Microsoft X-Box 360 pad 0: Applying InputClass "devname"
[ 85.010] (II) Using input driver 'libinput' for 'Microsoft X-Box 360 pad 0'
[ 85.010] (**) Microsoft X-Box 360 pad 0: always reports core events
[ 85.010] (**) Option "Device" "/dev/input/event16"
[ 85.010] (EE) client bug: Invalid path /dev/input/event16
[ 85.010] (EE) libinput: Microsoft X-Box 360 pad 0: Failed to create a device for /dev/input/event16
[ 85.010] (EE) PreInit returned 2 for "Microsoft X-Box 360 pad 0"
[ 85.010] (II) UnloadModule: "libinput"
[ 424.980] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 424.980] (II) modeset(0): Printing DDC gathered Modelines:
[ 424.980] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 424.983] (II) modeset(0): EDID vendor "BOE", prod id 2271
[ 424.983] (II) modeset(0): Printing DDC gathered Modelines:
[ 424.983] (II) modeset(0): Modeline "1920x1080"x0.0 352.24 1920 1968 2000 2080 1080 1083 1089 1176 +hsync -vsync (169.3 kHz eP)
[ 424.983] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 424.983] (--) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
[ 424.983] (--) NVIDIA(GPU-0): DFP-0: 2660.0 MHz maximum pixel clock
[ 424.983] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 424.983] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 424.983] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 424.983] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 424.983] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 424.983] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 424.983] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 424.983] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 424.983] (--) NVIDIA(GPU-0): DFP-3: 2660.0 MHz maximum pixel clock
