System rescue of non-booting Raspberry Pi 4b
I have a https://endeavouros.com/headless-arm-server-install/ (I believe) on a Raspberry Pi 4b which is not booting any more after a recent system update using yay. Has anyone else encountered this?
I tried to https://discovery.endeavouros.com/system-rescue/repair-a-non-booting-grub/2021/03/ and https://discovery.endeavouros.com/installation/systemd-boot/2022/12/ but grub-install yields command not found and bootctl complains about an /efi mount not existing altough mounted.
I do not remember, if grub or bootctl is being used; at least the latter command is found. But is it not typical to get grub on a headless ARM server? Is there a way to find - when arch-chroot into it - if it uses bootctl or grub? (step 1)
The partition layout is such:
Device     Boot  Start      End  Sectors  Size Id Type
/dev/sdb1         2048   411647   409600  200M  c W95 FAT32 (LBA)
/dev/sdb2       411648 62333951 61922304 29,5G 83 Linux
gparted says that out of the 200MiB 170MiB is used. Should that point to a size problem and it just needs an older kernel (which?) deleted?
In the meantime, I decided to re-install enos (server image is not available any more) This is kind of a solution…
It is on my to-do list. Hopefully I can create a new image for this in the next few days.
Pudge
Sounds good. Just out of curiosity: will grub or systemd-boot be used as a bootloader?
Any chance to increase the boot partition as I reckon this has caused the failure?
Thanks
Neither One. On ARM devices, a bootloader takes the place of grub and systemd-boot. The most common one is u-boot and another is tow-boot.
To install EnOS ARM on an ARM device, one downloads a tar image or a bit-by-bit image and burns the image onto a storage device. The boot partition size is determined by the script that creates the images. So one would have to do a git clone to download the script, then edit the script manually before running it to creating an image.
I have never seen the boot size cause any problems on EnOS ARM devices.
Pudge
I just updated my pi400 and had no issues.
And how full is the boot partition? Thanks
It is using 62 MB out of 268 MB.
This device has been up and running for about 18 months.
Pudge
