On my Gateway Laptop (LXQT,Openbox) The System tray icon for Removable Media When I click on it Instead of Launching Thunar it loads up Kitty Terminal instead. On my Daily The click does open up my Filemanger (Thunar) I have looked at the files in .config/lxqt and they are all the *same on both machines. I have also checked the panel.conf file in /etc/xdg/lxqt and see no exectuable commands for the sections in each of the files I have searched. Does anyone know how I can get the tray Icon when clicked to open Thunar instead of Kitty?
*=I did have to add this to get automount to work on the Gateway thinking this would solve my issue however it doesn’t completely solve it just the automount part.
I suspect the openCommand needs to be inside the [Plugin-X] block that has type=mount, not in a separate [mount] section. The full output will confirm it.
Ok so I checked the mime-type again after going to A.I and it has reverted back to kitty so I changed it again and now it seems to be working as expected. Not sure why the first time it didn’t keep the setting.
