System upgrade conflict [svt-av1] [lib32-svt-av1]
I was trying to upgrade my system and got a dependency conflict error
resolving dependencies...
:: installing svt-av1 (1.7.0-1) breaks dependency 'svt-av1=1.6.0' required by lib32-svt-av1
How do I solve this?
See if this post can be of any help:
Thank you for your reply.
I had already found this post. But it does not help. He did not share how he solved the issue (He himself doesn’t know I think)
What does it actually mean?
It’s no longer on the AUR?
If it has been installed on your system before from the official repos, it seems it is no longer available there. It is currently in the AUR.
What does the following command show?
pactree -r lib32-svt-av1
lib32-svt-av1
Does this mean I can just remove it? I’m scared to do it though. Don’t know if its being used or not.
Yes. Nothing else in your system is dependent on this package. Otherwise you would have had a list of those packages.
You could do:
sudo pacman -R lib32-svt-av1 && sudo pacman -Syu
to first remove that package and then update the packages you have installed originating from the official repos.
It worked!
Thank you
You are welcome!
Glad you got it sorted out!
And welcome to EnOS’ community @rd_626!
