cluster
December 26, 2020, 4:54pm
1
Operating System: EndeavourOS
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.77.0
Qt Version: 5.15.2
Kernel Version: 5.9.14-zen1-1-zen
OS Type: 64-bit
Processors: 8 × AMD FX™-8350 Eight-Core Processor
Memory: 15.6 GiB of RAM
Graphics Processor: llvmpipe
maybe something went wrong during an upgrade …
Graphics Processor shows llvmpipe instead of nvidia
installed:
nvidia-dkms-455.45.01-1-x86_64
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
yesterday I also switched from sddm to lightdm, could it have something to do with that?
Depends on how you uninstalled it. Llvm is a software fallback gpu driver. Are the nvidia drivers still installed?
cluster
December 26, 2020, 5:07pm
3
yes, the drivers are still installed and during re-installing it shows virtualbox & nvidia-dkms are compiled …
# lsmod | grep nvidia
nvidia_drm 61440 1
nvidia_modeset 1220608 2 nvidia_drm
nvidia 28299264 72 nvidia_modeset
drm_kms_helper 282624 1 nvidia_drm
drm 643072 4 drm_kms_helper,nvidia_drm
# lsinitcpio /boot/initramfs-linux.img | grep nvidia
usr/lib/modprobe.d/nvidia-dkms.conf
cluster
December 26, 2020, 5:10pm
4
shoud I re-run “nvidia-installer-dkms” ?
You’ll need to wait for someone else at this point I don’t use nvidia hardware.
More information on what you are trying to do will help?
Is it a virtual or hardware install?
cluster
December 26, 2020, 5:17pm
6
EOS is running on hardware, I’m sure it was still using the nvidia driver until last week
26.12.20 17:45 kernel NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
26.12.20 17:45 kernel nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 455.45.01 Thu Nov 5 22:55:44 UTC 2020
26.12.20 17:45 kernel [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
26.12.20 17:45 kernel [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
cluster
December 26, 2020, 6:23pm
7
strange … when I switch back from lightdm to sddm it shows
Graphics Processor: GeForce GT 630/PCIe/SSE2
did I miss something during the lightdm installation, lightdm seems to ignore the X11 files (20-nvidia.conf)
cluster
December 27, 2020, 7:56am
9
yes, I have activated lightdm via welcome … it works well but it seems to ignore or conflict w/ 20-nvidia.conf (there is no xorg.conf), nvidia drivers are loaded but not used after a lightdm boot.
cluster
December 27, 2020, 3:06pm
10
x-0.log shows using /etc/X11/xorg.conf.d
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 26 19:12:53 2020
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
xf86: found device 0
(II) Server terminated successfully (0). Closing log file.
lightdm.log and seat0-greeter.log do not contain any error or nvidia messages
Maybe run the nvidia-installer-dkms -t which is in test mode to see if it shows any errors. Then you could re-install it if you think it might correct the issue. Just drop the -t and i think you need to use sudo if you are going to run the install.
cluster
January 3, 2021, 10:50am
12
got it solved!
the ModulePath part was missing in 20-nvidia.conf
Section "Files"
ModulePath "/usr/lib/nvidia/xorg"
ModulePath "/usr/lib/xorg/modules"
EndSection
