I installed EndeavourOS Plasma, love it! I’ve searched this great forum & the internet not to mention searching myself under “System Settings” on/off for the past 3 days looking for a setting. When I walk away from my PC for say 20ish minutes my screen is black with the date/time ect move my mouse type password in and back to my desktop, how do i disable this or at the very least change the color/picture? I’m sure i could possibly be overlooking something somewhere, any help would be much appreciated. Thanks!
Look in System Settings->Hardware->Power Management->Energy Saving
Alternatively, you can look in:
System Settings->Workspace->Workspace Behavior->Screen Locking->Appearance
There are settings in both places.
disable the screensaver ?
there are some display settings to setup the screensaver behaviour at display i belive im not sure …
if stil happen try xset off
or just to add aur/plasma5-applets-caffeine-plus 1.4-2 [8+] [0.00%] [27 Aug 2019]
and as dalto tells
Thank you! I unticked the box that read Lock Screen Automatically, it was set at 5min. Much appreciated!
System Settings->Workspace->Workspace Behavior->Screen Locking->Appearance <— This did the trick
Yeah, that one always drove me crazy after a new install, but it only takes 5 minutes of inactivity to remind me to turn of suspend. I have learned how to save my settings so I have them all back after a reinstall or for another machine.
EndeavourOS with Plasma rocks!
