System will not boot since changing display manager
Hello all,
I was trying to switch my display manager from lightdm to ly, and I cannot successfully boot my system after performing these steps:
Sudo systemctl disable lightdm.service,
And then immediately,
sudo systemctl enable ly.service
(I think I skipped a necessary step in there?)
And when I reboot, I get an authentication error, without ever getting to the display manager login screen.
Has anyone some suggestions as to how I can rectify this?
Thanks for any and all kind suggestions.
Hello,
If you can open a TTY and log in to the system, you can check the status of the display manager :
systemctl status display-manager.service
Hello, and thanks for the reply.
I cannot get to the tty. System seems to hang.
Have booted from live-iso to use chroot, but cannot find out how to mount boot and home partitions as they are on an nvme. Been looking around.
sudo mount  /dev/nvme1n1p2  /mnt
sudo mount  /dev/nvme1n1p1  /mnt/boot/efi
sudo arch-chroot /mnt
example :arrow_double_up:
Thanks gang!
